StunterSM 0 Posted October 17, 2019 Report Share Posted October 17, 2019 Ista d je prava stvar za tebe š Link to post Share on other sites
zeljko85 0 Posted October 17, 2019 Author Report Share Posted October 17, 2019 (edited) Hvala!Ā Nista, onda da skidamĀ Edited October 17, 2019 by zeljko85 Link to post Share on other sites
zeljko85 0 Posted October 19, 2019 Author Report Share Posted October 19, 2019 (edited) Skinuto, malo sam se igrao sa ista i nasao sledeceĀ Greske, sve greske koje je nasao su vezane za polozaj grejanja/hladjenja. I rezultat citanjaĀ Vanos-a.Ā Edited October 19, 2019 by zeljko85 Link to post Share on other sites
Picvajzmen 0 Posted October 22, 2019 Report Share Posted October 22, 2019 Jedno poÄetniÄko pitanje, Å”ta god da uzmem bmw scanner, inpa, ista d jedan te isti kabl koristim? Onaj k+dcan sa usbom Å”to ima na aliexpresu da se naÄe? Sent from my Redmi Note 4 using Tapatalk Link to post Share on other sites
zeljko85 0 Posted October 22, 2019 Author Report Share Posted October 22, 2019 Za bmw scanner ne znam. Inpa i ista d koriste K+DCAN kabl Link to post Share on other sites
Picvajzmen 0 Posted October 23, 2019 Report Share Posted October 23, 2019 Hvala prijateljuSent from my Redmi Note 4 using Tapatalk Link to post Share on other sites
ilovebigasses 0 Posted October 23, 2019 Report Share Posted October 23, 2019 Bmw scanner moze sa bilo kojim kablom (najobicniji od stampaca) šš Link to post Share on other sites
Picvajzmen 0 Posted October 23, 2019 Report Share Posted October 23, 2019 Bmw scanner moze sa bilo kojim kablom (najobicniji od stampaca) [emoji16][emoji106]Kako to misliÅ”? Mislim gde utakneÅ” onaj kockasti nastavak u e46cu? Sent from my Redmi Note 4 using Tapatalk Link to post Share on other sites
ilovebigasses 0 Posted October 23, 2019 Report Share Posted October 23, 2019 Aaaa pa taj deo ubadas u OBD dzek. Link to post Share on other sites
Picvajzmen 0 Posted October 23, 2019 Report Share Posted October 23, 2019 Nije mi sad jasno kako taj nastavak može u obd port, moram da pogledam kad zavrŔim sa poslom danas.. [emoji848] Sad si me zainteresovao.  Sent from my Redmi Note 4 using Tapatalk    Link to post Share on other sites
StunterSM 0 Posted October 23, 2019 Report Share Posted October 23, 2019 Neozbiljan je 𤣠Link to post Share on other sites
Picvajzmen 0 Posted October 23, 2019 Report Share Posted October 23, 2019 Neozbiljan je [emoji1787]Kasno si mi rekao, dobio sam otkaz sa posla jer sam ukrao kabl od Å”tampaÄa i sad mi žena i dete nemaju Å”ta da jedu pa Äu se i razvesti, nadam se da te grize savest Å”to zajebavaÅ” glupe i neke i uniÅ”tavaÅ” im živote Sent from my Redmi Note 4 using Tapatalk Link to post Share on other sites
zeljko85 0 Posted October 23, 2019 Author Report Share Posted October 23, 2019 (edited) Neko, neki predlog kako, Å”ta da gledam? Ovo grejanje mi je trenutno prioritet. Prefledao sam sve osiguraÄe, Äitavi su. Pregledao žice, deluju ok, registrovao bateriju... nemam vise ideja sta da gledam. Äudne mi ove temperature (footwell temp -50c, ventilationĀ temp -43c), jel moguce da je neki senzor rikavela pa bacio ihkr modul u limp mode? Kad udjem u ihkr modul mogu da ocitam ugao pozicije duvanja, ali pozicija se ne menja Edited October 23, 2019 by zeljko85 Link to post Share on other sites
StunterSM 0 Posted October 23, 2019 Report Share Posted October 23, 2019 2 hours ago, Picvajzmen said: Kasno si mi rekao, dobio sam otkaz sa posla jer sam ukrao kabl od Å”tampaÄa i sad mi žena i dete nemaju Å”ta da jedu pa Äu se i razvesti, nadam se da te grize savest Å”to zajebavaÅ” glupe i neke i uniÅ”tavaÅ” im živote Sent from my Redmi Note 4 using Tapatalk Ā Vidi KABAL pase u interfejs, znaci sam kabal, parce kabla. Koristi kabal za stampace, digitalne foto aparate i slicno. Usb AB Link to post Share on other sites
Picvajzmen 0 Posted October 23, 2019 Report Share Posted October 23, 2019 Vidi KABAL pase u interfejs, znaci sam kabal, parce kabla. Koristi kabal za stampace, digitalne foto aparate i slicno. Usb AB[emoji23]Sent from my Redmi Note 4 using Tapatalk Link to post Share on other sites
NikNS 0 Posted October 23, 2019 Report Share Posted October 23, 2019 Cim se gadja takvim vrednostima senzori su rikavela.. Tipa ja kad sam otkinuo podkrilo gde je smesten senzor spoljne temperature pokazuje -40 stepeni tako da klasican simptom, mada probaj da sad kad si iskodirao akumulator izvadis ostavis celu noc bez akumulatora da svaki modul ostane bez struje i sutra vratis pa od samog tog praznjenja i dobijanja struje vrati sam sebe u normalu, ali sanse su male. Link to post Share on other sites
