wice 0 Posted May 20, 2013 Report Share Posted May 20, 2013 uzeo sam ovaj kabl i uz njega dobio adapter sa obd2 na obd1 i disk sa instalacijom v 5.0 ali ne znam da instaliram naime kod mene je win 7 mozda zato nece da radi,koristio sam uputstvo koje sam dobio na cd ali ne radi. ima li neko neki savet ko je vec instalirao ?hvala Link to post Share on other sites
777.boban 0 Posted May 20, 2013 Report Share Posted May 20, 2013 Probaj na xp-u,masa tih diagnostika nece da rade na Win7. Link to post Share on other sites
wice 0 Posted May 20, 2013 Author Report Share Posted May 20, 2013 ma tacno cu d apoludim,ili sam ja toliko glup ili nesto nije kako treba.instalirao sam u compability mody sa installl fajlovima koje sam skinuo na netu covek kaze d akod njega radi,kod mene nece kada upalim program, baterry je ukljuceno ne vezano da li sam povezao konektor na kolima ili ne,a ignition ne daje nikakve promene Link to post Share on other sites
wice 0 Posted May 20, 2013 Author Report Share Posted May 20, 2013 nece,probao sam i na drugom laptopu sa win xp i nece....ipak mi ova tehnika nije jaca strana u pitanju je ovo http://www.gophoto.it/view.php?i=http://static.kupindoslike.com/BMW-i-MINI-INPA-EDIABAS-K-DCAN-auto-dijagnostika_slika_O_8547937.jpg#.UZpe0tgeobM Link to post Share on other sites
StunterSM 0 Posted May 20, 2013 Report Share Posted May 20, 2013 Zajebano je malo ali treba da radi, mene je zezalo duze vreme i na kraju je proradila :) Link to post Share on other sites
wice 0 Posted May 20, 2013 Author Report Share Posted May 20, 2013 moze li neka smernica?:) Link to post Share on other sites
wice 0 Posted May 21, 2013 Author Report Share Posted May 21, 2013 ponovo sam instalirao po ovom uputstvu http://www.bmwforums.info/ecu-diagnostics-tuning/2506-idiots-guide-bmw-inpa-installation-modded-usb-vagcom-windows-vista.html ali opet nece jedino sto sam primetio je kada pokrenem ediabas v 6.4.7 koliko sam skontao to je drajver dok ne pokrenem program inpa tu je polje gde pise interface prazno kada pokrenem inpu onda pise STD-OBD a u inpi sta god da pokusam da pokrenem za e36 ispise "command not accepted" sve jedno da li je prikljucen kabl ili ne i ne mogu da nateram da svetle one dve lampice baterry i ignition Link to post Share on other sites
KG BMW 0 Posted May 21, 2013 Report Share Posted May 21, 2013 ja sam jedino uspesno mogao da instaliram a da to radi tako sto sve fajlove prekopiram na hard pa odatle instaliram,tako je pisalo i u readme.txt! Link to post Share on other sites
wice 0 Posted May 21, 2013 Author Report Share Posted May 21, 2013 tako sam i radio,sve kao sto pise u uputstvu i nece,a sto mi je najzalije je to sto u ovom uputstvu su namestili da radi sa vagcom kablom koji je 4-5 puta jeftiniji od ovoga :( Link to post Share on other sites
wice 0 Posted May 21, 2013 Author Report Share Posted May 21, 2013 probao sam na e46 ali covek zuri pa nisam detaljisao ni tamo ne pali crne tacke ali radi,na brzinu sam video da cita zive podatke, elem probao sam kod mene i sa carsoftom ,ali kada pokrenem testiranje, ugasi se crvena lampica na kablu i prijavi gresku "communication error" i bad data cable Link to post Share on other sites
wice 0 Posted May 21, 2013 Author Report Share Posted May 21, 2013 neko? Link to post Share on other sites
