Mirsad 0 Posted May 4, 2019 Author Report Share Posted May 4, 2019 23 hours ago, StunterSM said: Nisam gledao na mom, ali normalno je 250 na leru, a oko 400-500 sa zatvorenim egrom koliko me secanje sluzi. Jer na leru nema reciklazu izduvnuh gasova i mnogo vise vazduha prolazi kroz protokomer. super hvala znaci 250 na leru ! da vidio sam da bmw sccaner ne moze da ocitava live data evo narucio sam kabal za inpu pa da vidim:) hvala Link to post Share on other sites
ilovebigasses 0 Posted May 4, 2019 Report Share Posted May 4, 2019 Javljaj ? Link to post Share on other sites
Mirsad 0 Posted May 7, 2019 Author Report Share Posted May 7, 2019 On 5/4/2019 at 7:47 PM, ilovebigasses said: Javljaj ? ima li tko da mi zakaci da skinem INPA i upustvo za instaliranje win 10. Hvala Link to post Share on other sites
ilovebigasses 0 Posted May 7, 2019 Report Share Posted May 7, 2019 Brate vcrs cu da okacim i da ti serujem link, nmg pre. Radi sve provereno. Link to post Share on other sites
Mirsad 0 Posted May 7, 2019 Author Report Share Posted May 7, 2019 1 hour ago, ilovebigasses said: Brate vcrs cu da okacim i da ti serujem link, nmg pre. Radi sve provereno. HVALA BRATE Link to post Share on other sites
Kubi82 0 Posted May 7, 2019 Report Share Posted May 7, 2019 Ovde imas dobro uputstvo za kodiranje pomocu NCS Experta, a imas i linkove za skidanje svega drugog sto ti treba za Win10.Ja sam kod mene instalirao i radi, ali sam morao da spojim pinove 7 i 8 na K - DCAN kablu... Sent from my SM-J710F using Tapatalk Link to post Share on other sites
Kubi82 0 Posted May 7, 2019 Report Share Posted May 7, 2019 Sent from my SM-J710F using Tapatalk Link to post Share on other sites
Mirsad 0 Posted May 8, 2019 Author Report Share Posted May 8, 2019 On 5/7/2019 at 1:45 PM, Mirsad said: HVALA BRATE jos cekam kad stignes nije frka Link to post Share on other sites
ilovebigasses 0 Posted May 12, 2019 Report Share Posted May 12, 2019 Joj sutra vece kacimm. Prastaj u CG sam Link to post Share on other sites
Mirsad 0 Posted May 12, 2019 Author Report Share Posted May 12, 2019 48 minutes ago, ilovebigasses said: Joj sutra vece kacimm. Prastaj u CG sam Oo da zaboravio sam da si rekao da si dole ? Link to post Share on other sites
Mirsad 0 Posted May 29, 2019 Author Report Share Posted May 29, 2019 Stigao mi je kablic za INPU , od kolege sam instalirao inpu 2016 po upustvu radi bez greske na win 10x64, uhvatio sam malo vremena da prikljucim i ocitam MAF koji me zafrkaje , dobio sam ove vrijednosti koje su varirale posto je motor bio hladan, poslje sam skontao da treba temperatura da bude na radnoj 90c. da bi imao tacne vrijednosti svega ali nisam dugo cekao ovo je samo ispred kuce na brzaka uglavnom kolega Miki rece da vrijednosti MAF-a trebaju da su 25,00 . Link to post Share on other sites
NikNS 0 Posted May 29, 2019 Report Share Posted May 29, 2019 Stigao mi je kablic za INPU , od kolege sam instalirao inpu 2016 po upustvu radi bez greske na win 10x64, uhvatio sam malo vremena da prikljucim i ocitam MAF koji me zafrkaje , dobio sam ove vrijednosti koje su varirale posto je motor bio hladan, poslje sam skontao da treba temperatura da bude na radnoj 90c. da bi imao tacne vrijednosti svega ali nisam dugo cekao ovo je samo ispred kuce na brzaka [emoji6] uglavnom kolega Miki rece da vrijednosti MAF-a trebaju da su 25,00 .Riknuo ti je maf. Tesko da ces ciscenjem da ga vratis u zivot tako je i meni. On ocitava desetu vrednost videces i kad das gas da stoji isto tako vrti od 60 do 65Sent from my SM-J730F using Tapatalk Link to post Share on other sites
Mirsad 0 Posted May 29, 2019 Author Report Share Posted May 29, 2019 1 hour ago, NikNS said: Riknuo ti je maf. Tesko da ces ciscenjem da ga vratis u zivot tako je i meni. On ocitava desetu vrednost videces i kad das gas da stoji isto tako vrti od 60 do 65 Sent from my SM-J730F using Tapatalk I ja sam 1000% u to siguran cistio sam ga 2x prije ove provjere i u pravu si , moram kupiti novi nem druge Link to post Share on other sites
NikNS 0 Posted May 29, 2019 Report Share Posted May 29, 2019 I ja sam 1000% u to siguran cistio sam ga 2x prije ove provjere i u pravu si , moram kupiti novi [emoji4] nem druge Nudice ti sa kucistem al to ti ne treba, samo ulozak uzmi tj sam protokomer, i vijaj pierburg ako imas kesa ako ne onda moze i boschSent from my SM-J730F using Tapatalk Link to post Share on other sites