ilovebigasses 0 Posted October 23, 2019 Report Share Posted October 23, 2019 Hahahšššpitacu ujutru drugara za one VANOS greske pa ti pisem. Link to post Share on other sites
zeljko85 0 Posted November 18, 2019 Author Report Share Posted November 18, 2019 (edited) Update - ako nekog upste zanima Imao sam do sad 7,8 bmw-a ali ovakvo smece nikad u zivotu. Ako se neko ikad odluci da kupi 116i sa n45 motorom, nek mu je bog u pomoci ili sam ja neverovatan baksuz.Ā Sto se tice grejanja, nisam uspeo da ustanovim kvar, jos uvek. Zamenio sam kontrolni panel => nista, ispitao step motore => nista, ostaje mi da probam da zamenim FSU (mada sumnjam da je to, jer ventilator radi normalno, grejanje radi, mogu da kontrolisem jacinu duvanja i nemam problema sa akumulatorom), i da probam da nabavim malo bolji multimetar ili probnu lampu da testiram LIN-BUS ka steperima. Vanos, nisam nista dirao, i dalje se cuje kako se cuje i to ne mogu nista da diram dok ne skupim malo para, pa cu da probam da resavam problem kad dodje vreme.Ā I dalje dimi i gotovo sam 100% siguran da je zbog pcv membrane ili creva do usisne grane. Pre nego sto sam skidao membranu nisam mogao da otvorim cep na poklopcu ventila koliki je vakum bio, sad kad sam skinuo, ocistio vise nema tog vakuma, ali kad otvorim cep zadimi kao parna lokomotiva, ne vidi se od dima. Jel postoji neko resenje da se blokira pcv ventil znam da nije optimalno resenje ali vise mi je muka auta, hocu da probam da ga sredim maksimalno koliko je u mojoj moci i da ga prodam? Ā edit: Zaboravio sam da dodam, od kako ga imam, upalila se lampica za ABS od kako mi je vulkanizer zamenio gume, auto trokira dok ne upali gresku na bordu i ventilator na radijatoru je prestao da radi Edited November 18, 2019 by zeljko85 Link to post Share on other sites
NikNS 0 Posted November 18, 2019 Report Share Posted November 18, 2019 Mene vec nervira a tvoj je auto, jel moguce da je takav feler.... Iskreno znajuci cene popravki gore, naci nekog naseg mehanicara pa sa njim videti sta i kako jer to na tom autu nisu cista posla.... Pogotovo sto kazes da se nije zaustavio na tome nego i jos stvari odlazi... Link to post Share on other sites
zeljko85 0 Posted November 18, 2019 Author Report Share Posted November 18, 2019 Ne vredi matori, bio sam kod par njih, jedan nece da ima posla sa BMW-ima, drugi nema vremena da trazi gremline i treci radi samo za sebe(preprodavac) tako da sam izvisio za majstora. Bio sam i kod par lokalnih majstora ali stvarno nemam para za njih (najbolje sto sam nasao je: dijagnostika i zamena lanca - 1100eu i sam je rekao da je pitanje koliko ce to stvari da resi na autu Ā ).Ā Link to post Share on other sites
NikNS 0 Posted November 18, 2019 Report Share Posted November 18, 2019 Ma sve znam, drugar mi je u Oslu, a imam jednog u Stavangeru, sve je skupo da je ludilo. A pitanje da li ga kao takvog mozes dovuci do Srbije pa za manje kesa to resiti. U svakom slucaju prodaja mu ne gine... Bar bih ja tako Link to post Share on other sites
zeljko85 0 Posted November 18, 2019 Author Report Share Posted November 18, 2019 To bi bilo idealno ali tesko da mogu sad tako nesto da odradim, sto zbog klinca sto zbog nedostatka vremena. Dodje mi da ga olupam najjace Link to post Share on other sites
njegovawisost 0 Posted November 18, 2019 Report Share Posted November 18, 2019 (edited) Uzas, greini Ā Ovamo ima dobrih majatora za krseve od BMW, mozda bi i pronaali gremline. Kakav bre lanac, lanac na ovim kolima nije sigurno, to je maltene vecno. Ā To s ABS je moguce da je pocupao greskomĀ ABS kabl. Ā Ja na mom kecu 118D 2006, za godinu i kusur dana srecom ni jednu jedinu gresku elektronike... Edited November 18, 2019 by njegovawisost Link to post Share on other sites
dredger 0 Posted November 18, 2019 Report Share Posted November 18, 2019 Znaci nista od Norveskog prodavac placa popravku. Nije ni Norveska sto je bila. Link to post Share on other sites
zeljko85 0 Posted November 18, 2019 Author Report Share Posted November 18, 2019 (edited) Ne znam sta je, proveravao sam, sve stoji na mestu. Nigde se ne primecuje da je bilo sta zapinjalo tako da je verovatno slucajnost da se to bas sad desi. Mene sad interesuje da li je senzor ili je onaj abs prsten jer obicno kad upalim auto nema greske i u toku lagane voznje krene da torkira,Ā cuje se abs kako radi iĀ ukljucuje se kontrola proklizavanja. Tek kad izadjem na otvoren put on da gresku i tad vise ne seca ni nista. Sad da li je senzor ili prsten, pitanje Ā @dredger Pa bre sta da ti kazem, ljudi tamo, ljudi ovde, svuda ima djubradi. Mada je i moja greska sto nisam citao ugovor, pise da kupjem auto u stanju kakvom stoji i jbga Edited November 18, 2019 by zeljko85 odg za dredger Link to post Share on other sites
