wice 0 Posted June 29, 2013 Author Report Share Posted June 29, 2013 E DO JAJCA,JA JOS NISAM RESIO PROBLEM KOD MENE Link to post Share on other sites
wice 0 Posted July 10, 2013 Author Report Share Posted July 10, 2013 Link to post Share on other sites
ivicaflojd 0 Posted July 10, 2013 Report Share Posted July 10, 2013 felne su extra samo jos kad bi ga mozda spustio jos malo... ;) Link to post Share on other sites
wice 0 Posted July 10, 2013 Author Report Share Posted July 10, 2013 hocu al nemam vremena :( Link to post Share on other sites
vlada-t 0 Posted July 10, 2013 Report Share Posted July 10, 2013 Fino mu stoje ove felne....samo jos malo dole, i ja bih rekao... Link to post Share on other sites
susice34 0 Posted July 13, 2013 Report Share Posted July 13, 2013 Felne ti nisu ni za k.... Ako resis da ih prodas samo meni da javis :D Link to post Share on other sites
wice 0 Posted July 28, 2013 Author Report Share Posted July 28, 2013 zelim ovako javno da se puno zahvalim DEKIJU IZ CUPRIJE i njegovom burazeru na poklonu,tj zatamljivanju stakala.jes jednom momci svaka vam cast na svemu i na tolikom putu do mene.vas sam duznik!!!! Link to post Share on other sites
ivicaflojd 0 Posted July 29, 2013 Report Share Posted July 29, 2013 lepo lepo nema sta... :) Link to post Share on other sites
Mauro 0 Posted July 29, 2013 Report Share Posted July 29, 2013 zelim ovako javno da se puno zahvalim DEKIJU IZ CUPRIJE i njegovom burazeru na poklonu,tj zatamljivanju stakala.jes jednom momci svaka vam cast na svemu i na tolikom putu do mene.vas sam duznik!!!! :good: Link to post Share on other sites
wice 0 Posted August 4, 2013 Author Report Share Posted August 4, 2013 ugradio sam i plin kod babica,sve je ok ,i preporuke,mada i dalje nisam resio problem sa losim radom auta....i dalje ne radi lepo .i tako Link to post Share on other sites
DEKI Cuprija 0 Posted August 7, 2013 Report Share Posted August 7, 2013 Hvala Hvala,zasluzio si i vise od ovoga. Ovako je bilo ................. :rolleyes: :rolleyes: :rolleyes: :rolleyes: print screen windows 7 windows 7 screen shot screenshot software for windows how to take a screen shot imageshackus Link to post Share on other sites
ja sam 0 Posted August 11, 2013 Report Share Posted August 11, 2013 dobar je...mnogo mu felne znace... Link to post Share on other sites
Dzoni 0 Posted October 6, 2013 Report Share Posted October 6, 2013 Wice reci mi da li si menjao hladnjak ili si ostavio taj koji je bio dok si vozio 1.8? Link to post Share on other sites
wice 0 Posted October 6, 2013 Author Report Share Posted October 6, 2013 ostavio,ali sam menjao vec kada sam ubacivao klimu bio je mali,pa sam ubacio veliki ijer je i od klime bio pogolem,tako da sam ga sada samo zadrzao Link to post Share on other sites
wice 0 Posted October 20, 2013 Author Report Share Posted October 20, 2013 nego ima li neko ideju kako da mu oborim ler?stalno je na 1000 ne zalece se ne varira,ali me smara sto je visok,,,a uz to me smara i sto pali iza 2 ili treceg puta kada je topao,nebitno je da li je sa gasom ili bez...kada zaverglam a ne upali mogu ga verglati i minut i nece dok ne prekinem i pokusam ponovo,i onda upali bez problema,uglavnom kada se to desava zaverglam dva puta po sekundu dve i treci put kada zaverglam upali na cvrgu Link to post Share on other sites
Bimmer5 0 Posted October 22, 2013 Report Share Posted October 22, 2013 Dobra trojcica,citao sam temu od pocetka.Bas ulozeno dosta truda,novca,i vremena.Jedina mi bode oci ona oznaka 318,ja bih to skinuo. ;) Link to post Share on other sites
