Nismo 0 Posted November 18, 2018 Report Share Posted November 18, 2018 Ona bi trebalo stalno da lupa, a ako je dosta potrosena onda bi i zveckala. Neka je majstor nategne po spoju bocno i pogledajte da li je guma ispucala. Link to post Share on other sites
Nismo 0 Posted November 18, 2018 Report Share Posted November 18, 2018 Just now, danijel90 said: Culo mi se kada naglo pustim gas kao neki tup udarac u zadnjem delu,zamenio mi je lezaj kardana,ali zvuk je i dalje tu Proverite silen blok diferencijala... Link to post Share on other sites
StunterSM 0 Posted November 19, 2018 Report Share Posted November 19, 2018 Verovatno je u samom difu problem. Mi otklanjamo to uspesno. Pa ako bude bas u difu javi se Link to post Share on other sites
danijel90 0 Posted November 19, 2018 Author Report Share Posted November 19, 2018 8 hours ago, Nismo said: Ona bi trebalo stalno da lupa, a ako je dosta potrosena onda bi i zveckala. Neka je majstor nategne po spoju bocno i pogledajte da li je guma ispucala. Za sada neka ide tako,mislim rekao si da ne moze nista da bude opasno,a i meni se cini vise da je hidro spaner lanca u pitanju... Link to post Share on other sites
danijel90 0 Posted November 19, 2018 Author Report Share Posted November 19, 2018 Nego da resim ovaj problem sa lupkanjem prvo,jako me nervira,pa vam javljam sta sam uspeo... Link to post Share on other sites
Nismo 0 Posted November 19, 2018 Report Share Posted November 19, 2018 5 hours ago, StunterSM said: Verovatno je u samom difu problem. Mi otklanjamo to uspesno. Pa ako bude bas u difu javi se Pun ti je inbox, mozes li da resis to ili da mi das neki drugi kontakt? ? Link to post Share on other sites
StunterSM 0 Posted November 19, 2018 Report Share Posted November 19, 2018 +381 64 3545 782 Boki On je zaduzen za servis reduktora i diferencijala. Reci da ti je Miki dao broj Link to post Share on other sites
danijel90 0 Posted November 19, 2018 Author Report Share Posted November 19, 2018 Hvala...odakle je? Link to post Share on other sites
La Haine 0 Posted November 20, 2018 Report Share Posted November 20, 2018 To je Boki iz Bogatića verovatno. @StunterSM je u pravu, mislio sam da je do silena jer kad je hladno ne lupne, jutros je bilo hladno i kad sam ga čuo da je lupnuo, okrenuo mi se želudac.. pokusavao sam da sredim to kod ovog decka koji radi u servisu i odrzava mi auto, kaze majstor da ce da me kosta prilicno.. Razgovarao sam i sa jednim renomiranim znalcem iz Srbije, kaze to im je boljka.. Mora da se poskida i rasturi sve, da se vidi sta sve ne valja, nemam prostora vremenskog za to.. Uglavnom je bilo reci na f. kako su motori ovakvi onakvi, trose ulje umre svakih pet minuta po jedan..pravi problemi se ne pominju.. Link to post Share on other sites
La Haine 0 Posted November 20, 2018 Report Share Posted November 20, 2018 Meni se čuje samo na 1500 rpm pri saltanju, u normalnom rezimu voznje 2000+ obrtaja ga nema.. Svakako da mi je receno da treba da se proba drugi silen za početak.. Link to post Share on other sites
StunterSM 0 Posted November 21, 2018 Report Share Posted November 21, 2018 Firmu drzimo kolega i ja, RacingDiffs. Ali smo odvojili servis od proizvodnje i prodaje, jer je nemoguce raditi sve. Bokijev brat je radio sa nama dok je sve bilo kod mene oko godinu dana. Tako da smo servis prebacili kod Bokija. Sto se tice ovog problema sa lupkanjem jedan dan je potreban, ukoliko dovezete auto 250e je cifra, dok u slucaju da posaljete dif onda je 200e. Prethodno neka majstor utvrdi da li je do difa, da ne bi radili posao bzvz Link to post Share on other sites
La Haine 0 Posted November 21, 2018 Report Share Posted November 21, 2018 Hvala majstore, javiću se čim ugrabim vreme i sredstva. Link to post Share on other sites
danijel90 0 Posted December 9, 2018 Author Report Share Posted December 9, 2018 Pozdrav,pratio sam malo to cukanje u diferencijalu pri menjanju brzina,i sad na ovo hladno vreme se skoro ni ne cuje.. Link to post Share on other sites
danijel90 0 Posted December 9, 2018 Author Report Share Posted December 9, 2018 E sada imam novi problem,menjali su mi set kvacila i gornji cilindar kvacila,i od tada mi je kocnica jako tvrda i slabije koci,sta su majstori zeznuli? Link to post Share on other sites
La Haine 0 Posted March 5, 2019 Report Share Posted March 5, 2019 Meni je diferencijal dobar. silen je star, poluosovine nisu dobre-imaju lufta obe, polovne koje sam gledao takodje nisu perfektne, ali su bolje od mojih. Potrazicu nove, ako da Bog da sredim to. Link to post Share on other sites
smg 0 Posted March 6, 2019 Report Share Posted March 6, 2019 13 hours ago, La Haine said: Meni je diferencijal dobar. silen je star, poluosovine nisu dobre-imaju lufta obe, polovne koje sam gledao takodje nisu perfektne, ali su bolje od mojih. Potrazicu nove, ako da Bog da sredim to. Ja sam primetio da mi poluosovine imaju "lufta". E sad ne znam da li moraju da budu skroz "bez" lufta ili ipak moraju malo da mogu da "rade". Link to post Share on other sites
La Haine 0 Posted March 6, 2019 Report Share Posted March 6, 2019 (edited) Bem li ga, one polovne koje hteo da mi uvali otpadzija takodje rade malo..raspitacu se. Ima na ebayu poluosovina afkermarket, pitacu u radnji.. Mislim da tu homokinetika strada, pod manzetnom je kvar. Edited March 6, 2019 by La Haine Link to post Share on other sites
La Haine 0 Posted March 6, 2019 Report Share Posted March 6, 2019 Celu zimu ga ne cujem, javi se povremeno, nista strasno..kad otopli krene zezancija Link to post Share on other sites
smg 0 Posted March 6, 2019 Report Share Posted March 6, 2019 Zvao sam ja za nove 30k komad ... Link to post Share on other sites
Indorile 0 Posted March 6, 2019 Report Share Posted March 6, 2019 (edited) Nove poluosovine nemaju lufta, polovne imaju sve do jedne. Bila pre koju godinu SKF-ova akcija, obe za 150e. Edited March 6, 2019 by Indorile Link to post Share on other sites
La Haine 0 Posted March 6, 2019 Report Share Posted March 6, 2019 Ja cu da mu izmenjam silene za pocetak nosace...sve. od neceg mora da se krene Link to post Share on other sites
