Neso 0 Posted March 5, 2008 Report Share Posted March 5, 2008 Fino ozračio kako dr. Willy i sone666 rekoše, i sada i nakon divljanja mogu stisnuti crijevo, čak je i pomekano. - čovječe šta je to pričam uglavnom danas sam se malo izdivljao i prestade voda na auspuh. Vjerovatno je bio loš trip. Link to post Share on other sites
gadafi 0 Posted March 5, 2008 Report Share Posted March 5, 2008 neki put hoce svi ti simptomi gusenje nestabilan rad dim iz auspuha trokiranje velika potrosnja od labda sonde Link to post Share on other sites
BMW E36 POWER 0 Posted March 5, 2008 Author Report Share Posted March 5, 2008 sta da kazem osim Vili,ti si brat nas i ponosimo se s tobom... :good: covijek je nevjerovatan i nista mu nije problem,nebi vjerovali to...zahvaljujuci njemu nasi bmw-ovi mirno spavaju...samo sto ICV cisti wd-om a ne u ultrazvucnoj... :hi: Link to post Share on other sites
Neso 0 Posted March 5, 2008 Report Share Posted March 5, 2008 neki put hoce svi ti simptomi gusenje nestabilan rad dim iz auspuha trokiranje velika potrosnja od labda sonde nije povećana potrošnja, troši ko' upaljač. Al brate nesmijem reći koliko, hoćeš da me ubiju! Nego koliko to košta i kako se mijenja? Ili da napravimo poseban topic? Link to post Share on other sites
gadafi 0 Posted March 5, 2008 Report Share Posted March 5, 2008 kosta dosta oko 150 eura i tesko se menja Link to post Share on other sites
Neso 0 Posted March 5, 2008 Report Share Posted March 5, 2008 E ti odmah 150 evra, pomaže li tu brate cocacola ili sirće ili tako nešto. Kako sigurno utvrditi da je neispravna? Link to post Share on other sites
gadafi 0 Posted March 5, 2008 Report Share Posted March 5, 2008 dijagnostikom najlakse ..i ne pomaze nista koliko ja znam samo novo Link to post Share on other sites
gadafi 0 Posted March 5, 2008 Report Share Posted March 5, 2008 coca cola nista sirce nista jedino da ga vozis kod neke babe vracare da mu prebaje :good: Link to post Share on other sites
BMW 528iA 0 Posted March 5, 2008 Report Share Posted March 5, 2008 neki put hoce svi ti simptomi gusenje nestabilan rad dim iz auspuha trokiranje velika potrosnja od labda sonde Da li ste znali da Lambde sonde normalno rade do 120-130 000 km i posle toga samo daju pogresne informacije. Lambda sonda je jedan od faktora koji povecavaju potrosnju a vlasnik nema pojma zbog cega je tako. Link to post Share on other sites
///Misic 0 Posted March 5, 2008 Report Share Posted March 5, 2008 Da li ste znali da Lambde sonde normalno rade do 120-130 000 km i posle toga samo daju pogresne informacije.Lambda sonda je jedan od faktora koji povecavaju potrosnju a vlasnik nema pojma zbog cega je tako. Jel to prijavljuje dijagnostika ako ne radi? Link to post Share on other sites
gadafi 0 Posted March 5, 2008 Report Share Posted March 5, 2008 sva sreca pa je moja crkla ranije tako da sam bio siguran da me ona ne zeza .crkla tu negde oko 135 000 km :good: Link to post Share on other sites
gadafi 0 Posted March 5, 2008 Report Share Posted March 5, 2008 da prijavljuje :good: evo nekih kodova i znacenja usput :hi: ---------BMW Service Codes 10000000 through 19999999 10110005 Cold start Fails to start 10110006 Cold start Long start time 10110009 Cold start Goes out 10110019 Cold start Not running on all cylinders 10110047 Cold start Drop in engine speed 10110070 Cold start Wngine drops in speed too slowly 101100XX Cold start 1011XXXX Cold start 10120005 Hot start - permanent Fails to start 10120005 Hot start Fails to start 10120006 Hot start - permanent Long start time 10120006 Hot start Long start time 10120009 Hot start - permanent Goes out 10120009 Hot start Goes out 10120019 Hot start - permanent Not running on all cylinders 10120019 Hot start Not running on all cylinders 10120047 Hot start - permanent Drop in engine speed 10120047 Hot start Drop in engine speed 10120070 Hot start - permanent Wngine drops in speed too slowly 10120070 Hot start Wngine drops in speed too slowly 101200XX Hot start 101200XX Hot start - permanent 1012XXXX Start in all operating modes 10200120 Switching off when engine cold Not running / overrunning 102001XX Switching off when engine cold 10201120 Switching off when engine hot Not running / overrunning 102011XX Switching off when engine hot 1020XXXX Switching off engine 10310035 Idling quality Uneven running 10310042 Idling quality Misfires / malfunction 103100XX Idling quality 10310124 Idling speed Surge 10310147 Idling speed Drop in engine speed 10310159 Idling speed Too low / deep / slight 10310160 Idling speed Too high 103101XX Idling speed 10310209 Idling at full steering lock Goes out 10310247 Idling at full steering lock Drop in engine speed 103102XX Idling at full steering lock 10310309 Idling while engaging/changing drive range Goes out 10310347 Idling while engaging/changing drive range Drop in engine speed 103103XX Idling while engaging/changing drive range 10310409 Idling while switching A/C unit on/off Goes out 10310447 Idling while switching A/C unit on/off Drop in engine speed 103104XX Idling while switching A/C unit on/off 1031XXXX Idling with cold engine 10320035 Idling quality Uneven running 10320042 Idling quality Misfires / malfunction 103200XX Idling quality 10320124 Idling speed Surge 10320147 Idling speed Drop in engine speed 10320159 Idling speed Too low / deep / slight 10320160 Idling speed Too high 103201XX Idling speed 10320209 Idling with full steering lock Goes out 10320247 Idling with full steering lock Drop in engine speed 103202XX Idling with full steering lock 10320309 Idling while engaging/changing drive range Goes out 10320347 Idling while engaging/changing drive range Drop in engine speed 103203XX Idling while engaging/changing drive range 10320409 Idling while switching A/C unit on/off Goes out 10320447 Idling while switching A/C unit on/off Drop in engine speed 103204XX Idling while switching A/C unit on/off 10329157 E36 M44 Vibration when idling, vibrations in the seat 10329309 E36/7 E46 E53 M54 B30 Engine stalls when steering is turned to full lock/when braking 1032XXXX Idling in all operating modes 10410109 Starting characteristics Goes out 10410147 Starting characteristics Drop in engine speed 104101XX Starting characteristics 10410209 Transition from idle speed after clutch disengagement / neutral range Goes out 10410235 Transition from idle speed after clutch disengagement / neutral range Uneven running 10410247 Transition from idle speed after clutch disengagement / neutral range Drop in engine speed 104102XX Transition from idle speed after clutch disengagement / neutral range 10410338 Acceleration Shaking 10410361 Acceleration Too rough 10410371 Acceleration Retarded / churning 104103XX Acceleration 10410438 Constant driving Shaking 10410442 Constant driving Misfires / malfunction 104104XX Constant driving 10410538 Transition from traction mode to coasting Shaking 10410561 Transition from traction mode to coasting Too rough 104105XX Transition from traction mode to coasting 10410638 Setting off again (coasting at idle) Shaking 10410661 Setting off again (coasting at idle) Too rough 104106XX Setting off again (coasting at idle) 10410770 Shift procedure Wngine drops in speed too slowly 104107XX Shift procedure 10410838 Switching A/C unit on/off Shaking 104108XX Switching A/C unit on/off 1041XXXX Drive characteristics while engine cold 10420109 Starting characteristics Goes out 10420147 Starting characteristics Drop in engine speed 104201XX Starting characteristics 10420209 Transition from idle speed after clutch disengagement / neutral range Goes out 10420235 Transition from idle speed after clutch disengagement / neutral range Uneven running 10420247 Transition from idle speed after clutch disengagement / neutral range Drop in engine speed 104202XX Transition from idle speed after clutch disengagement / neutral range 10420338 Acceleration Shaking 10420361 Acceleration Too rough 10420371 Acceleration Retarded / churning 104203XX Acceleration 10420438 Constant driving Shaking 10420442 Constant driving Misfires / malfunction 104204XX Constant driving 10420538 Transition from traction mode to coasting Shaking 10420561 Transition from traction mode to coasting Too rough 104205XX Transition from traction mode to coasting 10420638 Setting off again (coasting at idle speed) Shaking 10420661 Setting off again (coasting at idle speed) Too rough 104206XX Setting off again (coasting at idle speed) 10420770 Shift procedure Wngine drops in speed too slowly 104207XX Shift procedure 10420838 Switching A/C unit on/off Shaking 104208XX Switching A/C unit on/off 10423059 Maximum speed Too low / deep / slight 104230XX Maximum speed 10423159 Performance Too low / deep / slight 104231XX Performance 10423259 Power when starting Too low / deep / slight 104232XX Power when starting 10423361 Governed top roadspeed Too rough 104233XX Governed top roadspeed 10423461 Governed top engine speed Too rough 104234XX Governed top engine speed 10423539 Acceleration knock Unpleasant noises 104235XX Acceleration knock 10423639 Knock when driving at constant speed Unpleasant noises 104236XX Knock when driving at constant speed 1042XXXX Driving in all operating modes 10500085 Exhaust emission inspection not passed 105000XX Exhaust emission inspection 10501160 Black smoke with cold engine Too high 105011XX Black smoke with cold engine 10501260 Black smoke with hot engine Too high 105012XX Black smoke with hot engine 10501317 Exhaust with cold engine Odour 105013XX Exhaust with cold engine 10501417 Exhaust with hot engine Odour 105014XX Exhaust with hot engine 1050XXXX Exhaust characteristics 10600060 Fuel consumption, general Too high 106000XX Fuel consumption, general 10600160 Fuel consumption over short distances Too high 106001XX Fuel consumption over short distances 1060XXXX Fuel consumption 10700117 Coolant Odour 107001XX Coolant 10700348 Coolant traces on ground / in engine compartment Leaking 107003XX Coolant traces on ground / in engine compartment 10701059 Engine temperature according to temperature display Too low / deep / slight 10701060 Engine temperature according to temperature display Too high 107010XX Engine temperature according to temperature display 1070XXXX Cooling 10800117 Engine oil Odour 108001XX Engine oil 10800260 Oil consumption Too high 108002XX Oil consumption 10800348 Oil traces on ground / in engine compartment Leaking 108003XX Oil traces on ground / in engine compartment 10801087 Oil pressure (although oil level O.K.) warning lamp lights up 108010XX Oil pressure (although oil level O.K.) 1080XXXX Lubrication 10XXXXXX Engine (symptom defect codes) 11110022 Crankcase Manufacturing fault 11110075 Crankcase corroded 111100XX Crankcase 11110537 Reinforcing shell with oil deflector Loose 111105XX Reinforcing shell with oil deflector 11110648 Crankcase, coolant side Leaking 111106XX Crankcase, coolant side 11110748 Crankcase, oil side Leaking 111107XX Crankcase, oil side 11110848 Screw plug in coolant area Leaking 111108XX Screw plug in coolant area 11110948 Screw plug in oil area Leaking 111109XX Screw plug in oil area 11111154 Cylinder barrel Scratches, score marks 11111169 Cylinder barrel Worn / sheared through 111111XX Cylinder barrel 11111201 AL (Aluminium) screw on crankcase/cylinder head cover Cracked / broken / torn off 111112XX AL (Aluminium) screw on crankcase/cylinder head cover 1111XXXX Engine block 11120001 Cylinder head cover Cracked / broken / torn off 111200XX Cylinder head cover 11120148 Cylinder head cover gasket Leaking 111201XX Cylinder head cover gasket 11120201 Cylinder head bolt Cracked / broken / torn off 11120223 Cylinder head bolt Incorrect / not fitted 11120237 Cylinder head bolt Loose 111202XX Cylinder head bolt 11120301 Cylinder head Cracked / broken / torn off 11120332 Cylinder head Deformed / distorted / bent 111203XX Cylinder head 11120621 Valve guide Worn 111206XX Valve guide 11120737 Valve seat ring Loose 11120769 Valve seat ring Worn / sheared through 111207XX Valve seat ring 11120948 Heater connection at cylinder head Leaking 111209XX Heater connection at cylinder head 11121316 Burner insert (diesel) Broken off 11121337 Burner insert (diesel) Loose 111213XX Burner insert (diesel) 11121448 Cylinder head, coolant side Leaking 111214XX Cylinder head, coolant side 11121548 Cylinder head, oil side Leaking 111215XX Cylinder head, oil side 11121648 Cylinder head gasket, coolant side Leaking 111216XX Cylinder head gasket, coolant side 11121748 Cylinder head gasket, oil side Leaking 111217XX Cylinder head gasket, oil side 11121837 Cylinder head oil filler cover Loose 11121848 Cylinder head oil filler cover Leaking 111218XX Cylinder head oil filler cover 11121948 Cylinder head cover, spark plug well Leaking 111219XX Cylinder head cover, spark plug well 11122232 Ignition coil cover Deformed / distorted / bent 111222XX Ignition