Sasquatch 0 Posted September 22, 2015 Author Report Share Posted September 22, 2015 @miki potrebna piksla :) nekako mi sve to nisko, daleko iz vidokruga mada je dosta eleganto. Ma podi i cao. Link to post Share on other sites
Indorile 0 Posted September 23, 2015 Report Share Posted September 23, 2015 Opruzi se za heads up displej i mirna backa :P Link to post Share on other sites
Sasquatch 0 Posted September 23, 2015 Author Report Share Posted September 23, 2015 Nije HUD nesto skup, ali moras da seces tablu jos i nalepnica na soferku sto ne bi nikada radio na ovom auto. Da si rekao digitalni cluster satica pa da sve vidim na jednom mestu i da razmisljam, samo sto je to mnogo para :) Link to post Share on other sites
Sasquatch 0 Posted December 31, 2015 Author Report Share Posted December 31, 2015 Haj da ne bude da nista nisam radio. Nove SKF lazajeve, zadnje, i anker platna i nove poluosovine. Nabavio lazaj kardana, stage 2 kuplung, nuke performance cam pulley i neke zabice. e da ne zaboravim, iz tu sve ide system pranja i brisace farova ali slike malo kasnije Pozdrav Link to post Share on other sites
Miki_BMW 0 Posted January 5, 2016 Report Share Posted January 5, 2016 Samo napred Djordje... :thumbsup: Link to post Share on other sites
Lemi M5 0 Posted January 6, 2016 Report Share Posted January 6, 2016 Ti si oboleo... Link to post Share on other sites
StunterSM 0 Posted January 6, 2016 Report Share Posted January 6, 2016 Posto si placao poluosovine Link to post Share on other sites
325ixA 0 Posted January 6, 2016 Report Share Posted January 6, 2016 Sto nove poluosovine? Link to post Share on other sites
StunterSM 0 Posted January 6, 2016 Report Share Posted January 6, 2016 Jer su polovne za sirotinju :) Link to post Share on other sites
325ixA 0 Posted January 6, 2016 Report Share Posted January 6, 2016 nove poluosovine su kao kupovina novog nakovnja, moze ali cemu. Link to post Share on other sites
percon 0 Posted January 6, 2016 Report Share Posted January 6, 2016 Nek se vidi raskos?? Link to post Share on other sites
Sasquatch 0 Posted January 6, 2016 Author Report Share Posted January 6, 2016 Polu osovine su bile na preko 50% popust iz Irske. A mislim kadaracunamo posto je remot svega pozadi, nije skupo. Dojadilo mi luft. To je kako se resava taj problem. I bit you gentle men adieú :) Link to post Share on other sites
325ixA 0 Posted January 6, 2016 Report Share Posted January 6, 2016 I onda je potonuo. Link to post Share on other sites
StunterSM 0 Posted January 6, 2016 Report Share Posted January 6, 2016 Koliko evropskih Link to post Share on other sites
Sasquatch 0 Posted January 6, 2016 Author Report Share Posted January 6, 2016 Oko 100 Link to post Share on other sites
MAXA BMW 0 Posted January 6, 2016 Report Share Posted January 6, 2016 Nisu skupe...A tesko je naci dobre polovne polu osovine sa abs-om.. Link to post Share on other sites
MladenR 0 Posted January 9, 2016 Report Share Posted January 9, 2016 Bez teksta ;) Link to post Share on other sites
Sasquatch 0 Posted January 27, 2016 Author Report Share Posted January 27, 2016 da ne ispadne da nisam kacio, za HLWW slike mora da se ceka evo stage 2 set kvacila neka firma drive tourqe jer eto opet imam problema sa kvacilom. Sad samo da stignu nove semeringe i ostali zaptevaciza menjaca. Prekidac za R je tu negde,i lezaj za kardana. Zadnja ankerplatna, lezajevi, i opruge ili SKF ili iz BMWa, opruge su 8.9kg/mm AVO Nuke campully za m20 ozbiljno izgleda jos treba da mi stigne ATE Power diskovi napred/nazad sa plocicama. Link to post Share on other sites
Bengvejac 0 Posted January 27, 2016 Report Share Posted January 27, 2016 Ozbiljan projekat :D Konacno sam saznao da se deo zove anker platna, do sad sam zvao tanjiri :P kolko su kostali posto moram i ja da pazarim? Link to post Share on other sites
Sasquatch 0 Posted January 27, 2016 Author Report Share Posted January 27, 2016 U felti su oko 4000 komad. Razlikuju se leva i desna. Mozes po broju da nadjes na bmw fans ili real oem. Link to post Share on other sites
Leto 0 Posted January 27, 2016 Report Share Posted January 27, 2016 Eh, pitanje zasto nove je kao kada bi pitali zasto si jebao kada možes da drkas! Isti je ishod rekao bi naivan svet. Link to post Share on other sites
Sasquatch 0 Posted January 27, 2016 Author Report Share Posted January 27, 2016 Novo se kupi jer su polovne uglavnom za kantu. Da zamenis, skida se glavcina, a to da skines postoji mogucnost da moras da menjas lezaj. Sto bi neko to radio da ne mora. Link to post Share on other sites
Sasquatch 0 Posted January 31, 2016 Author Report Share Posted January 31, 2016 zadnje platforme pa da podignem zadnji deo auta proba Jos samo da se montira i namesti visina Opruge su AVO 500lbs/inch ili 8.9kg/mm 2.5"ID (66mm ID). Tvrdoca je kompromis jer je auto touring pa je pozadi tezi nego 2/4vrata. Cilj je da bude 40%-45% tvrdje nego stosu prednje Link to post Share on other sites
Sasquatch 0 Posted February 9, 2016 Author Report Share Posted February 9, 2016 Sve ugradjeno. Morao sam da izvadim opruge, adapteri udaraju u platforme. Mora da se sve to skrati. Tvrdoca odgovara. Link to post Share on other sites
pomoravac 0 Posted February 26, 2016 Report Share Posted February 26, 2016 Auto bombona. Link to post Share on other sites
