marudza 0 Posted January 30, 2013 Report Share Posted January 30, 2013 Hebe net u PodgoricU,a? :D Link to post Share on other sites
Nikolam3 0 Posted January 30, 2013 Report Share Posted January 30, 2013 slike su stvarno velike a loše,a za radove svaka čast... Link to post Share on other sites
Desmo 0 Posted February 5, 2013 Report Share Posted February 5, 2013 Svaka ti čast na radovima, nek se mašina što pre zavrti i samo lagano :clapping: Link to post Share on other sites
zbeka 0 Posted February 14, 2013 Report Share Posted February 14, 2013 ne hebe, nije sad ekstra kao u metropoli Vrčin ali eto :preved: nepregledno je sa ovolikim slikama, a bas dobar projekat :pilot: Link to post Share on other sites
ivicaflojd 0 Posted February 14, 2013 Report Share Posted February 14, 2013 dokle se stiglo sa radovima kad ce masina da se zavrti Link to post Share on other sites
terza 0 Posted February 17, 2013 Author Report Share Posted February 17, 2013 slike su stvarno velike a loše,a za radove svaka čast... Trebalo bi da se prilagode samo ali... sredice to neki moderator :) Svaka ti čast na radovima, nek se mašina što pre zavrti i samo lagano :clapping: Trudimo se, nadam se da ce biti do leta ili pocetka jeseni. dokle se stiglo sa radovima kad ce masina da se zavrti Stiglo se do pocetka :), malo sam u guzvi oko diplomskog na faxu pa ne stizem...ali radi se po malo. ne hebe, nije sad ekstra kao u metropoli Vrčin ali eto :preved: nepregledno je sa ovolikim slikama, a bas dobar projekat :pilot: Jeste, bas je zeznuto. Jedino da se drzi CTRL i vrti skrol na misu da se odalji i stane slika u ekran. Kacicu opet slike kao i do sad pa mozda neko sredi stvar. Kome je veliko neka gleda slike direktno na SLIKE Link to post Share on other sites
terza 0 Posted February 17, 2013 Author Report Share Posted February 17, 2013 . Link to post Share on other sites
terza 0 Posted February 17, 2013 Author Report Share Posted February 17, 2013 5x120 Overfinch Range Rover Vogue GT 280mm Dosta laksi od ovih 260mm, centralni deo od neke spec legure m3 e36, Range Rover Vogue i Sport 260mm, i ovaj od 280mm svi su 5x120mm raspon rupa i centralna rupa ista Na zalost idu na x5 kod drugara... morao bi neke skupe japanske 18" felne ili 19" bilo koje, a mislim da na e30 sve preko 17" gubi smisao. Dvodelna OZ Mito felna 17" , nije moja samo proba sa diskom od 260mm, staju brembo 4 klipa. Ovo su moje zadnje 9 1/2 J i napred 8J Azev 17" 5x120 Kad dodje red, bice i one farbane Napred 215 40 17, pozadi 245 35 17 ovakve gume se vec bile na njima isto na e30 i pokazalo se kao prava mera Stgao deda mraz :))))) Kako vam se cini? Ovo je neki novi model, drugar je kupio iste pre god ili 2 i nisu imali ovaj dugi navoj da se skine cizma ili kako se vec zove. Visina zadnji Poceo sam kao ove glupace na FB kad slikaju sta su jele :D Nazad na glavno jelo :) Na originalnom karteru je merac ulja bio na zadnjem delu kartera, morali smo da krivimo merac i pravimo novi drzac meraca. Isto je i sa slivanjem uljnih para samo malo manji posao. taj sam Nemam poverenja ni u jedan deo na motoru koji sam kupio kao ispravan :) , pa se trudim da proverim ispravnost svega sto mogu. Dizne su probane na pezou 405 2.0 16v MI16, za cudo rade sve :D . Pre probe smo ih ocistili u u.z. kadi. Nemam snimak ali auto je i upaljen na ove dizne, zivo gorivo izbacuje od kolicine benzina :D dimi ko smederevac spreman Motorna instalacija I tu je bilo malo posla al ide brzo na slikama :P e, ovo ce biti zanimljivo na prvoj voznji. Takodje garantovana ispravnost, nadam se da je ok. lsd differential , sa 320is e30. odnos 3.46 i 25% sper Da je menjac 6 brzina sigurno bi islo nesto jos krace tj 3.91 sigurno Suv, presao