coil cover 11122314 Non-return valve for VANOS Occasional malfunction 11122315 Non-return valve for VANOS Permanent malfunction 111223XX Non-return valve for VANOS 11122448 Check valve for cylinder head oil supply Leaking 111224XX Check valve for cylinder head oil supply 11122513 Cam carrier Broken 111225XX Cam carrier 11125001 Cylinder head-timing case (M-model) Cracked / broken / torn off 11125048 Cylinder head-timing case (M-model) Leaking 111250XX Cylinder head-timing case (M-model) 11129148 E36/7 E38 E39 E46 M52TU cylinder head, leak in coolant area 11129239 E53 E60 E65 E66 N62 Whistling noise from engine (pressure control valve) 1112XXXX Cylinder head with cover 11130001 Oil sump Cracked / broken / torn off 11130037 Oil sump Loose 111300XX Oil sump 11130148 Oil sump gasket, top Leaking 111301XX Oil sump gasket, top 11130248 Oil sump gasket, bottom (V-engines) Leaking 111302XX Oil sump gasket, bottom (V-engines) 11130348 Oil drain plug Leaking 111303XX Oil drain plug 11130411 Oil circuit changeover valve (M-models) Occasional failure 11130412 Oil circuit changeover valve (M-models) Permanent failure 111304XX Oil circuit changeover valve (M-models) 11131001 Oil pan, two-piece (V-engines, M-engines) Cracked / broken / torn off 11131037 Oil pan, two-piece (V-engines, M-engines) Loose 111310XX Oil pan, two-piece (V-engines, M-engines) 11139204 E52 Oil drain plug leaking/too short 1113XXXX Oil sump 11140048 Timing case cover, top Leaking 111400XX Timing case cover, top 11140148 Timing case cover, bottom Leaking 111401XX Timing case cover, bottom 11140248 End cover on crankcase Leaking 111402XX End cover on crankcase 11140348 Rotary shaft seal (pulley side) Leaking 111403XX Rotary shaft seal (pulley side) 11140448 Rotary shaft seal (clutch side) Leaking 111404XX Rotary shaft seal (clutch side) 11140748 End cover, top/displacer (V-engines) Leaking 111407XX End cover, top/displacer (V-engines) 11141137 Transmission cover plate Loose 11141178 Transmission cover plate poor surface finish 111411XX Transmission cover plate 1114XXXX Housing cover 11150048 Engine breather lines Leaking 111500XX Engine breather lines 11150314 Valve for crankcase venting Occasional malfunction 11150315 Valve for crankcase venting Permanent malfunction 11150339 Valve for crankcase venting Unpleasant noises 11150348 Valve for crankcase venting Leaking 111503XX Valve for crankcase venting 11150412 Heating for crankcase ventilation lines Permanent failure 111504XX Heating for crankcase ventilation lines 11150512 Heater for oil separator Permanent failure 111505XX Heater for oil separator 11159169 E36/7 E39 E46 M52/TU Crankcase ventilation line worn 1115XXXX Housing ventilation 11210013 Crankshaft Broken 11210099 Crankshaft Fault code stored in diagnosis fault code memory (no warning lamp) 112100XX Crankshaft 11210269 Crankshaft chain sprocket Worn / sheared through 112102XX Crankshaft chain sprocket 11210428 Deep-groove ball bearing in crankshaft Seized 11210439 Deep-groove ball bearing in crankshaft Unpleasant noises 112104XX Deep-groove ball bearing in crankshaft 11210728 Axial crankshaft bearing Seized 11210731 Axial crankshaft bearing Excessive play 112107XX Axial crankshaft bearing 11210828 Radial crankshaft bearing Seized 11210831 Radial crankshaft bearing Excessive play 112108XX Radial crankshaft bearing 11210937 Crankshaft on main bearing shell cover Loose 112109XX Crankshaft on main bearing shell cover 11211514 Pulse generator wheel on crankshaft Occasional malfunction 11211515 Pulse generator wheel on crankshaft Permanent malfunction 11211599 Pulse generator wheel on crankshaft Fault code stored in diagnosis fault code memory (no 112115XX Pulse generator wheel on crankshaft 1121XXXX Crankshaft with bearing 11220001 Flywheel Cracked / broken / torn off 11220026 Flywheel Grooved 11220037 Flywheel Loose 11220039 Flywheel Unpleasant noises 11220048 Flywheel Leaking 112200XX Flywheel 11220116 Ring gear Broken off 11220137 Ring gear Loose 112201XX Ring gear 11220201 Driving disc for automatic transmission Cracked / broken / torn off 11220237 Driving disc for automatic transmission Loose 11220239 Driving disc for automatic transmission Unpleasant noises 112202XX Driving disc for automatic transmission 11220439 Flywheel with damper for E-CVT Unpleasant noises 11220448 Flywheel with damper for E-CVT Leaking 11220456 Flywheel with damper for E-CVT Poor running characteristics / friction 112204XX Flywheel with damper for E-CVT 1122XXXX Flywheel 11230001 Vibration damper (crankshaft) Cracked / broken / torn off 11230021 Vibration damper (crankshaft) Worn 11230037 Vibration damper (crankshaft) Loose 112300XX Vibration damper (crankshaft) 1123XXXX Vibration damper 11240013 Connecting rod Broken 11240032 Connecting rod Deformed / distorted / bent 112400XX Connecting rod 11240169 Connecting rod bearing shells Worn / sheared through 112401XX Connecting rod bearing shells 1124XXXX Connecting rod with bearing 11250028 Piston Seized 11250039 Piston Unpleasant noises 11250051 Piston Burnt/burnt through 11250054 Piston Scratches, score marks 11250078 Piston poor surface finish 112500XX Piston 11250137 Piston pin Loose 112501XX Piston pin 11250213 Piston rings Broken 11250269 Piston rings Worn / sheared through 112502XX Piston rings 11250413 Piston cooling, oil spray nozzle Broken 112504XX Piston cooling, oil spray nozzle 1125XXXX Piston with rings and pins 11270126 Counterbalance shafts Grooved 11270137 Counterbalance shafts Loose 11270139 Counterbalance shafts Unpleasant noises 112701XX Counterbalance shafts 1127XXXX Counterbalance shaft 11280113 Belt tensioner Broken 11280139 Belt tensioner Unpleasant noises 11280148 Belt tensioner Leaking 112801XX Belt tensioner 11280201 Ribbed V-belt, main drive Cracked / broken / torn off 11280237 Ribbed V-belt, main drive Loose 11280239 Ribbed V-belt, main drive Unpleasant noises 11280276 Ribbed V-belt, main drive dirty / blocked 112802XX Ribbed V-belt, main drive 11280301 Ribbed V-belt, A/C compressor Cracked / broken / torn off 11280337 Ribbed V-belt, A/C compressor Loose 11280339 Ribbed V-belt, A/C compressor Unpleasant noises 11280369 Ribbed V-belt, A/C compressor Worn / sheared through 11280376 Ribbed V-belt, A/C compressor dirty / blocked 112803XX Ribbed V-belt, A/C compressor 11280413 Belt pulley for crankshaft Broken 11280423 Belt pulley for crankshaft Incorrect / not fitted 11280432 Belt pulley for crankshaft Deformed / distorted / bent 11280437 Belt pulley for crankshaft Loose 112804XX Belt pulley for crankshaft 11280513 Belt pulley for water pump Broken 11280523 Belt pulley for water pump Incorrect / not fitted 11280532 Belt pulley for water pump Deformed / distorted / bent 11280537 Belt pulley for water pump Loose 112805XX Belt pulley for water pump 11280613 Belt pulley for alternator Broken 11280623 Belt pulley for alternator Incorrect / not fitted 11280632 Belt pulley for alternator Deformed / distorted / bent 11280637 Belt pulley for alternator Loose 112806XX Belt pulley for alternator 11280713 Deflection pulley for ribbed V-belt Broken 11280737 Deflection pulley for ribbed V-belt Loose 11280739 Deflection pulley for ribbed V-belt Unpleasant noises 112807XX Deflection pulley for ribbed V-belt 11280813 Tension pulley for ribbed V-belt Broken 11280837 Tension pulley for ribbed V-belt Loose 11280839 Tension pulley for ribbed V-belt Unpleasant noises 112808XX Tension pulley for ribbed V-belt 11280913 Pulley for A/C compressor drive Broken 11280932 Pulley for A/C compressor drive Deformed / distorted / bent 11280937 Pulley for A/C compressor drive Loose 112809XX Pulley for A/C compressor drive 11281001 A/C compressor carrier with tensioning device Cracked / broken / torn off 11281037 A/C compressor carrier with tensioning device Loose 112810XX A/C compressor carrier with tensioning device 1128XXXX Ribbed V-belt with tensioner and deflector 11310026 Camshaft Grooved 11310028 Camshaft Seized 113100XX Camshaft 11310137 Camshaft chain sprocket / VANOS Loose 11310169 Camshaft chain sprocket / VANOS Worn / sheared through 113101XX Camshaft chain sprocket / VANOS 11310237 Flanger for chain sprocket Loose 113102XX Flanger for chain sprocket 11310301 Timing chain Cracked / broken / torn off 11310339 Timing chain Unpleasant noises 11310369 Timing chain Worn / sheared through 113103XX Timing chain 11310439 Chain tensioner, camshaft Unpleasant noises 11310448 Chain tensioner, camshaft Leaking 11310469 Chain tensioner, camshaft Worn / sheared through 113104XX Chain tensioner, camshaft 11310613 Tensioning rail, camshaft Broken 11310626 Tensioning rail, camshaft Grooved 113106XX Tensioning rail, camshaft 11310713 Guide rail, camshaft Broken 11310726 Guide rail, camshaft Grooved 113107XX Guide rail, camshaft 11310813 Gear wheels on camshaft Broken 11310839 Gear wheels on camshaft Unpleasant noises 113108XX Gear wheels on camshaft 11311628 Camshaft bearing Seized 113116XX Camshaft bearing 11311769 Camshaft cam Worn / sheared through 113117XX Camshaft cam 11311814 Pulse generator wheel, camshaft sensor Occasional malfunction 11311815 Pulse generator wheel, camshaft sensor Permanent malfunction 11311837 Pulse generator wheel, camshaft sensor Loose 113118XX Pulse generator wheel, camshaft sensor 11311913 Slide rail between camshafts Broken 11311926 Slide rail between camshafts Grooved 113119XX Slide rail between camshafts 11312013 Cam ring, camshaft Broken 11312037 Cam ring, camshaft Loose 11312069 Cam ring, camshaft Worn / sheared through 113120XX Cam ring, camshaft 1131XXXX Camshaft 11330113 Rocker arm/finger/roller-type finger with shaft Broken 11330126 Rocker arm/finger/roller-type finger with shaft Grooved 11330131 Rocker arm/finger/roller-type finger with shaft Excessive play 11330137 Rocker arm/finger/roller-type finger with shaft Loose 11330139 Rocker arm/finger/roller-type finger with shaft Unpleasant noises 113301XX Rocker arm/finger/roller-type finger with shaft 11330439 Hydraulic tappet clearance compensation Unpleasant noises 113304XX Hydraulic tappet clearance compensation 11330701 Hydr. valve clearance adjuster bearing strip Cracked / broken / torn off 11330726 Hydr. valve clearance adjuster bearing strip Grooved 113307XX Hydr. valve clearance adjuster bearing strip 11330869 Bucket tappet Worn / sheared through 113308XX Bucket tappet 1133XXXX Rocker arm/finger with bearing 11340001 Inlet valve Cracked / broken / torn off 11340029 Inlet valve Sticking/jammed 11340048 Inlet valve Leaking 11340076 Inlet valve dirty / blocked 113400XX Inlet valve 11340101 Exhaust valve Cracked / broken / torn off 11340129 Exhaust valve Sticking/jammed 11340148 Exhaust valve Leaking 11340176 Exhaust valve dirty / blocked 113401XX Exhaust valve 11340201 Valve spring plate Cracked / broken / torn off 113402XX Valve spring plate 11340313 Valve spring Broken 113403XX Valve spring 11340648 Valve stem seal Leaking 113406XX Valve stem seal 11340701 Valve tapers Cracked / broken / torn off 11340723 Valve tapers Incorrect / not fitted 113407XX Valve tapers 1134XXXX Valves with springs 11360129 Camshaft adjusting unit (VANOS) Sticking/jammed 11360137 Camshaft adjusting unit (VANOS) Loose 11360139 Camshaft adjusting unit (VANOS) Unpleasant noises 11360148 Camshaft adjusting unit (VANOS) Leaking 11360169 Camshaft adjusting unit (VANOS) Worn / sheared through 11360183 Camshaft adjusting unit (VANOS) incorrect or no switching action 11360196 Camshaft adjusting unit (VANOS) Fault code in diagnosis memory (warn. lamp on) 11360199 Camshaft adjusting unit (VANOS) Fault code stored in diagnosis fault code memory (no warning 113601XX Camshaft adjusting unit (VANOS) 11360212 Solenoid valve for camshaft adjusting unit Permanent failure 11360229 Solenoid valve for camshaft adjusting unit Sticking/jammed 11360248 Solenoid valve for camshaft adjusting unit Leaking 11360276 Solenoid valve for camshaft adjusting unit dirty / blocked 11360296 Solenoid valve for camshaft adjusting unit Fault code in diagnosis memory (warn. lamp on) 11360299 Solenoid valve for camshaft adjusting unit Fault code stored in diagnosis fault code memory 113602XX Solenoid valve for camshaft adjusting unit 11360301 Oil line for camshaft adjusting unit Cracked / broken / torn off 11360348 Oil line for camshaft adjusting unit Leaking 113603XX Oil line for camshaft adjusting unit 11360469 Oil distributor, VANOS Worn / sheared through 113604XX Oil distributor, VANOS 11360548 Pressure accumulator (incl. shut-off valve) VANOS Leaking 11360579 Pressure accumulator (incl. shut-off valve) VANOS incorrect connection /contact 113605XX Pressure accumulator (incl. shut-off valve) VANOS 11369239 E39 E52 S62 VANOS gear mechanism, noise while starting 1136XXXX Camshaft adjustment (VANOS) 11370113 Eccentric shaft, Valvetronic Broken 11370129 Eccentric shaft, Valvetronic Sticking/jammed 113701XX Eccentric