StunterSM 0 Posted February 27, 2017 Author Report Share Posted February 27, 2017 Prednje kocnice od 850i, diskovi 324mm, reparirana klesta sa novim gumicama i nove plocice. Cekam zadnja klesta od 750 e32 isto reparacija, novi diskovi, pakne i plocice. Ici ce i nova kociona creva cisto usput. Dosta radjeno jos, nista slikano Trenutno je test auto za sperove koje proizvodimo sami Link to post Share on other sites
StunterSM 0 Posted March 1, 2017 Author Report Share Posted March 1, 2017 Kruzing, prenos je idealan Link to post Share on other sites
smg 0 Posted March 1, 2017 Report Share Posted March 1, 2017 Super ide sa šperom po snegu Link to post Share on other sites
StunterSM 0 Posted March 1, 2017 Author Report Share Posted March 1, 2017 Ide odlicno, samo da gazda skine levu nogu sa kocnice Link to post Share on other sites
vranjin 0 Posted March 2, 2017 Report Share Posted March 2, 2017 Kako mi se svidja ova radionica u Mitrovici :-) Послато са GT-I9515 уз помоћ Тапатока Link to post Share on other sites
StunterSM 0 Posted March 7, 2017 Author Report Share Posted March 7, 2017 Ispolirane, cekam poklopce sa farbanja. Veceras su felne ofarbane, nemam jos slike Link to post Share on other sites
StunterSM 0 Posted March 8, 2017 Author Report Share Posted March 8, 2017 Link to post Share on other sites
StunterSM 0 Posted March 8, 2017 Author Report Share Posted March 8, 2017 I gume nove cekaju Link to post Share on other sites
StunterSM 0 Posted March 14, 2017 Author Report Share Posted March 14, 2017 Kupljen i zimski set 17. Necemo se voziti vise na 16 zimi A disk popunio 17 Odlicno koce ove kocnice od 850i. Jos poklopci da se ofarbaju i bomba. Za nazad spremam kocnice od 750 ventilirajuce diskove 300mm. Mislim da cu i pancirna creva staviti, a uzeo sam i dupli servo sa vecim cilindrom od v8 sedmice Link to post Share on other sites
BMW_E30 0 Posted March 14, 2017 Report Share Posted March 14, 2017 On 1.3.2017. at 10:01 AM, StunterSM said: Kruzing, prenos je idealan Reci mi ovo što piše na tabli Hour 9.58, jel to opcija koja ide uz veliki bord pa mogu da se listaju podaci sa borda na tabli preko bc ručice? Pošto je meni ista tabla, ali nemam veliki bord i nemam ove podatke na instrument tabli. Link to post Share on other sites
StunterSM 0 Posted March 14, 2017 Author Report Share Posted March 14, 2017 Koji imas bord? Onaj veliki sto fale dugmici ili sat? Link to post Share on other sites
BMW_E30 0 Posted March 14, 2017 Report Share Posted March 14, 2017 Imam samo obican digitalni sat. Link to post Share on other sites
StunterSM 0 Posted March 17, 2017 Author Report Share Posted March 17, 2017 Kad zadrzis dugme na rucici borda pojavibtinse program na displeju, tad ispritiskas na bordu sta sve hoces da imas na displeju. Verovatno informacije uzima sa borda tako da nista tu ne mozes Link to post Share on other sites
KG BMW 0 Posted March 20, 2017 Report Share Posted March 20, 2017 Koji je prenos? Link to post Share on other sites
StunterSM 0 Posted March 20, 2017 Author Report Share Posted March 20, 2017 3.23 na m30 motoru Link to post Share on other sites
KG BMW 0 Posted March 20, 2017 Report Share Posted March 20, 2017 Da ti imas overdrive. Link to post Share on other sites
StunterSM 0 Posted March 20, 2017 Author Report Share Posted March 20, 2017 Manuelac je Link to post Share on other sites
StunterSM 0 Posted April 9, 2017 Author Report Share Posted April 9, 2017 Ofarban zimski set, u potrazi za gumama trenutno Anlaser od m70 v12, malo lepsi zvuk Sekirice u akciji Na kraju malo slow mo video auspuha Link to post Share on other sites
dredger 0 Posted April 10, 2017 Report Share Posted April 10, 2017 Felne su prva liga, ali nisu mi za sedmicu. Nadji negde BBS RS, to je za njega izmisljena felna, to je taj period. Link to post Share on other sites
StunterSM 0 Posted August 12, 2017 Author Report Share Posted August 12, 2017 Stigao Ecu Master DET3 da se izbaci konacno protokomer. Od sad auto radi na map senzor. Sutra cu da ugradim lambda sondu sirokog opsega Bosch 4.9. Mapu sam napravio da radi, sutra fizicki izbacujem protokomer(usko grlo), i zavrsavam mapiranje sa finim podesavanjem sa sondom. Vec lepse radi, na prvo paljenje nema one male oscilacije obrtaja, poteze ostrije. Videcemo sta kaze na merenju kad sve zavrsim Link to post Share on other sites
stevanmil 0 Posted August 13, 2017 Report Share Posted August 13, 2017 Izgleda se sedmica sprema za 300 na sat Link to post Share on other sites
StunterSM 0 Posted August 13, 2017 Author Report Share Posted August 13, 2017 Ipak ce kocka na 450ks Na sedmici samo da izbacim protokomer, i spremam struju od m50 na m30. Da dobijem 6 bobina, da se izbaci razvodna kapa, plus ugradnja senzora bregaste. Sve to moze sa emu stand alone, ali ne bih na nju stand alone da bi mi ostao bord i te gluposti sve.. Link to post Share on other sites
stevanmil 0 Posted August 13, 2017 Report Share Posted August 13, 2017 Taman da vidim kako radi struja m50 sa Det3. Kako koristis sondu sada? Direktno u det3 ide a fabricka sonda i instalacija za sondu se ne koriste? Kako ces da resis senzor bregaste? Uskoro to radis sa strujom od m50? Link to post Share on other sites
StunterSM 0 Posted August 13, 2017 Author Report Share Posted August 13, 2017 Radi kao i sa ovim, besprekorno. Sonda fabricka mi ne treba jer rucno pravim mapu, wide band sondu koristim sa saticem i sa det 3. Za senzor cu da pravim limeni davac i ubusim u deklo od razvodnika. Kroz mesec dana bi trebalo da krenem Link to post Share on other sites
smg 0 Posted August 14, 2017 Report Share Posted August 14, 2017 Da ne budem kao pao sa marsa, a čemu to? Delovalo mi je da je taj auto za uživanje skockan kapiram da ide dovoljno dobro. Link to post Share on other sites