ispod 100.000km Motor spreman, motorna instalacija stavljena, ulje sipano 5w30 professional castrol. Alnaser radi, ulje se diglo u glavu sve ok. Mislim da posle nekih 500km promenim ulje i sipam 10w60 ??? Ovako je izgledao unutra pre rasturanja Levi bubreg super Desni radjen, i opet ce :) Trenutno 1 konjska snaga :D glavni segrt haha Izgleda da 1.6 nije mogao da ga razvali, 100cm okruglo ako je to fabricka mera kako kazu... Planiram da menjam boju pa rasturamo sve. Fabricka boja cirrusblau Glavni limar :) Kiselina iz akumulatora je cudo, za kaznu ide u gepek :lol: Donji deo veznog lima je los pa cu ga menjati Nigde nisam nasao da valja pa sam kupio nov, iskoristicu samo donji deo pa ako nekom treba gornji deo moze za 2000din, ceo je 4600din. Moze i neka zamena Fantom Kako sam se nadao odlacan je :e30: Treba da se radi kao i vecina kola starijih preko 20 godina. Nesto je vec neko radio ali radicemo opet i pregledati sve. Po izgledu prednjih koseva, greda, nosaca prednjeg i zadnjeg branika, veznih limova siguran sam da nije bio lupan. Kako vama izgleda? U koju boju ga farbati????? Ne bi bilo tesko da nije ovoga Kompletan enterijer od e30 m3, prednja sedista, zadnja klupa za 2 osobe :), crveni tepih, tapaciri i zadnja polica. Na slici se i ne vidi lepo, boja koze je neka tamno crvena u originalnom stanju nije presvlaceno. Koja boja kola ide sa ovom bojom? Taj m3 je bio crne boje, pa nesto mislim i ja da prskam u crno. Mada i ova boja je lepa a ista boja koze je kao moja Sva misljenja i sugestije dobrodosle Link to post Share on other sites
NS_320i 0 Posted February 17, 2013 Report Share Posted February 17, 2013 Svaka cast, napreduje se, ova kocka ce biti metak kad se zavrsi!! Gledam one diskove - ima oci da ti ispadnu kad stisnes kocnicu hehehehe. Sto se tice boje i ja mislim da bi mu legla crna extra sa tim sedistima, ili bela eventualno.... Link to post Share on other sites
325ixA 0 Posted February 17, 2013 Report Share Posted February 17, 2013 sto je problem kliknuti rezise kod uploada... Link to post Share on other sites
CasperBg82 0 Posted February 17, 2013 Report Share Posted February 17, 2013 ili ja ne znam da gledam "u metar" ili je onaj disk 380mm a ne 280 :) Link to post Share on other sites
backovic 0 Posted February 17, 2013 Report Share Posted February 17, 2013 Uh....zalude mi komp! :lol: Sedišta su perverzija!! Link to post Share on other sites
Lemi M5 0 Posted February 17, 2013 Report Share Posted February 17, 2013 Svi diskovi su 100mm veci nego sto si napisao :) Link to post Share on other sites
marudza 0 Posted February 17, 2013 Report Share Posted February 17, 2013 uh kakav ce ovo auto da bude.svaka cast... Link to post Share on other sites
zlaja.so 0 Posted February 17, 2013 Report Share Posted February 17, 2013 Svaka cast za radove, ali gde pusti onog sa AUTOGENIM APARATOM da ti sprzi sve pa to se radi sa Co2... :lol: Link to post Share on other sites
Desmo 0 Posted February 17, 2013 Report Share Posted February 17, 2013 Koliki su standardni diskovi na autu iz kog je motor? M5 e34? Mislim da ne bi trebalo ići preko toga, ništa specijalno nećeš dobiti sa kočnicama od Rovera koji ima 2.2 tone. Samo muke sa velikim felnama i skupim gumama. Dobri diskovi, pločice i pancirna creva su dovoljni za kockicu :preved: Link to post Share on other sites