shaft, Valvetronic 11370213 Eccentric shaft spline, Valvetronic Broken 11370269 Eccentric shaft spline, Valvetronic Worn / sheared through 113702XX Eccentric shaft spline, Valvetronic 11370313 Intermediate lever retaining spring, Valvetronic Broken 11370369 Intermediate lever retaining spring, Valvetronic Worn / sheared through 113703XX Intermediate lever retaining spring, Valvetronic 11370413 Intermediate lever, Valvetronic Broken 11370469 Intermediate lever, Valvetronic Worn / sheared through 113704XX Intermediate lever, Valvetronic 11370513 Torque compensation spring, Valvetronic Broken 11370569 Torque compensation spring, Valvetronic Worn / sheared through 113705XX Torque compensation spring, Valvetronic 11370613 Support for torque compensation spring, Valvetronic Broken 11370637 Support for torque compensation spring, Valvetronic Loose 11370669 Support for torque compensation spring, Valvetronic Worn / sheared through 113706XX Support for torque compensation spring, Valvetronic 11370713 Valvetronic sensor Broken 11370737 Valvetronic sensor Loose 11370796 Valvetronic sensor Fault code in diagnosis memory (warn. lamp on) 11370799 Valvetronic sensor Fault code stored in diagnosis fault code memory (no warning lamp) 113707XX Valvetronic sensor 11370813 Valvetronic sensor connector Broken 113708XX Valvetronic sensor connector 11370937 Electric actuator, Valvetronic eccentric shaft Loose 11370948 Electric actuator, Valvetronic eccentric shaft Leaking 11370996 Electric actuator, Valvetronic eccentric shaft Fault code in diagnosis memory (warn. lamp 11370999 Electric actuator, Valvetronic eccentric shaft Fault code stored in diagnosis fault code 113709XX Electric actuator, Valvetronic eccentric shaft 11371013 Worm, Valvetronic electric actuator Broken 11371069 Worm, Valvetronic electric actuator Worn / sheared through 113710XX Worm, Valvetronic electric actuator 11371111 Component, Valvetronic control unit Occasional failure 11371112 Component, Valvetronic control unit Permanent failure 113711XX Component, Valvetronic control unit 11371213 Magnet sensor wheel, Valvetronic Broken 11371237 Magnet sensor wheel, Valvetronic Loose 113712XX Magnet sensor wheel, Valvetronic 11371428 Eccentric shaft bearing Seized 11371431 Eccentric shaft bearing Excessive play 113714XX Eccentric shaft bearing 11371537 Gate for intermediate lever, Valvetronic Loose 11371569 Gate for intermediate lever, Valvetronic Worn / sheared through 113715XX Gate for intermediate lever, Valvetronic 11379002 E46 N42 Valvetronic control unit output stage fault 1137XXXX Variable valve timing gear 11410039 Oil pump Unpleasant noises 114100XX Oil pump 11410137 Oil pump chain sprocket Loose 11410139 Oil pump chain sprocket Unpleasant noises 11410169 Oil pump chain sprocket Worn / sheared through 114101XX Oil pump chain sprocket 11410201 Drive or chain for oil pump Cracked / broken / torn off 114102XX Drive or chain for oil pump 11410713 Chain tensioning rail for oil pump sprocket Broken 11410737 Chain tensioning rail for oil pump sprocket Loose 11410739 Chain tensioning rail for oil pump sprocket Unpleasant noises 114107XX Chain tensioning rail for oil pump sprocket 11410837 Sprocket, vacuum unit Loose 11410839 Sprocket, vacuum unit Unpleasant noises 11410869 Sprocket, vacuum unit Worn / sheared through 114108XX Sprocket, vacuum unit 1141XXXX Oil pump with screen and drive 11420037 Full-flow filter body Loose 11420048 Full-flow filter body Leaking 114200XX Full-flow filter body 11420237 Oil line for rocker arm / finger Loose 11420248 Oil line for rocker arm / finger Leaking 114202XX Oil line for rocker arm / finger 11421148 Oil hoses to oil filter Leaking 114211XX Oil hoses to oil filter 1142XXXX Oil filter and lines 11430001 Dipstick Cracked / broken / torn off 11430023 Dipstick Incorrect / not fitted 11430048 Dipstick Leaking 114300XX Dipstick 11430148 Oil dipstick guide tube Leaking 114301XX Oil dipstick guide tube 11430213 Holder for oil dipstick guide tube Broken 11430237 Holder for oil dipstick guide tube Loose 114302XX Holder for oil dipstick guide tube 11439218 E65 E66 N62 Engine oil level shown on dipstick incorrect 1143XXXX Oil fill and dipstick bores 11440101 Engine oil - coolant heat exchanger Cracked / broken / torn off 11440148 Engine oil - coolant heat exchanger Leaking 114401XX Engine oil - coolant heat exchanger 1144XXXX Oil cooler with inlet and outlet line 11510115 Coolant pump Permanent malfunction 11510139 Coolant pump Unpleasant noises 11510148 Coolant pump Leaking 115101XX Coolant pump 11519148 E65 N62 Water pump coolant outlet 1151XXXX Water pump with drive 11520013 Fan blades Broken 11520039 Fan blades Unpleasant noises 115200XX Fan blades 11520114 Fan clutch (mechanical) Occasional malfunction 11520115 Fan clutch (mechanical) Permanent malfunction 11520139 Fan clutch (mechanical) Unpleasant noises 11520148 Fan clutch (mechanical) Leaking 115201XX Fan clutch (mechanical) 1152XXXX Fan 11530032 Thermostat housing Deformed / distorted / bent 11530048 Thermostat housing Leaking 115300XX Thermostat housing 11530114 Thermostat Occasional malfunction 11530115 Thermostat Permanent malfunction 11530179 Thermostat incorrect connection /contact 115301XX Thermostat 11531212 Characteristic map thermostat, heating Permanent failure 11531296 Characteristic map thermostat, heating Fault code in diagnosis memory (warn. lamp on) 11531299 Characteristic map thermostat, heating Fault code stored in diagnosis fault code memory 115312XX Characteristic map thermostat, heating 11531348 Coolant return pipe Leaking 11531375 Coolant return pipe corroded 115313XX Coolant return pipe 1153XXXX Thermostat and engine-mounted coolant lines 11610379 Electric motor, individual control intake system (DISA) incorrect connection /contact 11610396 Electric motor, individual control intake system (DISA) Fault code in diagnosis memory (11610399 Electric motor, individual control intake system (DISA) Fault code stored in diagnosis fault 116103XX Electric motor, individual control intake system (DISA) 11610429 Differentiated fully variable intake system DIVA Sticking/jammed 11610439 Differentiated fully variable intake system DIVA Unpleasant noises 11610448 Differentiated fully variable intake system DIVA Leaking 116104XX Differentiated fully variable intake system DIVA 11610579 Actuator (incl. sensor) DIVA incorrect connection /contact 11610596 Actuator (incl. sensor) DIVA Fault code in diagnosis memory (warn. lamp on) 11610599 Actuator (incl. sensor) DIVA Fault code stored in diagnosis fault code memory (no warning 116105XX Actuator (incl. sensor) DIVA 11611237 Intake manifold Loose 11611239 Intake manifold Unpleasant noises 11611248 Intake manifold Leaking 116112XX Intake manifold 11611948 Decoupling flange between cylinder head and intake manifold Leaking 116119XX Decoupling flange between cylinder head and intake manifold 11612037 Vacuum hose, DISA flap valve Loose 11612048 Vacuum hose, DISA flap valve Leaking 116120XX Vacuum hose, DISA flap valve 11612111 Solenoid valve for intake manifold (DISA) Occasional failure 11612112 Solenoid valve for intake manifold (DISA) Permanent failure 116121XX Solenoid valve for intake manifold (DISA) 11612239 DISA flap/sliding sleeves Unpleasant noises 11612248 DISA flap/sliding sleeves Leaking 11612283 DISA flap/sliding sleeves incorrect or no switching action 11612296 DISA flap/sliding sleeves Fault code in diagnosis memory (warn. lamp on) 11612299 DISA flap/sliding sleeves Fault code stored in diagnosis fault code memory (no warning lamp) 116122XX DISA flap/sliding sleeves 11612315 Air shut-off valve, suction jet pump Permanent malfunction 116123XX Air shut-off valve, suction jet pump 11612437 Swirl flap Loose 11612483 Swirl flap incorrect or no switching action 116124XX Swirl flap 11612583 Swirl flap changeover valve incorrect or no switching action 11612584 Swirl flap changeover valve incorrect electrical resistance 116125XX Swirl flap changeover valve 11612615 Suction jet pump for brake booster Permanent malfunction 11612648 Suction jet pump for brake booster Leaking 116126XX Suction jet pump for brake booster 11619167 E53 M62 Heating sleeve for crankcase breather 1161XXXX Intake manifold 11620001 Exhaust manifold Cracked / broken / torn off 11620032 Exhaust manifold Deformed / distorted / bent 11620039 Exhaust manifold Unpleasant noises 11620048 Exhaust manifold Leaking 116200XX Exhaust manifold 11620101 Heat shield for exhaust manifold Cracked / broken / torn off 11620101 Heat shield, exhaust manifold Cracked / broken / torn off 11620137 Heat shield for exhaust manifold Loose 11620137 Heat shield, exhaust manifold Loose 11620139 Heat shield for exhaust manifold Unpleasant noises 11620139 Heat shield, exhaust manifold Unpleasant noises 116201XX Heat shield for exhaust manifold 116201XX Heat shield, exhaust manifold 11620301 Stud bolts for exhaust manifold Cracked / broken / torn off 11620301 Studs for exhaust manifold Cracked / broken / torn off 11620337 Stud bolts for exhaust manifold Loose 11620337 Studs for exhaust manifold Loose 116203XX Stud bolts for exhaust manifold 116203XX Studs for exhaust manifold 11620448 Exhaust manifold gasket, cylinder head end Leaking 11620448 Exhaust manifold gasket, cylinder head side Leaking 116204XX Exhaust manifold gasket, cylinder head end 116204XX Exhaust manifold gasket, cylinder head side 11629039 E36/7 E39 E46 M54 RHD gasket with heat shield for exhaust manifold whirring noise 1162XXXX Exhaust manifold 11642637 Interference air valve - exhaust inspection Loose 11642648 Interference air valve - exhaust inspection Leaking 116426XX Interference air valve - exhaust inspection 1164XXXX Exhaust control unit 11650528 Exhaust turbocharger (ATL) Seized 11650531 Exhaust turbocharger (ATL) Excessive play 11650539 Exhaust turbocharger (ATL) Unpleasant noises 11650583 Exhaust turbocharger (ATL) incorrect or no switching action 116505XX Exhaust turbocharger (ATL) 11651848 Oil pipe, exhaust turbocharger (ATL) Leaking 116518XX Oil pipe, exhaust turbocharger (ATL) 11651914 Charge pressure regulation Occasional malfunction 11651915 Charge pressure regulation Permanent malfunction 116519XX Charge pressure regulation 11652048 Vacuum accumulator for exhaust turbocharger Leaking 116520XX Vacuum accumulator for exhaust turbocharger 11652111 Solenoid valve for exhaust turbocharger Occasional failure 11652112 Solenoid valve for exhaust turbocharger Permanent failure 11652183 Solenoid valve for exhaust turbocharger incorrect or no switching action 116521XX Solenoid valve for exhaust turbocharger 11652276 Filter EPDW exhaust turbocharger dirty / blocked 116522XX Filter EPDW exhaust turbocharger 11652329 EPDW boost pressure regulator Sticking/jammed 11652384 EPDW boost pressure regulator incorrect electrical resistance 116523XX EPDW boost pressure regulator 11652428 Compressor (mechanical supercharger) Seized 11652439 Compressor (mechanical supercharger) Unpleasant noises 11652448 Compressor (mechanical supercharger) Leaking 116524XX Compressor (mechanical supercharger) 11659015 E46 M47/TU Exhaust turbocharger failed 1165XXXX Turbocharger with control 11660011 Vacuum pump (diesel) Occasional failure 11660011 Vacuum pump Occasional failure 11660012 Vacuum pump (diesel) Permanent failure 11660012 Vacuum pump Permanent failure 11660039 Vacuum pump (diesel) Unpleasant noises 11660039 Vacuum pump Unpleasant noises 11660048 Vacuum pump (diesel) Leaking 11660048 Vacuum pump Leaking 116600XX Vacuum pump 116600XX Vacuum pump (diesel) 11660248 Vacuum lines Leaking 11660276 Vacuum lines dirty / blocked 11660279 Vacuum lines incorrect connection /contact 116602XX Vacuum lines 1166XXXX Vacuum pump 11710148 Exhaust gas recirculation valve (EGR) Leaking 11710176 Exhaust gas recirculation valve (EGR) dirty / blocked 11710183 Exhaust gas recirculation valve (EGR) incorrect or no switching action 117101XX Exhaust gas recirculation valve (EGR) 11710348 EGR valve, valve seat Leaking 117103XX EGR valve, valve seat 11710576 Filter electropneumatic pressure converter EPDW EGR dirty / blocked 117105XX Filter electropneumatic pressure converter EPDW EGR 11710601 EGR cooling Cracked / broken / torn off 11710637 EGR cooling Loose 11710648 EGR cooling Leaking 11710676 EGR cooling dirty / blocked 117106XX EGR cooling 11710729 Electropneumatic pressure converter EPDW for EGR Sticking/jammed 11710784 Electropneumatic pressure converter EPDW for EGR incorrect electrical resistance 117107XX Electropneumatic pressure converter EPDW for EGR 11710801 EGR pipe Cracked / broken / torn off 11710848 EGR pipe Leaking 117108XX EGR pipe 11710911 Throttle valve for EGR Occasional failure 11710912 Throttle valve for EGR Permanent failure 11710934 Throttle valve for EGR Stiff to move 11710948 Throttle valve for EGR Leaking 117109XX Throttle valve for EGR 1171XXXX Exhaust