zeljko_srb 0 Posted October 23, 2013 Report Share Posted October 23, 2013 oteraj auto kod bate brate vise ne vredi ti da se sam bakces toliko Link to post Share on other sites
wice 0 Posted October 23, 2013 Author Report Share Posted October 23, 2013 bio sam,pogledao je covek na brzinu,trebao bi da mu ostavim auto,a jbg meni treba svaki dan,tako da jbg teram ovako Link to post Share on other sites
wice 0 Posted January 2, 2014 Author Report Share Posted January 2, 2014 nego primetio sam nesto cudno pa da vidim da li to tako treba.primetio sam da je motorni racunar otvaran i da mu je blokada pomerena,tj u voznjikada ga nabodem po gasu ubrzava do 6300 otprilike i kada drzim gas posle pola sec ili max sekundu samo trzne i nastavi da ubrzava do 7000 i onda je u blokadi,da li to tako treba? i da li je moguce da je zbog pomerene blokade povecan i ler?posto je na 1000 Link to post Share on other sites
CasperBg82 0 Posted January 2, 2014 Report Share Posted January 2, 2014 To moze da bude uzrok problematicnog lera, a sto se blokade tice valjda je ta prva sto bi rekli "meka" blokada, a krajnja pomerena na 7 hiljada Ti nisi probao sa drugim kompjuterom? Link to post Share on other sites
wice 0 Posted January 3, 2014 Author Report Share Posted January 3, 2014 bas tako i oseca se kao da je meka :) ubrzava,zastane na tren i ponovo zalepi za sediste. jbg probao sam sa drugim,ali samo ga udzekao upalio i cinilo mi se da isto radi na leru i skinuo ga ,nisam ga vozio Link to post Share on other sites
StunterSM 0 Posted January 3, 2014 Report Share Posted January 3, 2014 Kod bokija e36 nesto jebucka ne mozemo naci sta je. Sve je menjano i opet ses. Tako da cu sad da mu skidam komplet instalaciju motornu da promenim, mozda je negde zica pukla ili nesto slicno. Ivice nisam pratio od pocetka, jesi regulator menjao? Link to post Share on other sites
wice 0 Posted January 3, 2014 Author Report Share Posted January 3, 2014 nisam,samo ga cistio Link to post Share on other sites
mackaski9 0 Posted January 3, 2014 Report Share Posted January 3, 2014 nisam,samo ga cistio Meni kada je ICV pravio probleme sa velikim variranjem, cistio sam ga pa posle par nedelja opet isto-na kraju sam mu samo skinuo dzek, da nema nikakvu funkciju i ler mi je konstantan bio na 1000obr i nije varirao pa sam tako vozio..Nekada je isto kao i kod tebe, palio iz prve, a nekada iz 2-3 po kratkom verglanju jer nije imao funkciju pa je on bio uzrok. Ja ciljam na njega, ili na instalaciju sto ide do njega..Hajde za pocetak upali auto, otvori haubu i skini dzek sa ICV i vidi ima li promena u radu, pa posle vrati da vidis da li je isto a posle isto to probaj sa protokomerom i dzekom :) Link to post Share on other sites
wice 0 Posted January 4, 2014 Author Report Share Posted January 4, 2014 napravio mi je drugar neki ads interfejs i uspeo sam da pokrenem inpu cita sve osim motora :) pristupim i motoru nekim zaobilaznim putem i imao je tri razlicite greske koje se sporadicno javljaju i uglavnom su vezane za l sondu 201 37 i 70 jedna je za relej lambda sonde druga knock senzor ili lambda i treca lambda integrator elem gledao sam relej lambde i on je kod mene narandzast a na netu sam gledao uglavnom je svetlo zeleni i na m40 je svetlo zeleni.to je rele do kabine,zna li neko kakav treba da bude? evo kako izgleda interfejs za okrugli konektor sam prepravio poklopac konektora :) Link to post Share on other sites