terza 0 Posted February 17, 2013 Author Report Share Posted February 17, 2013 Svaka cast, napreduje se, ova kocka ce biti metak kad se zavrsi!! Gledam one diskove - ima oci da ti ispadnu kad stisnes kocnicu hehehehe. Sto se tice boje i ja mislim da bi mu legla crna extra sa tim sedistima, ili bela eventualno.... I ja sam vise za crnu nego za belu... Kocice samo da se prvo zaleti :D sto je problem kliknuti rezise kod uploada... sve mislim proradice forum a onda ce biti male slike...jbg ili ja ne znam da gledam "u metar" ili je onaj disk 380mm a ne 280 :) Pogresno sam ukucao 360 i 380mm su diskovi :) uh kakav ce ovo auto da bude.svaka cast... Bice bice ako izguramo do kraja :P imam jednu lanciu iz 1939 stoji na pola gotova vec 2 godine, nadam se da ce ovaj projekat ici do kraja. Svaka cast za radove, ali gde pusti onog sa AUTOGENIM APARATOM da ti sprzi sve pa to se radi sa Co2... :lol: Mali brener i spec mesing zica, nije neka velika temperatrua a naliva se lepo i bude jako. To mi je cale :preved: Koliki su standardni diskovi na autu iz kog je motor? M5 e34? Mislim da ne bi trebalo ići preko toga, ništa specijalno nećeš dobiti sa kočnicama od Rovera koji ima 2.2 tone. Samo muke sa velikim felnama i skupim gumama. Dobri diskovi, pločice i pancirna creva su dovoljni za kockicu :preved: Ne znam, nemam te od m5 :) Stavio bi ja i ove od m3 ali su losi, a ovi od rovera su deblji dosta, pa kad se liznu budu debljine kao bmw-ovi kad su novi. 17 inca ide kako god Link to post Share on other sites
Desmo 0 Posted February 17, 2013 Report Share Posted February 17, 2013 Ako praviš bmw - pravi ga od bmw delova. Zajebi te engleze i struganje diskova. Pozdrav. Link to post Share on other sites
325ixA 0 Posted February 17, 2013 Report Share Posted February 17, 2013 Da, jer sve što je bmw napravio je savršeno I ima odlike relikvije. ili to samo vlasnici golf dvojki dozivljavaju tako... Link to post Share on other sites
Desmo 0 Posted February 17, 2013 Report Share Posted February 17, 2013 I ti imaš dvojku? :drinks: Link to post Share on other sites
325ixA 0 Posted February 17, 2013 Report Share Posted February 17, 2013 otvori se za bmw pa da pričamo. Link to post Share on other sites
zlaja.so 0 Posted February 17, 2013 Report Share Posted February 17, 2013 Mali brener i spec mesing zica, nije neka velika temperatrua a naliva se lepo i bude jako. To mi je cale :preved: Ako je CALE u pitanju onda je opravdano :lol: i za sve ostalo svaka cast :D Link to post Share on other sites
TOKYO 0 Posted February 17, 2013 Report Share Posted February 17, 2013 Odlican posao, i krece se u pravom smeru... ;) Te Azevke..., jel su sa Banetove kocke??? Ja nisam za crnu, zamrzeo sam je kod mene na autu, nije samo zbog prljanja, nego ubije sve konture, kad je MT2 ili M3 onda moze da prodje, ali kod obicne mi se ne svidja, najvise volim sivu, mada i bela mi je super, mozda i crvena??? Link to post Share on other sites
BMW KLINIK 0 Posted February 17, 2013 Report Share Posted February 17, 2013 Ta crvena sedišta nisu iz crnog nego iz belog m3.....kasnije je prefarban u crno.... Link to post Share on other sites
terza 0 Posted February 17, 2013 Author Report Share Posted February 17, 2013 Ako praviš bmw - pravi ga od bmw delova. Zajebi te engleze i struganje diskova. Pozdrav. Disk je skinut sa engleza a napravio ga italijan, isto kao i kandze sa e38. brembo Odlican posao, i krece se u pravom smeru... ;) Te Azevke..., jel su sa Banetove kocke??? Ja nisam za crnu, zamrzeo sam je kod mene na autu, nije samo zbog prljanja, nego ubije sve konture, kad je MT2 ili M3 onda moze da prodje, ali kod obicne mi se ne svidja, najvise volim sivu, mada i bela mi je super, mozda i crvena??? Jesu, i Azevke i diff, zadnji trap... ima dosta. Nisam za belu, mozda crvena ona kalipso...ne znam. Nemam mt2 mozda bude jednog dana ako naleti povoljno pa ce biti dobra i crna. Ta crvena sedišta nisu iz crnog nego iz belog m3.....kasnije je prefarban u crno.... Onda sam cuo pricu od pola :D i sta mu bolje stoji? :superstition: Link to post Share on other sites