gas recirculation (EGR) 11720211 Air pump Occasional failure 11720212 Air pump Permanent failure 11720239 Air pump Unpleasant noises 11720296 Air pump Fault code in diagnosis memory (warn. lamp on) 11720299 Air pump Fault code stored in diagnosis fault code memory (no warning lamp) 117202XX Air pump 11720376 Air filter, secondary air pump dirty / blocked 117203XX Air filter, secondary air pump 11720401 Secondary air line (manifold up to valve) Cracked / broken / torn off 11720448 Secondary air line (manifold up to valve) Leaking 117204XX Secondary air line (manifold up to valve) 11720514 Electric changeover valve, secondary air system Occasional malfunction 11720515 Electric changeover valve, secondary air system Permanent malfunction 11720537 Electric changeover valve, secondary air system Loose 11720548 Electric changeover valve, secondary air system Leaking 11720596 Electric changeover valve, secondary air system Fault code in diagnosis memory (warn. lamp 11720599 Electric changeover valve, secondary air system Fault code stored in diagnosis fault code 117205XX Electric changeover valve, secondary air system 11720615 Shut-off valve (return flow shut-off valve) Permanent malfunction 11720648 Shut-off valve (return flow shut-off valve) Leaking 117206XX Shut-off valve (return flow shut-off valve) 11720737 Intake line (between filter and pump) Loose 11720748 Intake line (between filter and pump) Leaking 117207XX Intake line (between filter and pump) 11720837 Delivery line (between pump and shut-off valve) Loose 11720848 Delivery line (between pump and shut-off valve) Leaking 117208XX Delivery line (between pump and shut-off valve) 11720937 Vacuum line between electric changeover valve and shut-off valve (petrol engine) Loose 11720948 Vacuum line between electric changeover valve and shut-off valve (petrol engine) Leaking 117209XX Vacuum line between electric changeover valve and shut-off valve (petrol engine) 11721048 Vacuum accumulator Leaking 11721048 Vacuum reservoir, secondary air system Leaking 117210XX Vacuum accumulator 117210XX Vacuum reservoir, secondary air system 11721114 Mass air flow sensor HFM for secondary air system Occasional malfunction 11721115 Mass air flow sensor HFM for secondary air system Permanent malfunction 11721176 Mass air flow sensor HFM for secondary air system dirty / blocked 117211XX Mass air flow sensor HFM for secondary air system 11729288 E46 N42 Removal or deactivation of secondary air pump 11729476 1172XXXX Air pump, lines and control valves 11780214 Oxygen control sensor (before catalytic converter) Occasional malfunction 11780215 Oxygen control sensor (before catalytic converter) Permanent malfunction 11780279 Oxygen control sensor (before catalytic converter) incorrect connection /contact 11780296 Oxygen control sensor (before catalytic converter) Fault code in diagnosis memory (warn. 11780299 Oxygen control sensor (before catalytic converter) Fault code stored in diagnosis fault 117802XX Oxygen control sensor (before catalytic converter) 11780314 Oxygen monitor sensor Occasional malfunction 11780315 Oxygen monitor sensor Permanent malfunction 11780379 Oxygen monitor sensor incorrect connection /contact 11780396 Oxygen monitor sensor Fault code in diagnosis memory (warn. lamp on) 11780399 Oxygen monitor sensor Fault code stored in diagnosis fault code memory (no warning lamp) 117803XX Oxygen monitor sensor 11780411 Exhaust temperature sensor Occasional failure 11780412 Exhaust temperature sensor Permanent failure 11780413 Exhaust temperature sensor Broken 11780437 Exhaust temperature sensor Loose 11780496 Exhaust temperature sensor Fault code in diagnosis memory (warn. lamp on) 11780499 Exhaust temperature sensor Fault code stored in diagnosis fault code memory (no warning 117804XX Exhaust temperature sensor 11789346 E39 E52 S62 Exhaust gas temperature sensor - dispensed with 1178XXXX Exhaust control units 11XXXXXX Engine 12110029 Distributor Sticking/jammed 12110040 Distributor Poorly adjusted / outside tolerance 121100XX Distributor 12110201 Distributor cap / connections Cracked / broken / torn off 12110251 Distributor cap / connections Burnt/burnt through 121102XX Distributor cap / connections 12110613 Distributor rotor Broken 12110651 Distributor rotor Burnt/burnt through 121106XX Distributor rotor 1211XXXX Ignition, ignition distributor, circuit breaker 12120014 Spark plugs Occasional malfunction 12120015 Spark plugs Permanent malfunction 121200XX Spark plugs 12120182 Ignition leads arcing over 121201XX Ignition leads 12120237 Spark plug caps Loose 12120282 Spark plug caps arcing over 121202XX Spark plug caps 12120337 Angled plug (distributor cap + coil) Loose 12120382 Angled plug (distributor cap + coil) arcing over 121203XX Angled plug (distributor cap + coil) 1212XXXX Ignition harness, spark plugs 12130011 Ignition coil Occasional failure 12130012 Ignition coil Permanent failure 12130037 Ignition coil Loose 12130099 Ignition coil Fault code stored in diagnosis fault code memory (no warning lamp) 121300XX Ignition coil 12139112 E36/7 E46 E39 E53 Ignition coils fail (Bremi) 12139112 E36/7 E46 Ignition coils fail (Bremi) 12139184 E65 E66 N62 Ignition coils (Bremi) fail 12139212 E46 E53 E65 E66 E67 E83 E85 Misfiring - ignition coils (Bremi) fail 1213XXXX Ignition coil 12140814 Knock sensor Occasional malfunction 12140815 Knock sensor Permanent malfunction 12140837 Knock sensor Loose 12140896 Knock sensor Fault code in diagnosis memory (warn. lamp on) 12140899 Knock sensor Fault code stored in diagnosis fault code memory (no warning lamp) 121408XX Knock sensor 12140914 Differential pressure sensors (Cooper S) Occasional malfunction 12140915 Differential pressure sensors (Cooper S) Permanent malfunction 121409XX Differential pressure sensors (Cooper S) 12141014 Pulse generator, crankshaft Occasional malfunction 12141015 Pulse generator, crankshaft Permanent malfunction 12141037 Pulse generator, crankshaft Loose 12141096 Pulse generator, crankshaft Fault code in diagnosis memory (warn. lamp on) 12141099 Pulse generator, crankshaft Fault code stored in diagnosis fault code memory (no warning 121410XX Pulse generator, crankshaft 12141114 Pulse generator, camshaft Occasional malfunction 12141115 Pulse generator, camshaft Permanent malfunction 12141137 Pulse generator, camshaft Loose 12141196 Pulse generator, camshaft Fault code in diagnosis memory (warn. lamp on) 12141199 Pulse generator, camshaft Fault code stored in diagnosis fault code memory (no warning lamp) 121411XX Pulse generator, camshaft 12141511 Component, DME control unit Occasional failure 12141512 Component, DME control unit Permanent failure 12141523 Component, DME control unit Incorrect / not fitted 12141537 Component, DME control unit Loose 12141550 Component, DME control unit Water ingress / condensate 121415XX Component, DME control unit 12141715 Control unit for electrically heated catalytic converter Permanent malfunction 121417XX Control unit for electrically heated catalytic converter 12149009 E38 E39 M62 Air conditioning switches off during acceleration - DME reprogramming 12149047 R50 Dip in engine speed during gearshift (program DME) 12149105 E38 E39 E53 M62TU Engine will not start - FC 164 12149125 E36/7 E46 S54 Rough engine operation after cold start (program DME) 12149147 R50 R53 Vehicle handling problems - programming DME control unit 12149225 R50 Delayed throttle response (program DME) 12149323 Setting OBD readiness code 12149487 E36 E38 E39 E46 E53 M52/TU M62/TU "Check engine" lamp comes on 12149596 E36 E46 E52 E53 E39 M54 S54 S62 Illumination of "Engine emergency program lamp" (oxygen 12149696 E46 N42 DME data Valvetronic monitoring faulty 12149796 E36 E39 E46 E53 M54 Crankshaft position/rpm sensor 12149809 R53 Rough engine operation after cold start 1214XXXX Electronic shift or control units 12210011 Preheating relay/preheating control unit Occasional failure 12210012 Preheating relay/preheating control unit Permanent failure 122100XX Preheating relay/preheating control unit 1221XXXX Preheating relays 12230011 Sheathed-element preheater plugs Occasional failure 12230012 Sheathed-element preheater plugs Permanent failure 122300XX Sheathed-element preheater plugs 1223XXXX Sheathed-element preheater plugs 12310011 Alternator Occasional failure 12310012 Alternator Permanent failure 12310037 Alternator Loose 12310039 Alternator Unpleasant noises 12310048 Alternator Leaking 123100XX Alternator 12310601 Forced cooling for alternator Cracked / broken / torn off 12310632 Forced cooling for alternator Deformed / distorted / bent 12310637 Forced cooling for alternator Loose 123106XX Forced cooling for alternator 12310814 Voltage regulator Occasional malfunction 12310815 Voltage regulator Permanent malfunction 12310837 Voltage regulator Loose 123108XX Voltage regulator 1231XXXX Alternator with drive and mount 12410011 Starter motor Occasional failure 12410012 Starter motor Permanent failure 12410037 Starter motor Loose 12410039 Starter motor Unpleasant noises 124100XX Starter motor 12410401 Heat shield, starter Cracked / broken / torn off 12410439 Heat shield, starter Unpleasant noises 124104XX Heat shield, starter 1241XXXX Starter with mounting 12420713 Starter, alternator connections Broken 12420737 Starter, alternator connections Loose 12420775 Starter, alternator connections corroded 12420780 Starter, alternator connections short circuit 124207XX Starter, alternator connections 12420813 Ground cable, engine - body Broken 12420837 Ground cable, engine - body Loose 12420875 Ground cable, engine - body corroded 124208XX Ground cable, engine - body 12421013 Battery lead B+ (engine compartment) Broken 12421037 Battery lead B+ (engine compartment) Loose 12421075 Battery lead B+ (engine compartment) corroded 12421080 Battery lead B+ (engine compartment) short circuit 124210XX Battery lead B+ (engine compartment) 12421113 Battery lead B- (engine compartment) Broken 12421137 Battery lead B- (engine compartment) Loose 12421175 Battery lead B- (engine compartment) corroded 124211XX Battery lead B- (engine compartment) 12421213 Other starter lead Broken 12421237 Other starter lead Loose 12421275 Other starter lead corroded 12421280 Other starter lead short circuit 124212XX Other starter lead 1242XXXX Starter cable 12510337 DME/DDE control unit connector Loose 12510348 DME/DDE control unit connector Leaking 12510375 DME/DDE control unit connector corroded 12510379 DME/DDE control unit connector incorrect connection /contact 12510381 DME/DDE control unit connector interruption 125103XX DME/DDE control unit connector 12510413 Injection valve connector Broken 12510437 Injection valve connector Loose 12510475 Injection valve connector corroded 12510479 Injection valve connector incorrect connection /contact 12510481 Injection valve connector interruption 125104XX Injection valve connector 12510513 Sensor and component connector Broken 12510537 Sensor and component connector Loose 12510575 Sensor and component connector corroded 12510579 Sensor and component connector incorrect connection /contact 12510581 Sensor and component connector interruption 125105XX Sensor and component connector 12510613 Plug connections Broken 12510637 Plug connections Loose 12510675 Plug connections corroded 12510679 Plug connections incorrect connection /contact 12510681 Plug connections interruption 125106XX Plug connections 12510713 Wiring, heated catalytic converter Broken 12510737 Wiring, heated catalytic converter Loose 12510775 Wiring, heated catalytic converter corroded 12510780 Wiring, heated catalytic converter short circuit 12510781 Wiring, heated catalytic converter interruption 125107XX Wiring, heated catalytic converter 12511201 Lines, engine wiring harness Cracked / broken / torn off 12511269 Lines, engine wiring harness Worn / sheared through 12511281 Lines, engine wiring harness interruption 125112XX Lines, engine wiring harness 12511313 Terminal lugs/threaded connection Broken 12511337 Terminal lugs/threaded connection Loose 12511375 Terminal lugs/threaded connection corroded 12511380 Terminal lugs/threaded connection short circuit 125113XX Terminal lugs/threaded connection 12519538 E38 E39 E46 M57 Judder/misfiring (connector for rail pressure sensor) 1251XXXX Engine wiring harness 12530113 Wiring harness, transmission Broken 12530175 Wiring harness, transmission corroded 12530181 Wiring harness, transmission interruption 125301XX Wiring harness, transmission 1253XXXX Wiring harness, transmission 12610014 Engine oil level sensor (TÖNS) Occasional malfunction 12610014 Thermal oil level sensor (TOENS) Occasional malfunction 12610015 Engine oil level sensor (TÖNS) Permanent malfunction 12610015 Thermal oil level sensor (TOENS) Permanent malfunction 12610048 Engine oil level sensor (TÖNS) Leaking 12610048 Thermal oil level