BMWscaner 0 Posted December 17, 2008 Author Report Share Posted December 17, 2008 @ motorsport izvinjavam se jer u brzini kliknem na quote navika sa drugih foruma nece se ponavljati @ tokyo auspusi su tu radi vizualnog dojma i zvucnog naravno a nista nisu tezi od serijskih 1.5 cijevi i 2 inoxna zavrsetka nece mu to skoditi a sinoc auto spusten na mjeru kolko sam htio ( 5 cm ) i stigli davno naruceni SCHROT pojasevi i ugradjeni u vozilo uskoro nove slikice a u ponedjeljak felge dolaze na red imao sam malih problema sa gumama ali sam rijesio i to Link to post Share on other sites
Lemi M5 0 Posted December 17, 2008 Report Share Posted December 17, 2008 i kako ti stoje prednje poluosovine? jel ti diff nije u ravni sa glavchinama? Link to post Share on other sites
BMW E36 POWER 0 Posted December 17, 2008 Report Share Posted December 17, 2008 aj slike sto prije... Link to post Share on other sites
BMWscaner 0 Posted December 17, 2008 Author Report Share Posted December 17, 2008 poluosovine stoje ok nisu opterecene i nema nikakvih promjena na njima i nece ni biti jer je ostalo dovoljno prostora izmedju njih i sasije tako da na rupi ili necem slicnom sta trzne auto nece doci u kontakt sa sasijom jer ako dodju nastaje sracka i iskrivljivanje istih a slike ce uskoro kad stignu jos neke stvarcice i da ufatim vremena da ga operem kisa me ubija Link to post Share on other sites
Lemi M5 0 Posted December 17, 2008 Report Share Posted December 17, 2008 aj slikaj ga odozdo, samo da vidim kako stoji diff i to? Link to post Share on other sites
BMWscaner 0 Posted December 17, 2008 Author Report Share Posted December 17, 2008 moze slikat cu sad koji dan kad budem gume montirao pa usput Link to post Share on other sites
BMWscaner 0 Posted December 24, 2008 Author Report Share Posted December 24, 2008 evo malo update radova pa procjenite sami Link to post Share on other sites
Mr.BMW 0 Posted December 24, 2008 Report Share Posted December 24, 2008 Uh *ebeno joj stoje!Samo jos malkice u zemlju i lepota! :rolleyes: Link to post Share on other sites
Lemi M5 0 Posted December 24, 2008 Report Share Posted December 24, 2008 17ice su na njemu felne?! koja dimenzija guma? Link to post Share on other sites
BMW E36 POWER 0 Posted December 24, 2008 Report Share Posted December 24, 2008 bruuuuuka kako dobro izgleda...svaka cast sceneru :rolleyes: Link to post Share on other sites
motorsport 0 Posted December 24, 2008 Report Share Posted December 24, 2008 felne mu bas dobro stoje... sta si ovo radio sa farovima, eto ih kao novi... :rolleyes: Link to post Share on other sites
BMWscaner 0 Posted December 25, 2008 Author Report Share Posted December 25, 2008 farovi rastavljeni i ispolirani grubom pastom za poliranje auta usjajeni do perfekcije a felge su 17ke zadnje gume su 215/40 a prednje 205/45 i zadovoljan sam jer auto nema nikakve promjene u odnosu na one 205/55 15 sta su bile na autu cak mozda da je nekako i stabilniji na vecim felgama kolko sam dojam dobio eto tolko za ovu godinu dosta ulaganja i radova za sada do prvog mjeseca kad stizu nove igracke :rolleyes: Link to post Share on other sites
Lemi M5 0 Posted December 25, 2008 Report Share Posted December 25, 2008 extra extra, svaka chast! :rolleyes: Link to post Share on other sites
TOKYO 0 Posted December 25, 2008 Report Share Posted December 25, 2008 Odlicno izgleda, mozda da se i zadnji kraj spusti za jos 1cm do 2??? Link to post Share on other sites
Bora 0 Posted December 25, 2008 Report Share Posted December 25, 2008 Mozda malko, Ma da i ne mora prelep mi je ovako ;) Link to post Share on other sites
dacha654321 0 Posted December 25, 2008 Report Share Posted December 25, 2008 Skroz je dobar Link to post Share on other sites
