StunterSM 0 Posted May 30, 2013 Report Share Posted May 30, 2013 Dosla i kockica, V8 ce biti pod haubom, sad krecu pripreme, bicete obavesteni o radovima :) Koliko vidim, sasija je dosta zdrava, idu trapovi sa 5 rupa, mozda neki kompresor na kraju i tako to :) Evo jedne slike za pocetak Link to post Share on other sites
bucaBMW 0 Posted May 30, 2013 Report Share Posted May 30, 2013 sta treba da se radi,evo ja cu da gledam :D . . . samo napred srecno :) Link to post Share on other sites
Dzoni 0 Posted May 30, 2013 Report Share Posted May 30, 2013 Jos jedna legenda :D SAMO NAPRED!!! Link to post Share on other sites
terza 0 Posted May 30, 2013 Report Share Posted May 30, 2013 ooo stigao je :) daj jos neku sliku i srecan rad, da nemas velikih muka kao ja! hahaha :D Link to post Share on other sites
susice34 0 Posted May 30, 2013 Report Share Posted May 30, 2013 Jos jedna legenda :D SAMO NAPRED!!! +1 Link to post Share on other sites
StunterSM 0 Posted May 30, 2013 Author Report Share Posted May 30, 2013 Hvala momci bice slika. Auto ce biti potpuno restauriran, maximalno ce se posvetiti paznja detaljima B) Link to post Share on other sites
susice34 0 Posted May 30, 2013 Report Share Posted May 30, 2013 To se ceni, samo napred i neka je sa srecom! Link to post Share on other sites
bokibmw 0 Posted May 30, 2013 Report Share Posted May 30, 2013 krecemo polako...... Link to post Share on other sites
Dzoni 0 Posted May 31, 2013 Report Share Posted May 31, 2013 Kurcenje... Link to post Share on other sites
[kick] 0 Posted May 31, 2013 Report Share Posted May 31, 2013 Samo napred, pre izrade nosace obratite paznju na izduvne grane :) Link to post Share on other sites
StunterSM 0 Posted May 31, 2013 Author Report Share Posted May 31, 2013 Od ponedeljaka se vari, radi se zastita i farba motorni prostor, posle toga ide motor i tako dalje. Hvala Kick, mada mislim da nece biti problema ;) Link to post Share on other sites
Miki_BMW 0 Posted May 31, 2013 Report Share Posted May 31, 2013 Pomno cu pratiti radove... Neka je sa srecom... :) Link to post Share on other sites
ivicaflojd 0 Posted May 31, 2013 Report Share Posted May 31, 2013 jos jedan V8... :) samo napred sa srecom radovi Link to post Share on other sites
percon 0 Posted May 31, 2013 Report Share Posted May 31, 2013 lepo,lepo. samo napred,praticemo vas Link to post Share on other sites
StunterSM 0 Posted June 2, 2013 Author Report Share Posted June 2, 2013 Jebao me siber :angry: Al sta cu kad volim :dance3: Nisu odvodi valjali pa je voda isla u kabinu i pod je stradao na par mesta.. Nista sto se ne moze srediti, ali jbg. Da nije bilo pokvarenog sibera auto bi bio 90% zdrav min. Gepek je solidan, mesto rezervnog tocka je kao novo Leva strana takodje Ali desna je pokazala, sa par fleka ce biti sredjeno Sa leve strane papucica bilo je nekog slivanja vode i rdja mu je jebala kevu Iza vozaca pod je dobar Zadnja desna strana malo u banani I evo ga kod suvozacevih nogu trulex, tu je valjda pustao vodu, to se mora resiti posle varenja. Sutra pocinju radovi oko varenja, zastite, zastite od buke itd itd. Bice i slika delova trapa, kocnica i ostalih zanimljivih resenja i delova :) Link to post Share on other sites
marudza 0 Posted June 2, 2013 Report Share Posted June 2, 2013 'oce cigan da ima siber... :lol::P Link to post Share on other sites
StunterSM 0 Posted June 3, 2013 Author Report Share Posted June 3, 2013 :dance3: Evo slika kocnica, disk 350mm+brembo cetvoroklipna klesta. Ice pancirna creva, nazad od 540i E39 kocnice na disk od 350mm takodje+hidro rucna :lol: Klesta odneta danas na peskiranje, kao i letva i most. :crazy: Nasao sam ovo malo precenjeno djubre :lol: Polirani Eibach Podizaci stizu za koji dan, ozvucenje se polako prikuplja. E sad, sta ce mi faliti... Bice mi potrebna instalacija od nekog m20, kabinska i spoljanja za stopke, farove itd. Ako neko ima celu kockicu za delove zamolio bi da ne spaljuje bakar, posto imam siber ne mogu da platim bolje od brace romova! Ako treba sam cu da skinem sve, potrebna mi je cela. E da jos klima za kocku mi je potrebna. Jedino ce mi biti visak kompresor, ali moze i sa njim. Znaci kompletna klima Link to post Share on other sites
terza 0 Posted June 3, 2013 Report Share Posted June 3, 2013 Sredi se to sve nije strasno. Ovo boja ko m*da moja :D cirusblau isto? Nasao sam adapter plocu za menjac od m50 na m60 motor :dance3: Link to post Share on other sites
marudza 0 Posted June 3, 2013 Report Share Posted June 3, 2013 Pa podeli sa drugarima,daj da vidimo to... :) ja sam hteo da probam da napravim,al nikako.. Link to post Share on other sites
StunterSM 0 Posted June 3, 2013 Author Report Share Posted June 3, 2013 Ce gi napravimo :preved: Link to post Share on other sites
terza 0 Posted June 3, 2013 Report Share Posted June 3, 2013 Pa podeli sa drugarima,daj da vidimo to... :) ja sam hteo da probam da napravim,al nikako.. Evo drugari... Ovaj je za m60 v8 motor i menjac od m50 motora. a ovaj je za m70 v12 motor i isto menjac od m50 motora. Link to post Share on other sites
marudza 0 Posted June 3, 2013 Report Share Posted June 3, 2013 Des to naso?Kolko novaca? Link to post Share on other sites
Dzoni 0 Posted June 4, 2013 Report Share Posted June 4, 2013 Imam ja komplet instalaciju sa moje crne kocke... Link to post Share on other sites
StunterSM 0 Posted June 4, 2013 Author Report Share Posted June 4, 2013 Jedan problem resen ;) Link to post Share on other sites