sensor (TOENS) Leaking 126100XX Engine oil level sensor (TÖNS) 126100XX Thermal oil level sensor (TOENS) 12610114 Oil pressure switch Occasional malfunction 12610115 Oil pressure switch Permanent malfunction 12610148 Oil pressure switch Leaking 126101XX Oil pressure switch 12610214 Engine oil temperature sensor Occasional malfunction 12610215 Engine oil temperature sensor Permanent malfunction 12610248 Engine oil temperature sensor Leaking 12610296 Engine oil temperature sensor Fault code in diagnosis memory (warn. lamp on) 12610299 Engine oil temperature sensor Fault code stored in diagnosis fault code memory (no warning 126102XX Engine oil temperature sensor 12610314 Oil status sensor Occasional malfunction 12610315 Oil status sensor Permanent malfunction 12610348 Oil status sensor Leaking 126103XX Oil status sensor 12610414 Evaluator TOENS Occasional malfunction 12610414 Evaluator TÖNS Occasional malfunction 12610415 Evaluator TOENS Permanent malfunction 12610415 Evaluator TÖNS Permanent malfunction 126104XX Evaluator TOENS 126104XX Evaluator TÖNS 12619112 E60 E61 M54 Thermal oil level sensor (TÖNS) defective (replace TÖNS + adapter cable) 12619314 E65 E66 N62 Oil level sensor malfunction 1261XXXX Oil pressure, oil temperature, oil level indicator 12630514 Temperature switch for coolant Occasional malfunction 12630515 Temperature switch for coolant Permanent malfunction 12630548 Temperature switch for coolant Leaking 126305XX Temperature switch for coolant 12630811 Master relay for DME/DDE Occasional failure 12630812 Master relay for DME/DDE Permanent failure 126308XX Master relay for DME/DDE 12630911 Ignition coil relay Occasional failure 12630912 Ignition coil relay Permanent failure 126309XX Ignition coil relay 12631011 Secondary air pump relay Occasional failure 12631012 Secondary air pump relay Permanent failure 12631079 Secondary air pump relay incorrect connection /contact 12631096 Secondary air pump relay Fault code in diagnosis memory (warn. lamp on) 12631099 Secondary air pump relay Fault code stored in diagnosis fault code memory (no warning lamp) 126310XX Secondary air pump relay 12631179 Valvetronic relay module/IVM (integrated supply module) incorrect connection /contact 12631196 Valvetronic relay module/IVM (integrated supply module) Fault code in diagnosis memory (12631199 Valvetronic relay module/IVM (integrated supply module) Fault code stored in diagnosis fault 126311XX Valvetronic relay module/IVM (integrated supply module) 12631214 Compressor relay for mechanical charger Occasional malfunction 12631215 Compressor relay for mechanical charger Permanent malfunction 12631237 Compressor relay for mechanical charger Loose 126312XX Compressor relay for mechanical charger 1263XXXX Switches and relays 12640014 Fuel heating Occasional malfunction 12640015 Fuel heating Permanent malfunction 126400XX Fuel heating 1264XXXX Fuel heating 12710014 Control unit for electronic engine output control (EML) Occasional malfunction 12710015 Control unit for electronic engine output control (EML) Permanent malfunction 12710037 Control unit for electronic engine output control (EML) Loose 12710087 Control unit for electronic engine output control (EML) warning lamp lights up 127100XX Control unit for electronic engine output control (EML) 12710114 Engine emergency program, accelerator sensor Occasional malfunction 12710115 Engine emergency program, accelerator sensor Permanent malfunction 12710181 Engine emergency program, accelerator sensor interruption 127101XX Engine emergency program, accelerator sensor 12710214 Engine emergency program, throttle body Occasional malfunction 12710215 Engine emergency program, throttle body Permanent malfunction 12710234 Engine emergency program, throttle body Stiff to move 12710281 Engine emergency program, throttle body interruption 12710299 Engine emergency program, throttle body Fault code stored in diagnosis fault code memory 127102XX Engine emergency program, throttle body 1271XXXX Electronic control unit 12720014 Pedal position sensor Occasional malfunction 12720015 Pedal position sensor Permanent malfunction 12720034 Pedal position sensor Stiff to move 12720037 Pedal position sensor Loose 12720039 Pedal position sensor Unpleasant noises 12720096 Pedal position sensor Fault code in diagnosis memory (warn. lamp on) 12720099 Pedal position sensor Fault code stored in diagnosis fault code memory (no warning lamp) 127200XX Pedal position sensor 1272XXXX Sensor for control unit 12900148 Control unit box (E-box) Leaking 129001XX Control unit box (E-box) 12900212 Cooling fan for electrical equipment box (E-box) Permanent failure 12900239 Cooling fan for electrical equipment box (E-box) Unpleasant noises 129002XX Cooling fan for electrical equipment box (E-box) 12900312 Temperature switch for electrical equipment box (E-box) Permanent failure 12900323 Temperature switch for electrical equipment box (E-box) Incorrect / not fitted 129003XX Temperature switch for electrical equipment box (E-box) 1290XXXX Electrical equipment box 12XXXXXX Engine Electrical System 12XXXXXX Engine electrics 13310439 Solenoid valve (fuel delivery) Unpleasant noises 13310448 Solenoid valve (fuel delivery) Leaking 13310483 Solenoid valve (fuel delivery) incorrect or no switching action 13310499 Solenoid valve (fuel delivery) Fault code stored in diagnosis fault code memory (no warning 133104XX Solenoid valve (fuel delivery) 1331XXXX Fuel pump with drive and pressure line 13320048 Fuel filter Leaking 13320076 Fuel filter dirty / blocked 133200XX Fuel filter 13321348 Filter drain plug with water level sensor (DDE) Leaking 133213XX Filter drain plug with water level sensor (DDE) 13321437 Fuel cooler (diesel) Loose 13321448 Fuel cooler (diesel) Leaking 13321476 Fuel cooler (diesel) dirty / blocked 133214XX Fuel cooler (diesel) 13321514 Valve, fuel preheating (diesel) Occasional malfunction 13321515 Valve, fuel preheating (diesel) Permanent malfunction 13321548 Valve, fuel preheating (diesel) Leaking 133215XX Valve, fuel preheating (diesel) 13329076 E46 M54 N42 Fuel filter clogged 1332XXXX Fuel filter 13410115 Idle regulating valve Permanent malfunction 13410124 Idle regulating valve Surge 13410129 Idle regulating valve Sticking/jammed 13410139 Idle regulating valve Unpleasant noises 13410196 Idle regulating valve Fault code in diagnosis memory (warn. lamp on) 13410199 Idle regulating valve Fault code stored in diagnosis fault code memory (no warning lamp) 134101XX Idle regulating valve 13410348 Idle speed, air duct Leaking 134103XX Idle speed, air duct 1341XXXX Speed governor 13515015 Distributor-type injection pump diesel (not CR) Permanent malfunction 13515048 Distributor-type injection pump diesel (not CR) Leaking 13515056 Distributor-type injection pump diesel (not CR) Poor running characteristics / friction 13515099 Distributor-type injection pump diesel (not CR) Fault code stored in diagnosis fault code 135150XX Distributor-type injection pump diesel (not CR) 13515411 Cutout solenoid Occasional failure 13515412 Cutout solenoid Permanent failure 135154XX Cutout solenoid 13515848 Distributor-type injection pump, shaft seal Leaking 135158XX Distributor-type injection pump, shaft seal 13515948 Distributor-type injection pump, housing Leaking 135159XX Distributor-type injection pump, housing 13516048 Distributor-type injection pump, inlet/outlet Leaking 135160XX Distributor-type injection pump, inlet/outlet 13516512 High pressure pump HDP Permanent failure 13516515 High pressure pump HDP Permanent malfunction 13516548 High pressure pump HDP Leaking 13516596 High pressure pump HDP Fault code in diagnosis memory (warn. lamp on) 13516599 High pressure pump HDP Fault code stored in diagnosis fault code memory (no warning lamp) 135165XX High pressure pump HDP 1351XXXX Injection pump, regulator section, mixture regulator 13530137 Injector line, DDE connection, nozzle Loose 13530148 Injector line, DDE connection, nozzle Leaking 135301XX Injector line, DDE connection, nozzle 13530737 Injector line, DDE connection, pump Loose 13530748 Injector line, DDE connection, pump Leaking 135307XX Injector line, DDE connection, pump 13530848 Leakage oil line, diesel Leaking 13530876 Leakage oil line, diesel dirty / blocked 135308XX Leakage oil line, diesel 13531048 Diesel fuel injector (not CR) Leaking 13531084 Diesel fuel injector (not CR) incorrect electrical resistance 135310XX Diesel fuel injector (not CR) 13531139 Pressure regulator, petrol Unpleasant noises 13531148 Pressure regulator, petrol Leaking 135311XX Pressure regulator, petrol 13531248 Circuit line/injection tube, petrol Leaking 135312XX Circuit line/injection tube, petrol 13531501 Cover sections for engine Cracked / broken / torn off 13531532 Cover sections for engine Deformed / distorted / bent 13531539 Cover sections for engine Unpleasant noises 135315XX Cover sections for engine 13531737 Fuel pressure regulator, vacuum hose Loose 135317XX Fuel pressure regulator, vacuum hose 13531815 Fuel temperature sensor Permanent malfunction 13531848 Fuel temperature sensor Leaking 135318XX Fuel temperature sensor 13532048 High pressure accumulator (rail) Leaking 135320XX High pressure accumulator (rail) 13532101 High pressure lines Cracked / broken / torn off 13532148 High pressure lines Leaking 135321XX High pressure lines 13532215 Injector, common rail Permanent malfunction 13532239 Injector, common rail Unpleasant noises 13532248 Injector, common rail Leaking 13532284 Injector, common rail incorrect electrical resistance 13532296 Injector, common rail Fault code in diagnosis memory (warn. lamp on) 13532299 Injector, common rail Fault code stored in diagnosis fault code memory (no warning lamp) 135322XX Injector, common rail 13532337 Flange for injector (CR) Loose 135323XX Flange for injector (CR) 13532415 Rail pressure sensor Permanent malfunction 13532448 Rail pressure sensor Leaking 13532496 Rail pressure sensor Fault code in diagnosis memory (warn. lamp on) 13532499 Rail pressure sensor Fault code stored in diagnosis fault code memory (no warning lamp) 135324XX Rail pressure sensor 13532529 Pressure control valve Sticking/jammed 13532548 Pressure control valve Leaking 13532584 Pressure control valve incorrect electrical resistance 135325XX Pressure control valve 13532648 Distributor block, common rail (CR) Leaking 135326XX Distributor block, common rail (CR) 13532711 Valve, air-contained fuel injectors Occasional failure 13532712 Valve, air-contained fuel injectors Permanent failure 135327XX Valve, air-contained fuel injectors 1353XXXX Injectors and lines 13540034 Throttle body with flap Stiff to move 13540037 Throttle body with flap Loose 13540040 Throttle body with flap Poorly adjusted / outside tolerance 13540048 Throttle body with flap Leaking 135400XX Throttle body with flap 13540212 Throttle valve potentiometer/switch Permanent failure 13540237 Throttle valve potentiometer/switch Loose 13540296 Throttle valve potentiometer/switch Fault code in diagnosis memory (warn. lamp on) 13540299 Throttle valve potentiometer/switch Fault code stored in diagnosis fault code memory (no 135402XX Throttle valve potentiometer/switch 13540613 Tension/torsion spring for throttle body Broken 135406XX Tension/torsion spring for throttle body 13540711 Motor-driven throttle valve Occasional failure 13540712 Motor-driven throttle valve Permanent failure 13540734 Motor-driven throttle valve Stiff to move 13540737 Motor-driven throttle valve Loose 13540748 Motor-driven throttle valve Leaking 13540796 Motor-driven throttle valve Fault code in diagnosis memory (warn. lamp on) 13540799 Motor-driven throttle valve Fault code stored in diagnosis fault code memory (no warning 135407XX Motor-driven throttle valve 13540834 Throttle valve actuation on M models Stiff to move 13540837 Throttle valve actuation on M models Loose 13540840 Throttle valve actuation on M models Poorly adjusted / outside tolerance 13540848 Throttle valve actuation on M models Leaking 135408XX Throttle valve actuation on M models 13540911 ASC choke valve Occasional failure 13540912 ASC choke valve Permanent failure 13540934 ASC choke valve Stiff to move 13540948 ASC choke valve Leaking 135409XX ASC choke valve 13541012 EDR actuator (motor-driven throttle valve control) with operating system, M-models Permanent 13541034 EDR actuator (motor-driven throttle valve control) with operating system, M-models Stiff 13541040 EDR actuator (motor-driven throttle valve control) with operating system, M-models Poorly 13541048 EDR actuator (motor-driven throttle valve control) with operating system, M-models Leaking 13541096 EDR actuator (motor-driven throttle valve control) with operating system, M-models Fault 13541099 EDR actuator (motor-driven throttle valve control) with operating system, M-models Fault 135410XX EDR actuator (motor-driven