BMWscaner 0 Posted December 26, 2008 Author Report Share Posted December 26, 2008 imam problem sa tim spustanjem jer je to X a ako ode prenisko ( moze jos 3 sm da ide nize ) ostat ce mi mali zazor izmedju poluosovine i sasije i u slucaju ako naletim na kakvu neravninu ili rupu ima da mi unisti zglob koji je najosjetljiviji a mogao bi to rjesiti nekim ultratvrdim amortima i spiralama ali onda se to nemoze voziti po nasim putevima. a nazad nisam nista dirao jer nemogu naci nikakve spirale za -20mm sve sta imam je puno nize od toga a to bi onda opet izgledalo jos ruznije jer onda prednji i zadnji kraj nebi nikako bili u nekom nivou ( zadnji bi bio nizi) a to nikako nezelim a posto je x pogon on ljepi cestu i bez niskog lezanja na cesti ( iako bi ja volio da mogu da idem jako nisko jer mi se to vizualno svidja ) zasad nek ostane ovako dok nesto nesmislimo sta nije dosad nikome palo na pamet ako Klinik ili neko ima bezbolno ( da neostetim poluosovine i zglobove) rjesenje neka se javi bio bi jako zahvalan Link to post Share on other sites
TOKYO 0 Posted December 26, 2008 Report Share Posted December 26, 2008 Ja volim kad auto stoji od prilike ravno, moze prednji kraj biti nizi, ali za nijansu! Bar je raspodela mase bolja, ne znam kako je kod X-a, ali definitivno je dosta laksi nazad, zato mislim da je bolje da se poravna... ;) Link to post Share on other sites
BMWscaner 0 Posted January 14, 2009 Author Report Share Posted January 14, 2009 evo danas malo u KUCKICU mjuziku ubacio ono cisto da nesto svirucka 2x ovakva u nekakvoj kutiji rucni rad zesce bezze spojio na ovo pojacalo i nekakav axion mp3 pradnji su original bmw i dobro rade jos cekam da mi donese lik ovale za nazad i dosta nisam bas fanatik za tu glazbu ali ono cisto da ima prodigy iz cega da se cuje :lol: i naravno tu je crunch napajanje od 20cm2 dosta meni Link to post Share on other sites
BMWscaner 0 Posted January 29, 2009 Author Report Share Posted January 29, 2009 evo da par slikica postavim danas se malo auto opralo nabrzake i poslikalo da se vidi sta se malkice i radilo na autu zadnjih mjesec dva nista previse ali eto nek se vidi evo uglavnom to je to ugradjene nazad distance od 1.5 cm koje ce uskoro zamjeniti 2.5cm ove idu naprijed retrovizori dectane nova crna unutrasnjost ( osim sjedala koja idu kod tapetara cim se oslobodi termin) prednja maska i cekam jos par crnih sitnica ali i to ce biti uskoro i ugradio malo glazbice cisto da se nadje ( kutiju cu tepacirati cim uhvatim vremena i fino provuci kablove ovo je privremeno sve ) eto tolko za sada bit ce uskoro jos toga dok stignu narucene stvari sve :diablo: Link to post Share on other sites
BMW E36 POWER 0 Posted January 29, 2009 Report Share Posted January 29, 2009 svaka cast sceneru!!!vjerujes li da i ja jedva cekam da tapaciras ta sjedista,bit ce to potpuno drugi auto kada to odradis... maska mu je bas mocna,retrovizori isto...vrh izgleda sada... jedino mi malo ovaj cd strci ali zaebi muziku... :diablo: Link to post Share on other sites
error 0 Posted January 29, 2009 Report Share Posted January 29, 2009 skenereeee legendo! Link to post Share on other sites
BMW-E36 0 Posted January 29, 2009 Report Share Posted January 29, 2009 Fina kockica :diablo: Link to post Share on other sites
BMWscaner 0 Posted January 29, 2009 Author Report Share Posted January 29, 2009 jbg mp3 sam ubacio koji je prvi bio pod rukom ( citaj najjeftiniji) za 15eura nisam ni ocekivao da bude lijep a zacudilo me da i svira kako treba:) a bit ce nesto ljepse kad se bitnije stvari odrade ionako je rijetko kad upaljena glazba samo eto neka se ima da mi ne bode oci rupa od playera :diablo: Link to post Share on other sites
dacha654321 0 Posted January 29, 2009 Report Share Posted January 29, 2009 Prava je shmekerica.... Svaka cast i sve pohvale.... Link to post Share on other sites