Mirsad 0 Posted May 29, 2019 Author Report Share Posted May 29, 2019 (edited) 45 minutes ago, NikNS said: Nudice ti sa kucistem al to ti ne treba, samo ulozak uzmi tj sam protokomer, i vijaj pierburg ako imas kesa ako ne onda moze i bosch Sent from my SM-J730F using Tapatalk Ma najveci je problem sto mi je BOSCH i kod njega se ne mijenja samo ulozak mora sve , sranj ali eto narucio sam bosch 150eura , ma ja sam osjeti da nesko malo slabije povuce ? i na leru je znao da variraju obrtaji , de mi reci kad se zamjeni dali se treba kakva adaptaciju uradit ili je to to samo pokopcas i furaj . Edited May 29, 2019 by Mirsad Link to post Share on other sites
NikNS 0 Posted May 29, 2019 Report Share Posted May 29, 2019 Ma najveci je problem sto mi je BOSCH i kod njega se ne mijenja samo ulozak mora sve [emoji20] , sranj ali eto narucio sam bosch 150eura , ma ja sam osjeti da nesko malo slabije povuce ? i na leru je znao da variraju obrtaji , de mi reci kad se zamjeni dali se treba kakva adaptaciju uradit ili je to to samo pokopcas i furaj . [emoji4]Prikopcas i cepas pun gas i sve mislis da si seo u tudji auto hahaha. Videces razlika je ogromnaSent from my SM-J730F using Tapatalk Link to post Share on other sites
Mirsad 0 Posted May 29, 2019 Author Report Share Posted May 29, 2019 6 minutes ago, NikNS said: Prikopcas i cepas pun gas i sve mislis da si seo u tudji auto hahaha. Videces razlika je ogromna Sent from my SM-J730F using Tapatalk vijerujem ti javim kad ga prikopcam i postavim sliku sa inpe koliko nov pokazuje ? bas me interesuje NOV koje daje vrijednosti ???? Link to post Share on other sites
Mirsad 0 Posted May 29, 2019 Author Report Share Posted May 29, 2019 23 minutes ago, Mirsad said: vijerujem ti javim kad ga prikopcam i postavim sliku sa inpe koliko nov pokazuje ? bas me interesuje NOV koje daje vrijednosti ???? sad nesto rovim po netu i ispravan maf treba da daje vrijednosti od 11.00 do 12, ?? i stanju mirovanja !!! covjece kod mene od 50.00 pa do preko 60.?? ?? Link to post Share on other sites
NikNS 0 Posted May 29, 2019 Report Share Posted May 29, 2019 sad nesto rovim po netu i ispravan maf treba da daje vrijednosti od 11.00 do 12, ?? i stanju mirovanja !!! covjece kod mene od 50.00 pa do preko 60.?? [emoji3][emoji3]U vrednosti se ne razuemm preterano, to necu da ti pricam nista ali u praksi neces verovati koja je razlika. Tvoj uopste ne daje vrednosti nikqkvr nego kolko motor zadaje on tolko cita kad odradis sve bices prezadovoljan. Obavezno javi utiske, bice kao da si ga cipovao hahaSent from my SM-J730F using Tapatalk Link to post Share on other sites
ilovebigasses 0 Posted May 29, 2019 Report Share Posted May 29, 2019 Ja se kunem u Bosch. Link to post Share on other sites
NikNS 0 Posted May 29, 2019 Report Share Posted May 29, 2019 Ja se kunem u Bosch.Pravi Bosch a ne ono poljsko njesra ili neke licence [emoji41] ja uvek idem po prvoj ugradnji ili kako je vec bilo na autu Sent from my SM-J730F using Tapatalk Link to post Share on other sites
Mirsad 0 Posted May 29, 2019 Author Report Share Posted May 29, 2019 OEM BOSCH po kataloskom za moje auto se krece kod nas do 200 eura, meni jaran mehanicar pa ce mi uraditi poust na 150eurica , mada sam gledao i pierburg i on je isto u toj cijeni ali kontam posto je na autu bosh neka ide i dalje Link to post Share on other sites
Rocco77 0 Posted May 29, 2019 Report Share Posted May 29, 2019 Oem bosch oko 200e nesto kostao,trajao tacno koliko i garancija 6 mjeseci tako da sad trazim samo polovan original dobarПослато са SM-A520F уз помоћ Тапатока Link to post Share on other sites
Mirsad 0 Posted May 29, 2019 Author Report Share Posted May 29, 2019 11 minutes ago, Rocco77 said: Oem bosch oko 200e nesto kostao,trajao tacno koliko i garancija 6 mjeseci tako da sad trazim samo polovan original dobar Послато са SM-A520F уз помоћ Тапатока Da ti nisu sta podvalili ? Link to post Share on other sites
Rocco77 0 Posted May 29, 2019 Report Share Posted May 29, 2019 Da ti nisu sta podvalili [emoji35]Kod druga u auto djelovima i to mi je cak popust dao,a pirburg nije imao na stanju za e60,mada mi je dosta njih reklo da im se bolje bosch pokaza. I mn kad je stavljen razlika u voznji nebo i zemlja sad vidim opet se umrtvio na prvi gas i opet variraПослато са SM-A520F уз помоћ Тапатока Link to post Share on other sites