throttle valve control) with operating system, M-models 1354XXXX Throttle valve and controls 13610311 Component, DDE control unit Occasional failure 13610312 Component, DDE control unit Permanent failure 13610323 Component, DDE control unit Incorrect / not fitted 13610337 Component, DDE control unit Loose 13610350 Component, DDE control unit Water ingress / condensate 136103XX Component, DDE control unit 13610511 Control unit for direct fuel injection (N73) Occasional failure 13610512 Control unit for direct fuel injection (N73) Permanent failure 136105XX Control unit for direct fuel injection (N73) 13619818 E65 M57 M67 Incorrect oil service indicator after DDE replacement 1361XXXX Electronic control unit 13620211 Coolant temperture sensor (on engine) Occasional failure 13620212 Coolant temperture sensor (on engine) Permanent failure 13620237 Coolant temperture sensor (on engine) Loose 13620248 Coolant temperture sensor (on engine) Leaking 13620296 Coolant temperture sensor (on engine) Fault code in diagnosis memory (warn. lamp on) 13620299 Coolant temperture sensor (on engine) Fault code stored in diagnosis fault code memory (136202XX Coolant temperture sensor (on engine) 13620514 Intake air temperature sensor Occasional malfunction 13620515 Intake air temperature sensor Permanent malfunction 13620537 Intake air temperature sensor Loose 13620548 Intake air temperature sensor Leaking 13620596 Intake air temperature sensor Fault code in diagnosis memory (warn. lamp on) 13620599 Intake air temperature sensor Fault code stored in diagnosis fault code memory (no warning 136205XX Intake air temperature sensor 13620714 Mass air flow sensor Occasional malfunction 13620715 Mass air flow sensor Permanent malfunction 13620776 Mass air flow sensor dirty / blocked 13620796 Mass air flow sensor Fault code in diagnosis memory (warn. lamp on) 13620799 Mass air flow sensor Fault code stored in diagnosis fault code memory (no warning lamp) 136207XX Mass air flow sensor 13620814 Boost pressure sensor for DDE Occasional malfunction 13620815 Boost pressure sensor for DDE Permanent malfunction 13620837 Boost pressure sensor for DDE Loose 136208XX Boost pressure sensor for DDE 13621114 Battery temperature sensor Occasional malfunction 13621115 Battery temperature sensor Permanent malfunction 13621137 Battery temperature sensor Loose 136211XX Battery temperature sensor 13621211 Engine oil temperature sensor (VANOS) Occasional failure 13621212 Engine oil temperature sensor (VANOS) Permanent failure 13621237 Engine oil temperature sensor (VANOS) Loose 13621248 Engine oil temperature sensor (VANOS) Leaking 13621296 Engine oil temperature sensor (VANOS) Fault code in diagnosis memory (warn. lamp on) 13621299 Engine oil temperature sensor (VANOS) Fault code stored in diagnosis fault code memory (136212XX Engine oil temperature sensor (VANOS) 13621311 Coolant temperature sensor (radiator outlet) Occasional failure 13621312 Coolant temperature sensor (radiator outlet) Permanent failure 13621337 Coolant temperature sensor (radiator outlet) Loose 13621348 Coolant temperature sensor (radiator outlet) Leaking 13621399 Coolant temperature sensor (radiator outlet) Fault code stored in diagnosis fault code memory 136213XX Coolant temperature sensor (radiator outlet) 13621515 Predelivery pressure sensor, common rail (CR) Permanent malfunction 13621548 Predelivery pressure sensor, common rail (CR) Leaking 136215XX Predelivery pressure sensor, common rail (CR) 13621648 Differential pressure sensor (intake pipe pressure sensor) Leaking 13621699 Differential pressure sensor (intake pipe pressure sensor) Fault code stored in diagnosis 136216XX Differential pressure sensor (intake pipe pressure sensor) 13621714 Exhaust gas pressure sensor Occasional malfunction 13621715 Exhaust gas pressure sensor Permanent malfunction 13621748 Exhaust gas pressure sensor Leaking 136217XX Exhaust gas pressure sensor 13621802 Ionic current control unit Software error / internal device fault 13621811 Ionic current control unit Occasional failure 13621812 Ionic current control unit Permanent failure 13621837 Ionic current control unit Loose 136218XX Ionic current control unit 13629214 E38 E39 E53 M62 Mass air flow sensor, warranty extension 1362XXXX Sensor for control unit 13630511 Fuel pump relay Occasional failure 13630512 Fuel pump relay Permanent failure 13630599 Fuel pump relay Fault code stored in diagnosis fault code memory (no warning lamp) 136305XX Fuel pump relay 1363XXXX Electromechanical shift units 13640114 Fuel injector/high pressure fuel injector HDEV (petrol) Occasional malfunction 13640115 Fuel injector/high pressure fuel injector HDEV (petrol) Permanent malfunction 13640139 Fuel injector/high pressure fuel injector HDEV (petrol) Unpleasant noises 13640148 Fuel injector/high pressure fuel injector HDEV (petrol) Leaking 13640196 Fuel injector/high pressure fuel injector HDEV (petrol) Fault code in diagnosis memory (13640199 Fuel injector/high pressure fuel injector HDEV (petrol) Fault code stored in diagnosis fault 136401XX Fuel injector/high pressure fuel injector HDEV (petrol) 13640248 O-ring for injector Leaking 136402XX O-ring for injector 1364XXXX Injector valves, start valves 13710037 Intake air cleaner housing Loose 13710037 Intake filter housing (intake silencer) Loose 13710048 Intake air cleaner housing Leaking 13710048 Intake filter housing (intake silencer) Leaking 137100XX Intake air cleaner housing 137100XX Intake filter housing (intake silencer) 13710314 Auxiliary air flaps (N73) Occasional malfunction 13710315 Auxiliary air flaps (N73) Permanent malfunction 137103XX Auxiliary air flaps (N73) 13710413 Intake port Broken 13710437 Intake port Loose 137104XX Intake port 13719337 E53 M62 Intake hose loose 1371XXXX Intake mufflers 13720001 Unfiltered air flow (before air filter) Cracked / broken / torn off 13720032 Unfiltered air flow (before air filter) Deformed / distorted / bent 13720037 Unfiltered air flow (before air filter) Loose 13720039 Unfiltered air flow (before air filter) Unpleasant noises 13720048 Unfiltered air flow (before air filter) Leaking 137200XX Unfiltered air flow (before air filter) 13720101 Clean air flow (after air filter) Cracked / broken / torn off 13720132 Clean air flow (after air filter) Deformed / distorted / bent 13720137 Clean air flow (after air filter) Loose 13720139 Clean air flow (after air filter) Unpleasant noises 13720148 Clean air flow (after air filter) Leaking 137201XX Clean air flow (after air filter) 13720201 Flexible gaiter for volume air flow/mass air flow sensor Cracked / broken / torn off 13720237 Flexible gaiter for volume air flow/mass air flow sensor Loose 13720239 Flexible gaiter for volume air flow/mass air flow sensor Unpleasant noises 13720248 Flexible gaiter for volume air flow/mass air flow sensor Leaking 137202XX Flexible gaiter for volume air flow/mass air flow sensor 1372XXXX Air flow 13740037 Sound generator with mounting bracket Loose 13740048 Sound generator with mounting bracket Leaking 137400XX Sound generator with mounting bracket 1374XXXX Engine sound system 13800117 CN gas supply system Odour 13800139 CN gas supply system Unpleasant noises 138001XX CN gas supply system 13800209 CN gas - changing over to gas mode Goes out 13800211 CN gas - changing over to gas mode Occasional failure 13800212 CN gas - changing over to gas mode Permanent failure 138002XX CN gas - changing over to gas mode 13800324 CN gas - idle speed in gas mode Surge 13800335 CN gas - idle speed in gas mode Uneven running 13800347 CN gas - idle speed in gas mode Drop in engine speed 138003XX CN gas - idle speed in gas mode 13800417 CN gas - engine in gas mode Odour 13800425 CN gas - engine in gas mode Rough running 13800438 CN gas - engine in gas mode Shaking 13800442 CN gas - engine in gas mode Misfires / malfunction 13800456 CN gas - engine in gas mode Poor running characteristics / friction 138004XX CN gas - engine in gas mode 13800560 CN gas - fuel consumption in gas mode Too high 138005XX CN gas - fuel consumption in gas mode 13800659 CN gas - engine output in gas mode Too low / deep / slight 138006XX CN gas - engine output in gas mode 13800763 CN gas - starting time in gas mode Too long 138007XX CN gas - starting time in gas mode 1380XXXX CN-gas - unit 13810137 CN gas - low pressure line Loose 13810148 CN gas - low pressure line Leaking 138101XX CN gas - low pressure line 13810214 CN gas - injection valve Occasional malfunction 13810215 CN gas - injection valve Permanent malfunction 13810239 CN gas - injection valve Unpleasant noises 138102XX CN gas - injection valve 1381XXXX CN gas - valves and lines 13820114 CN gas - high / low pressure reducer Occasional malfunction 13820115 CN gas - high / low pressure reducer Permanent malfunction 138201XX CN gas - high / low pressure reducer 13820214 CN gas - intake system, vacuum sensor Occasional malfunction 13820215 CN gas - intake system, vacuum sensor Permanent malfunction 138202XX CN gas - intake system, vacuum sensor 13820314 CN gas - metering unit Occasional malfunction 13820315 CN gas - metering unit Permanent malfunction 13820348 CN gas - metering unit Leaking 13820380 CN gas - metering unit short circuit 13820381 CN gas - metering unit interruption 138203XX CN gas - metering unit 1382XXXX CN gas - mixture regulator, metering system, pressure relief 13830114 CN gas - gas cylinder with non-return valve Occasional malfunction 13830137 CN gas - gas cylinder with non-return valve Loose 13830148 CN gas - gas cylinder with non-return valve Leaking 13830152 CN gas - gas cylinder with non-return valve Not opening 13830153 CN gas - gas cylinder with non-return valve Not closing 13830175 CN gas - gas cylinder with non-return valve corroded 138301XX CN gas - gas cylinder with non-return valve 13830211 CN gas - gas leak sensor Occasional failure 13830212 CN gas - gas leak sensor Permanent failure 13830214 CN gas - gas leak sensor Occasional malfunction 13830215 CN gas - gas leak sensor Permanent malfunction 138302XX CN gas - gas leak sensor 13830348 CN gas - vent housing Leaking 138303XX CN gas - vent housing 13830448 CN gas - vent hose Leaking 138304XX CN gas - vent hose 13830537 CN gas - tank frame Loose 13830575 CN gas - tank frame corroded 138305XX CN gas - tank frame 13830613 CN gas - condensate tank Broken 13830617 CN gas - condensate tank Odour 13830637 CN gas - condensate tank Loose 138306XX CN gas - condensate tank 1383XXXX CN gas - gas tank with bracket and valves 13840148 CN gas - high pressure lines Leaking 138401XX CN gas - high pressure lines 13840327 CN gas - non-return valve Locked/jammed 13840348 CN gas - non-return valve Leaking 13840383 CN gas - non-return valve incorrect or no switching action 138403XX CN gas - non-return valve 1384XXXX CN gas - high pressure lines 13850137 CN gas - electromagnetic non-return valve Loose 13850148 CN gas - electromagnetic non-return valve Leaking 13850180 CN gas - electromagnetic non-return valve short circuit 13850183 CN gas - electromagnetic non-return valve incorrect or no switching action 138501XX CN gas - electromagnetic non-return valve 13850214 CN gas - filler connection Occasional malfunction 13850215 CN gas - filler connection Permanent malfunction 13850248 CN gas - filler connection Leaking 13850276 CN gas - filler connection dirty / blocked 138502XX CN gas - filler connection 13850301 CN gas - end cap Cracked / broken / torn off 138503XX CN gas - end cap 13850514 CN gas - changeover, gas/petrol operation Occasional malfunction 13850515 CN gas - changeover, gas/petrol operation Permanent malfunction 13850529 CN gas - changeover, gas/petrol operation Sticking/jammed 13850537 CN gas - changeover, gas/petrol operation Loose 13850586 CN gas - changeover, gas/petrol operation does not light up 138505XX CN gas - changeover, gas/petrol operation 13850686 CN gas - indicator lamp does not light up 138506XX CN gas - indicator lamp 1385XXXX CN gas - electrical components 13860114 CN gas - control unit Occasional malfunction 13860115 CN gas - control unit Permanent malfunction 13860137 CN gas - control unit Loose 138601XX CN gas - control unit 13860214 CN gas - changeover module Occasional malfunction 13860215 CN gas - changeover module Permanent malfunction 13860237 CN gas - changeover module Loose 138602XX CN gas - changeover module 13860314 CN gas - gas quality switch Occasional malfunction 13860315 CN gas - gas quality switch Permanent malfunction 138603XX CN gas - gas quality switch 13860414 CN gas - oxygen sensor Occasional malfunction 13860415 CN gas - oxygen sensor Permanent malfunction 13860479 CN gas - oxygen sensor incorrect connection /contact 138604XX CN gas - oxygen sensor 13860514 CN gas - non-return relay Occasional malfunction 13860515 CN gas - non-return relay Permanent malfunction 13860537 CN gas - non-return