wice 0 Posted May 25, 2013 Author Report Share Posted May 25, 2013 pa za senzor bregaste ne znam,da li se on tako manifestuje?kako da ga proverim? imam problem dijagnostiku ne mogu da nateram da radi kada je povezem a sto se tice kompresije,mislim da je ok, a kada skidam bobinu po bobinu dok radi na sve druge cilindre promeni rad,ali na njega ne menja,opet sam ga danas stiskao malo,zaista dobro vuce i poteze odlicno,mozda je fals, pro=bacu ovih dana da skinem usisnu da proverim gumice i u kakvom je stanju grana usisna Link to post Share on other sites
CasperBg82 0 Posted May 25, 2013 Report Share Posted May 25, 2013 Vidi ovo http://www.bimmerfest.com/forums/showthread.php?t=571094 camshaft position sensor (CPS). This important sensor tells the car’s computer where the engine is in its rotation with respect to the combustion cycle. The DME takes the signals from the cam position sensor and crankshaft position sensor, and calculates when to fire the fuel injectors and spark plugs. If the camshaft position sensor is not operating properly, your car will run very erratically or perhaps not at all. Link to post Share on other sites
wice 0 Posted May 25, 2013 Author Report Share Posted May 25, 2013 probacu i sa njim,pao mi je i on pre neki dan na pamet Link to post Share on other sites
CasperBg82 0 Posted May 26, 2013 Report Share Posted May 26, 2013 Ajd ako te ne bude mrzelo okaci neki klip, da vidimo kako radi, najbolje zvuk sa auspuha Osim ako je isto kao sa snimka na onom linku :) Link to post Share on other sites
boban 7 0 Posted May 26, 2013 Report Share Posted May 26, 2013 pa ovaj tvoj bolje radi od onog sredjenog :lol: Link to post Share on other sites
wice 0 Posted May 26, 2013 Author Report Share Posted May 26, 2013 ma na leru se cuje kao v motor,nije bas tecan rad Link to post Share on other sites
Glisa 0 Posted May 26, 2013 Report Share Posted May 26, 2013 I ja sam hteo d kazem da se cuje kao amerikan muscle :) Link to post Share on other sites
susice34 0 Posted May 26, 2013 Report Share Posted May 26, 2013 I ja sam hteo d kazem da se cuje kao amerikan muscle :) +1 Link to post Share on other sites
wice 0 Posted May 26, 2013 Author Report Share Posted May 26, 2013 MERIO sam otpor na senzorima na bregastoj 1320 na radilici 540 sto znaci da je ok Link to post Share on other sites
zeljko_srb 0 Posted May 27, 2013 Report Share Posted May 27, 2013 ja ne mogu da otvorim klipove da cujem zvuk... a ovo sto te drka. stvarno ne bih znao sta da ti kazem. provozaj se do bate pa nek on vidi. Link to post Share on other sites
wice 0 Posted May 28, 2013 Author Report Share Posted May 28, 2013 bas me nervira.skidao sam i granu i sve predihtovao i opet ne radi lepo,i ler je i dalje na 1000 ,a mozda tabla ne radi.kada dam kontakt kazaljka obrtomera se odvoji od iglice 2-3mm Link to post Share on other sites
hagor 0 Posted June 2, 2013 Report Share Posted June 2, 2013 opaaa, lepo, lepo :) hoces li i ostatak m-optica da pakujes ? Link to post Share on other sites
wice 0 Posted June 2, 2013 Author Report Share Posted June 2, 2013 hocu cim bude para,imam vec retrovizore ali sa coupe pa ih moram prepraviti Link to post Share on other sites
Glisa 0 Posted June 3, 2013 Report Share Posted June 3, 2013 Jos ove bubrege da skines i sredis,malo su se fucnuli :lol: Inace je auto kao bombona :D Link to post Share on other sites
wice 0 Posted June 24, 2013 Author Report Share Posted June 24, 2013 hocu da vratim vezni lim sa starim bubrezima koji je bio ipak mi je dosta lepsi,tako da ove zato ne sredjujem :) prepravio sam retrovizore od kupea posto nisam mogao naci nosace od limuzine ,evo par slika ako nekoga intresuje malo sam obrusio nosac i prihvate za srafove,i napravio medjuploce i to ovako izgleda Link to post Share on other sites
vlada-t 0 Posted June 24, 2013 Report Share Posted June 24, 2013 jel su u planu i ///M lajsne? Link to post Share on other sites
wice 0 Posted June 24, 2013 Author Report Share Posted June 24, 2013 jesu ako nekada bude para Link to post Share on other sites
vlada-t 0 Posted June 24, 2013 Report Share Posted June 24, 2013 auu pa bice para,nemoj tako Link to post Share on other sites
StunterSM 0 Posted June 24, 2013 Report Share Posted June 24, 2013 Evo dacu ti ja stari vezni lim sa bubrezima, samo da ga iskopam Link to post Share on other sites
wice 0 Posted June 24, 2013 Author Report Share Posted June 24, 2013 e pa hvala :) moze bez bubrega imam odlicne,u stvari imam i vezni ali je dosta rdjav,ubicu se da ga ocistim,gde god skinem boju pojavi se rdja,ako imas bolji bio bih ti zahvalan :) @vlada-t brate jebeno je bez posla vec 8 meseci dinara nisam primio u firmi,firma nit radi nit da dam otkaz i da se odreknem svega sto duguju,snalazim se privatno ali je jebeno,porodica i sve ostalo tako da je auto na poslednjem mestu Link to post Share on other sites
vlada-t 0 Posted June 24, 2013 Report Share Posted June 24, 2013 svaka ti cast za svo ovo zajebavanje onda! Link to post Share on other sites
CasperBg82 0 Posted June 28, 2013 Report Share Posted June 28, 2013 Mi smo "resili" problem sa onim M50.. pukla glava od izduvnog ventila prema izduvnoj grani a preko kanala za vodu.. Link to post Share on other sites