wice 0 Posted May 24, 2013 Author Report Share Posted May 24, 2013 koliko ja vidim niko se nije zaludjivao sa ovim :) Link to post Share on other sites
StunterSM 0 Posted May 24, 2013 Report Share Posted May 24, 2013 Sacekaj koji dan, uzeo sam novi lap top pa cu da se igram sa inpom. Uglavnom radila mi je. Kad namestim, narezacu ti cd sa uputstvo i programom koji 100% radi Link to post Share on other sites
wice 0 Posted May 24, 2013 Author Report Share Posted May 24, 2013 ok, mada jedino sta mi pada na pamet je da me zeza kabl,mada preko onog adaptera kada ubodem elm 327 on se konektuje,ali posto sam koristio skan master ( za fiata) on jedino iscita da je povezan,iscita napon akumulatora i prijavi da ecu ne moze pronaci u bazi podataka,sto je i normalno jelte :) Link to post Share on other sites
wice 0 Posted May 24, 2013 Author Report Share Posted May 24, 2013 da li moze da pravi problem sto je na usb? ako je to problem da ga onda menjam za verziju koja je na serijski? Link to post Share on other sites
wice 0 Posted May 26, 2013 Author Report Share Posted May 26, 2013 cuo sam se sa covekom od koga sam uzeo,moze mi nabaviti i sa serijskim portom tj sa prikljuckom na serijski,ako je to pametnija kombinacija ,da onda menjam Link to post Share on other sites
wice 0 Posted May 28, 2013 Author Report Share Posted May 28, 2013 help ? Link to post Share on other sites
Sicko 0 Posted May 28, 2013 Report Share Posted May 28, 2013 Jbg. Ne znam šta može da bude. Moja šljaka preko carsoft-ovog interfejsa ponekad prijavi lošu komunikaciju ali ništa strašno. Koje ti je godište auto? Znam da moja neće na m50 da radi. Prilikom instalacije čini mi se da biraš koji priključak koristiš obd2 ili okrugli pa probaj i sa jednim i sa drugim, šta ja znam... Pozovi Mikija (Mikie36) mada se sad prekrstio u neki drugi nik. Ako ne strani forumi i uporno... Ako treba nešto da se prevede tu sam... Srećno. Link to post Share on other sites
wice 0 Posted May 28, 2013 Author Report Share Posted May 28, 2013 1992 je.koju verziju carsofta koristis? Link to post Share on other sites
hermes 0 Posted May 28, 2013 Report Share Posted May 28, 2013 carsoft preko comporta,samo to. Link to post Share on other sites
Sicko 0 Posted May 28, 2013 Report Share Posted May 28, 2013 V6,5 koristim... Link to post Share on other sites
Sicko 0 Posted May 28, 2013 Report Share Posted May 28, 2013 http://forums.bimmerforums.com/forum/showthread.php?t=1312104 Ovu instalaciju sam koristio za Inpu i saljaka... Doduše kupio sam neki matori laptop sa com-portom i sa nekim matorim windows-om... Link to post Share on other sites
wice 0 Posted May 28, 2013 Author Report Share Posted May 28, 2013 cek cek ,kazete da vas interfejs nije na usb vec na serijski?da menjam onda moj kabl.a da li vam radi na novijim vozilima oko 2000? Link to post Share on other sites
CasperBg82 0 Posted May 28, 2013 Report Share Posted May 28, 2013 MikiS38 je to rekao u jednoj temi, valjda usb ne podrzava 8-bitnu komunikaciju, tako nesto Link to post Share on other sites
wice 0 Posted May 28, 2013 Author Report Share Posted May 28, 2013 http://forums.bimmerforums.com/forum/showthread.php?t=1312104 Ovu instalaciju sam koristio za Inpu i saljaka... Doduše kupio sam neki matori laptop sa com-portom i sa nekim matorim windows-om... hvala na linku ,al odakle si skinuo?koje god ti je e36? Link to post Share on other sites