relay Loose 138605XX CN gas - non-return relay 1386XXXX CN gas - engine electrics 13900114 Fuel tank vent valve (carbon canister) Occasional malfunction 13900115 Fuel tank vent valve (carbon canister) Permanent malfunction 13900139 Fuel tank vent valve (carbon canister) Unpleasant noises 13900196 Fuel tank vent valve (carbon canister) Fault code in diagnosis memory (warn. lamp on) 13900199 Fuel tank vent valve (carbon canister) Fault code stored in diagnosis fault code memory 139001XX Fuel tank vent valve (carbon canister) 13900237 Hose to tank venting valve Loose 13900248 Hose to tank venting valve Leaking 139002XX Hose to tank venting valve 1390XXXX Carbon canister vent 13XXXXXX Fuel Preparation and Regulation 13XXXXXX Fuel metering and control system 16110032 Fuel tank Deformed / distorted / bent 16110048 Fuel tank Leaking 16110075 Fuel tank corroded 16110094 Fuel tank difficult to fill tank 161100XX Fuel tank 16110137 Fuel tank filler tube (incl. filler hose) Loose 16110148 Fuel tank filler tube (incl. filler hose) Leaking 16110175 Fuel tank filler tube (incl. filler hose) corroded 161101XX Fuel tank filler tube (incl. filler hose) 16110234 Fuel tank bayonet cap Stiff to move 16110237 Fuel tank bayonet cap Loose 16110248 Fuel tank bayonet cap Leaking 161102XX Fuel tank bayonet cap 16110337 Fuel expansion tank Loose 16110348 Fuel expansion tank Leaking 161103XX Fuel expansion tank 16110601 Fuel tank mount Cracked / broken / torn off 16110637 Fuel tank mount Loose 16110639 Fuel tank mount Unpleasant noises 161106XX Fuel tank mount 16110714 Fuel tank pressure sensor Occasional malfunction 16110715 Fuel tank pressure sensor Permanent malfunction 16110799 Fuel tank pressure sensor Fault code stored in diagnosis fault code memory (no warning lamp) 161107XX Fuel tank pressure sensor 16110939 Fuel (sloshing sound) Unpleasant noises 161109XX Fuel (sloshing sound) 16111017 Fuel supply system Odour 161110XX Fuel supply system 16111148 Threaded connection for left tank installation unit, fuel tank Leaking 161111XX Threaded connection for left tank installation unit, fuel tank 16111248 Threaded connection for right tank installation unit, fuel tank Leaking 161112XX Threaded connection for right tank installation unit, fuel tank 16111348 Left tank installation unit, fuel tank Leaking 161113XX Left tank installation unit, fuel tank 16111448 Right tank installation unit, fuel tank Leaking 161114XX Right tank installation unit, fuel tank 1611XXXX Fuel tank with filler pipe 1611XXXX Fuel tank with mount 16120037 Fuel lines/connections in engine compartment (fixed to body) Loose 16120039 Fuel lines/connections in engine compartment (fixed to body) Unpleasant noises 16120048 Fuel lines/connections in engine compartment (fixed to body) Leaking 161200XX Fuel lines/connections in engine compartment (fixed to body) 16120237 Fuel lines/connections (at tank) Loose 16120239 Fuel lines/connections (at tank) Unpleasant noises 16120248 Fuel lines/connections (at tank) Leaking 161202XX Fuel lines/connections (at tank) 16120711 Distributor (between fuel supply and return line) Occasional failure 16120712 Distributor (between fuel supply and return line) Permanent failure 16120748 Distributor (between fuel supply and return line) Leaking 16120776 Distributor (between fuel supply and return line) dirty / blocked 161207XX Distributor (between fuel supply and return line) 16120837 Fuel lines/connections, underbody Loose 16120839 Fuel lines/connections, underbody Unpleasant noises 16120848 Fuel lines/connections, underbody Leaking 161208XX Fuel lines/connections, underbody 16129239 E39 E46 M57 Fuel pump resonance noise in vehicle interior 1612XXXX Fuel lines 16130037 Breather line/connections (from fuel tank to carbon canister / expansion tank) Loose 16130039 Breather line/connections (from fuel tank to carbon canister / expansion tank) Unpleasant 16130048 Breather line/connections (from fuel tank to carbon canister / expansion tank) Leaking 16130076 Breather line/connections (from fuel tank to carbon canister / expansion tank) dirty / blocked 161300XX Breather line/connections (from fuel tank to carbon canister / expansion tank) 16130239 Carbon canister (AKF) Unpleasant noises 16130248 Carbon canister (AKF) Leaking 16130276 Carbon canister (AKF) dirty / blocked 161302XX Carbon canister (AKF) 16130437 Breather line/connections (from carbon canister to fuel tank vent valve) Loose 16130439 Breather line/connections (from carbon canister to fuel tank vent valve) Unpleasant noises 16130448 Breather line/connections (from carbon canister to fuel tank vent valve) Leaking 16130476 Breather line/connections (from carbon canister to fuel tank vent valve) dirty / blocked 161304XX Breather line/connections (from carbon canister to fuel tank vent valve) 16130501 Diagnosis module for fuel tank leakage DMTL Cracked / broken / torn off 16130501 Leak diagnosis unit Cracked / broken / torn off 16130514 Diagnosis module for fuel tank leakage DMTL Occasional malfunction 16130514 Leak diagnosis unit Occasional malfunction 16130515 Diagnosis module for fuel tank leakage DMTL Permanent malfunction 16130515 Leak diagnosis unit Permanent malfunction 16130539 Diagnosis module for fuel tank leakage DMTL Unpleasant noises 16130539 Leak diagnosis unit Unpleasant noises 16130548 Diagnosis module for fuel tank leakage DMTL Leaking 16130548 Leak diagnosis unit Leaking 16130576 Diagnosis module for fuel tank leakage DMTL dirty / blocked 16130576 Leak diagnosis unit dirty / blocked 161305XX Diagnosis module for fuel tank leakage DMTL 161305XX Leak diagnosis unit 16130632 Leak diagnosis unit connection at carbon canister (AKF) Deformed / distorted / bent 16130648 Leak diagnosis unit connection at carbon canister (AKF) Leaking 16130676 Leak diagnosis unit connection at carbon canister (AKF) dirty / blocked 161306XX Leak diagnosis unit connection at carbon canister (AKF) 16130732 Line to intake manifold (diagnosis module for fuel tank leakage DMTL) Deformed / distorted 16130732 Line to intake pipe (leakage diagnosis unit LDE only) Deformed / distorted / bent 16130739 Line to intake manifold (diagnosis module for fuel tank leakage DMTL) Unpleasant noises 16130739 Line to intake pipe (leakage diagnosis unit LDE only) Unpleasant noises 16130748 Line to intake manifold (diagnosis module for fuel tank leakage DMTL) Leaking 16130748 Line to intake pipe (leakage diagnosis unit LDE only) Leaking 16130776 Line to intake manifold (diagnosis module for fuel tank leakage DMTL) dirty / blocked 16130776 Line to intake pipe (leakage diagnosis unit LDE only) dirty / blocked 161307XX Line to intake manifold (diagnosis module for fuel tank leakage DMTL) 161307XX Line to intake pipe (leakage diagnosis unit LDE only) 16130832 Dust filter with line to diagnosis module for fuel tank leakage DMTL Deformed / distorted 16130832 Dust filter with line to leak diagnosis unit Deformed / distorted / bent 16130866 Dust filter with line to diagnosis module for fuel tank leakage DMTL No effect 16130866 Dust filter with line to leak diagnosis unit No effect 16130876 Dust filter with line to diagnosis module for fuel tank leakage DMTL dirty / blocked 16130876 Dust filter with line to leak diagnosis unit dirty / blocked 161308XX Dust filter with line to diagnosis module for fuel tank leakage DMTL 161308XX Dust filter with line to leak diagnosis unit 16139117 E46 M43TU M52TU M54 Fuel odour 1613XXXX Fuel ventilation system, emission monitoring 16140218 Fuel filler sensor, left Incorrect/incomplete reading 161402XX Fuel filler sensor, left 16140318 Fuel filler sensor, right Incorrect/incomplete reading 161403XX Fuel filler sensor, right 16140411 Electric fuel pump in fuel tank (in-tank electric fuel pump) Occasional failure 16140412 Electric fuel pump in fuel tank (in-tank electric fuel pump) Permanent failure 16140439 Electric fuel pump in fuel tank (in-tank electric fuel pump) Unpleasant noises 161404XX Electric fuel pump in fuel tank (in-tank electric fuel pump) 16140515 Fuel sucking jet pump Permanent malfunction 16140539 Fuel sucking jet pump Unpleasant noises 16140576 Fuel sucking jet pump dirty / blocked 161405XX Fuel sucking jet pump 16140699 EKP control unit Fault code stored in diagnosis fault code memory (no warning lamp) 161406XX EKP control unit 16140739 Pressure regulator in delivery unit Unpleasant noises 16140748 Pressure regulator in delivery unit Leaking 161407XX Pressure regulator in delivery unit 16140848 Hydraulic lines/connections in fuel tank Leaking 161408XX Hydraulic lines/connections in fuel tank 16140981 Electric lines/connections in fuel tank interruption 161409XX Electric lines/connections in fuel tank 16141011 Electric fuel pump in feed line (diesel, in-line electric fuel pump) Occasional failure 16141012 Electric fuel pump in feed line (diesel, in-line electric fuel pump) Permanent failure 16141039 Electric fuel pump in feed line (diesel, in-line electric fuel pump) Unpleasant noises 161410XX Electric fuel pump in feed line (diesel, in-line electric fuel pump) 16141148 Fuel filter in delivery unit Leaking 161411XX Fuel filter in delivery unit 16141276 Intake filter, in-tank electric fuel pump dirty / blocked 161412XX Intake filter, in-tank electric fuel pump 16149115 E46 M54 Incorrect fuel gauge display (fuel level sensor) 16149218 E53 M62 M54 Fuel gauge incorrect (fuel level sensor) 16149318 E36/7 Incorrect value shown by fuel gauge (fuel level sensor) 16149418 E36 Fuel gauge incorrect - fuel level sensor 16149518 R50 W10 MINI Fuel gauge incorrect indication (fill level sensor) 16149711 E46 M47/TU M57 (SA 201) Replacing presupply pump 1614XXXX Fuel delivery, preparation and volume measurement 16XXXXXX Fuel supply 17110037 Radiator including module carrier Loose 17110048 Radiator including module carrier Leaking 17110072 Radiator including module carrier Poorly bled 171100XX Radiator including module carrier 17110114 Radiator cap Occasional malfunction 17110115 Radiator cap Permanent malfunction 17110123 Radiator cap Incorrect / not fitted 17110148 Radiator cap Leaking 171101XX Radiator cap 17110237 Radiator compensating tank Loose 17110248 Radiator compensating tank Leaking 171102XX Radiator compensating tank 17110401 Fan surround Cracked / broken / torn off 17110437 Fan surround Loose 17110439 Fan surround Unpleasant noises 171104XX Fan surround 17110759 Radiator coolant level Too low / deep / slight 17110760 Radiator coolant level Too high 171107XX Radiator coolant level 17111112 Electric fan Permanent failure 17111137 Electric fan Loose 17111139 Electric fan Unpleasant noises 17111179 Electric fan incorrect connection /contact 17111199 Electric fan Fault code stored in diagnosis fault code memory (no warning lamp) 171111XX Electric fan 17111214 Thermostat for oil-to-coolant heat exchanger (automatic transmission) Occasional malfunction 17111215 Thermostat for oil-to-coolant heat exchanger (automatic transmission) Permanent malfunction 17111279 Thermostat for oil-to-coolant heat exchanger (automatic transmission) incorrect connection 171112XX Thermostat for oil-to-coolant heat exchanger (automatic transmission) 1711XXXX Radiator with mount 17122001 Coolant hose, thin (inside diameter approx. 8 mm) Cracked / broken / torn off 17122030 Coolant hose, thin (inside diameter approx. 8 mm) Blistering 17122069 Coolant hose, thin (inside diameter approx. 8 mm) Worn / sheared through 171220XX Coolant hose, thin (inside diameter approx. 8 mm) 17122101 Coolant hose, medium (inside diameter approx. 16 mm) Cracked / broken / torn off 17122130 Coolant hose, medium (inside diameter approx. 16 mm) Blistering 17122169 Coolant hose, medium (inside diameter approx. 16 mm) Worn / sheared through 171221XX Coolant hose, medium (inside diameter approx. 16 mm) 17122201 Coolant hose, thick (inside diameter approx. 32 mm) Cracked / broken / torn off 17122230 Coolant hose, thick (inside diameter approx. 32 mm) Blistering 17122269 Coolant hose, thick (inside diameter approx. 32 mm) Worn / sheared through 171222XX Coolant hose, thick (inside diameter approx. 32 mm) 17122313 Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm) Broken 17122337 Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm) Loose 17122341 Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm) Poorly adapted/171223XX Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm) 17122413 Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm) Broken 17122437 Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm) Loose 17122441 Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm) Poorly adapted/171224XX Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm) 17122513 Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm) Broken 17122537 Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm) Loose 17122541 Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm) Poorly adapted/171225XX Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm) 17122613 Hose clip, coolant hose, thin (inside diameter approx. 8 mm) Broken 17122637 Hose clip, coolant hose, thin (inside diameter approx. 8 mm) Loose 17122641 Hose clip, coolant hose, thin (inside diameter approx. 8 mm) Poorly adapted/fitted 171226XX Hose clip, coolant hose, thin (inside diameter approx. 8 mm) 17122713 Hose clip, coolant hose, medium (inside diameter approx. 16 mm) Broken 17122737 Hose clip, coolant hose, medium (inside diameter approx. 16 mm) Loose 17122741 Hose clip, coolant hose, medium (inside diameter approx. 16 mm) Poorly adapted/fitted 171227XX Hose clip, coolant hose, medium (inside diameter approx. 16 mm) 17122813 Hose clip, coolant hose, thick (inside diameter approx. 32 mm) Broken 17122837 Hose clip, coolant hose, thick (inside diameter approx. 32 mm) Loose 17122841 Hose clip, coolant hose, thick (inside diameter approx. 32 mm) Poorly adapted/fitted 171228XX Hose clip, coolant hose, thick (inside diameter approx. 32 mm) 1712XXXX Coolant lines/coolant hoses 17210039 Engine oil cooler Unpleasant noises 17210048 Engine oil cooler Leaking 172100XX Engine oil cooler 17210148 Heat exchanger, automatic transmission fluid - coolant Leaking 172101XX Heat exchanger, automatic transmission fluid - coolant 17210539 Oil cooler for automatic transmission Unpleasant noises 17210548 Oil cooler for automatic transmission Leaking 172105XX Oil cooler for automatic transmission 1721XXXX Oil cooler 17220037 Engine oil cooler lines/connections, engine end Loose 17220039 Engine oil cooler lines/connections, engine end Unpleasant noises 17220048 Engine oil cooler lines/connections, engine end Leaking 172200XX Engine oil cooler lines/connections, engine end 17220137 Engine oil cooler lines/connections, oil cooler end Loose 17220139 Engine oil cooler lines/connections, oil cooler end Unpleasant noises 17220148 Engine oil cooler lines/connections, oil cooler end Leaking 172201XX Engine oil cooler lines/connections, oil cooler end 17221139 Oil cooler lines/hoses for transmission fluid, transmission side Unpleasant noises 17221148 Oil cooler lines/hoses for transmission fluid, transmission side Leaking 172211XX Oil cooler lines/hoses for transmission fluid, transmission side 17221239 Oil cooler lines/hoses for transmission fluid on radiator side Unpleasant noises 17221248 Oil cooler lines/hoses for transmission fluid on radiator side Leaking 172212XX Oil cooler lines/hoses for transmission fluid on radiator side 17229023 E53 M54 Retrofit autom. gearbox oil cooler lines with chafe guard (with independ. heating 1722XXXX Oil cooler lines 17310112 Radiator shutter Permanent failure 17310113 Radiator shutter Broken 17310115 Radiator shutter Permanent malfunction 173101XX Radiator shutter 1731XXXX Radiator shutter 17320112 Changeover valve, radiator shutter Permanent failure 17320129 Changeover valve, radiator shutter Sticking/jammed 17320179 Changeover valve, radiator shutter incorrect connection /contact 17320184 Changeover valve, radiator shutter incorrect electrical resistance 173201XX Changeover valve, radiator shutter 17320248 Vacuum hose, radiator shutter Leaking 17320276 Vacuum hose, radiator shutter dirty / blocked 173202XX Vacuum hose, radiator shutter 1732XXXX Radiator shutter actuation 17510137 Charge air intercooler Loose 17510148 Charge air intercooler Leaking 17510176 Charge air intercooler dirty / blocked 175101XX Charge air intercooler 17510232 Charge air pipes/hoses Deformed / distorted / bent 17510237 Charge air pipes/hoses Loose 17510248 Charge air pipes/hoses Leaking 17510276 Charge air pipes/hoses dirty / blocked 175102XX Charge air pipes/hoses 1751XXXX Charge air intercooler with mount 17XXXXXX Cooling 17XXXXXX Cooling System 18110032 Exhaust system, general Deformed / distorted / bent 18110039 Exhaust system, general Unpleasant noises 181100XX Exhaust system, general 18110101 Front exhaust pipe (jacket pipe) Cracked / broken / torn off 18110101 Front exhaust pipes (Y-pipe) Cracked / broken / torn off 18110137 Front exhaust pipe (jacket pipe) Loose 18110137 Front exhaust pipes (Y-pipe) Loose 18110148 Front exhaust pipe (jacket pipe) Leaking 18110148 Front exhaust pipes (Y-pipe) Leaking 181101XX Front exhaust pipe (jacket pipe) 181101XX Front exhaust pipes (Y-pipe) 18110248 Exhaust pipe flange gasket Leaking 18110248 Flange gasket, exhaust pipe Leaking 181102XX Exhaust pipe flange gasket 181102XX Flange gasket, exhaust pipe 18110501 Vibration absorber, exhaust pipe Cracked / broken / torn off 18110537 Vibration absorber, exhaust pipe Loose 181105XX Vibration absorber, exhaust pipe 18110601 Intermediate pipe (between manifold and catalytic converter) Cracked / broken / torn off 18110604 Intermediate pipe (between manifold and catalytic converter) Screw connection torn 18110637 Intermediate pipe (between manifold and catalytic converter) Loose 18110639 Intermediate pipe (between manifold and catalytic converter) Unpleasant noises 18110648 Intermediate pipe (between manifold and catalytic converter) Leaking 181106XX Intermediate pipe (between manifold and catalytic converter) 1811XXXX Exhaust line 1811XXXX Exhaust pipe 18120001 Front silencer Cracked / broken / torn off 18120039 Front silencer Unpleasant noises 18120048 Front silencer Leaking 18120075 Front silencer corroded 181200XX Front silencer 18120101 End silencer (with tailpipes) Cracked / broken / torn off 18120139 End silencer (with tailpipes) Unpleasant noises 18120148 End silencer (with tailpipes) Leaking 18120175 End silencer (with tailpipes) corroded 181201XX End silencer (with tailpipes) 18120201 Intermediate silencer Cracked / broken / torn off 18120239 Intermediate silencer Unpleasant noises 18120248 Intermediate silencer Leaking 18120275 Intermediate silencer corroded 181202XX Intermediate silencer 18120339 Rear silencer, exhaust flap Unpleasant noises 18120383 Rear silencer, exhaust flap incorrect or no switching action 181203XX Rear silencer, exhaust flap 1812XXXX Silencer 18210001 Front exhaust mount (bracket) Cracked / broken / torn off 18210001 Front exhaust system mounting (clamp) Cracked / broken / torn off 18210037 Front exhaust mount (bracket) Loose 18210037 Front exhaust system mounting (clamp) Loose 182100XX Front exhaust mount (bracket) 182100XX Front exhaust system mounting (clamp) 18210101 Rear exhaust mount (bracket) Cracked / broken / torn off 18210101 Rear exhaust system mounting (clamp) Cracked / broken / torn off 18210137 Rear exhaust mount (bracket) Loose 18210137 Rear exhaust system mounting (clamp) Loose 182101XX Rear exhaust mount (bracket) 182101XX Rear exhaust system mounting (clamp) 18210401 Centre exhaust mount (bracket) Cracked / broken / torn off 18210401 Middle exhaust system mounting (clamp) Cracked / broken / torn off 18210437 Centre exhaust mount (bracket) Loose 18210437 Middle exhaust system mounting (clamp) Loose 182104XX Centre exhaust mount (bracket) 182104XX Middle exhaust system mounting (clamp) 18210501 Front exhaust mount, rubber element Cracked / broken / torn off 18210501 Rubber element, front exhaust system mounting Cracked / broken / torn off 18210537 Front exhaust mount, rubber element Loose 18210537 Rubber element, front exhaust system mounting Loose 182105XX Front exhaust mount, rubber element 182105XX Rubber element, front exhaust system mounting 18210601 Centre exhaust mount, rubber element Cracked / broken / torn off 18210601 Rubber element, middle exhaust system mounting Cracked / broken / torn off 18210637 Centre exhaust mount, rubber element Loose 18210637 Rubber element, middle exhaust system mounting Loose 182106XX Centre exhaust mount, rubber element 182106XX Rubber element, middle exhaust system mounting 18210701 Rear exhaust mount, rubber element Cracked / broken / torn off 18210701 Rubber element, rear exhaust system mounting Cracked / broken / torn off 18210737 Rear exhaust mount, rubber element Loose 18210737 Rubber element, rear exhaust system mounting Loose 182107XX Rear exhaust mount, rubber element 182107XX Rubber element, rear exhaust system mounting 1821XXXX Exhaust mounting components 1821XXXX Exhaust system mounting parts 18300001 Diesel particle filter (DPF) Cracked / broken / torn off 18300014 Diesel particle filter (DPF) Occasional malfunction 18300015 Diesel particle filter (DPF) Permanent malfunction 18300039 Diesel particle filter (DPF) Unpleasant noises 18300048 Diesel particle filter (DPF) Leaking 183000XX Diesel particle filter (DPF) 1830XXXX Exhaust pipe with catalyti Link to post Share on other sites
BMW 528iA 0 Posted March 5, 2008 Report Share Posted March 5, 2008 Jel to prijavljuje dijagnostika ako ne radi? Dijagnostika prijavljuje ako ona ne radi uopste, ne ako je slaba. P.S. HEX codovi su vrh! Link to post Share on other sites
gadafi 0 Posted March 5, 2008 Report Share Posted March 5, 2008 mislim da moze da se vidi i kad je slaba .samo su dosta slabiji inpulsi ili ne kosnstantni (kada se locira na aparatu) Link to post Share on other sites
BMW E36 POWER 0 Posted March 5, 2008 Author Report Share Posted March 5, 2008 vili,pohvali se... Link to post Share on other sites
gadafi 0 Posted March 5, 2008 Report Share Posted March 5, 2008 sad jedno pitanje :good: dali moze da se vrati digitalna kilometraza sa aparatom za dijagnosticiranje automobila? naravno a da se ne primeti :hi: Link to post Share on other sites
///Misic 0 Posted March 6, 2008 Report Share Posted March 6, 2008 Dijagnostika prijavljuje ako ona ne radi uopste, ne ako je slaba.P.S. HEX codovi su vrh! hmmm... pa kako da znam da li je slaba ako dijagnostika cuti? Link to post Share on other sites
BMW 528iA 0 Posted March 6, 2008 Report Share Posted March 6, 2008 mislim da moze da se vidi i kad je slaba .samo su dosta slabiji inpulsi ili ne kosnstantni (kada se locira na aparatu) Da, impusli su slabi i to moze da se vidi uzpomoc dijagnostike ali kome to pada napamet kad Check engine nije upaljen? A koliko vlasnika imaju Auto Datu? 0. A koliko imaju skener gresaka? Dosta, i ja ga imam. Link to post Share on other sites
BMW 528iA 0 Posted March 6, 2008 Report Share Posted March 6, 2008 hmmm... pa kako da znam da li je slaba ako dijagnostika cuti? BMW preporucuje da servisiras auto svakih 20 000 milja. Link to post Share on other sites
///Misic 0 Posted March 6, 2008 Report Share Posted March 6, 2008 Da, impusli su slabi i to moze da se vidi uzpomoc dijagnostike ali kome to pada napamet kad Check engine nije upaljen? A koliko vlasnika imaju Auto Datu? 0. A koliko imaju skener gresaka? Dosta, i ja ga imam. imam autodatu, ali nemam taj skener, pa ja trazim da me kace na dijagnostiku svaki put kad menjam ulje zbog eventualnih gresaka koje se pojave. Jel to ok? Link to post Share on other sites
BMW 528iA 0 Posted March 6, 2008 Report Share Posted March 6, 2008 sad jedno pitanje :good: dali moze da se vrati digitalna kilometraza sa aparatom za dijagnosticiranje automobila? naravno a da se ne primeti :hi: Kod BMW-a predjena kilometraza je registrovana u 4 procesora. U ABS-u, u ECU-u, u imobilajzer kljuca i u intrumentablu. Ovlasceni servis BMW-a ima aparat koji moze da regulise kilometrazu i niko ne moze da zna. Moguce je i uz pomoc lap topa i odgovarajuceg programa ali BMW ima jos jednu stvar koju drugi automobili nemaju a to je mala tackica na display kilometraze i zove se Manipulation Dot. Ona svijetli ako je neko na neprofesionalan nacin dirao kilometrazu, svijetli iako je neko zamijenio instrumentablu a ona nije progeamirana od strane BMW servisa. Link to post Share on other sites
BMW 528iA 0 Posted March 6, 2008 Report Share Posted March 6, 2008 imam autodatu, ali nemam taj skener, pa ja trazim da me kace na dijagnostiku svaki put kad menjam ulje zbog eventualnih gresaka koje se pojave.Jel to ok? Da. Link to post Share on other sites
Neso 0 Posted March 7, 2008 Report Share Posted March 7, 2008 Ona svijetli ako je neko na neprofesionalan nacin dirao kilometrazu, svijetli iako je neko zamijenio instrumentablu a ona nije progeamirana od strane BMW servisa. Može li se kako ubiti ova sijalica, mora se nakako sat moći spustiti na 200hkm, samo je bitno da ona ne svijetli. Link to post Share on other sites
BMW 528iA 0 Posted March 7, 2008 Report Share Posted March 7, 2008 Naravno da moze, ako nadjes majstora koji ima tehniku za to. Link to post Share on other sites
BMW-E36 0 Posted March 31, 2008 Report Share Posted March 31, 2008 ocistismo neki dan na nasim autima...mnogo mirnije radi kada je hladan pa ako neko ima vremena da se zeza oko auta neka ocisti...skoditi ne moze...Za e36: ---------------------------------------------------------------------------------------- jel ovo stvar i sa 316i onaj sa lancem? Juce se zavirivah al nidje ne mogoh da vidim ler venti? :pleasantry: Link to post Share on other sites
