Bengvejac 0 Posted March 12, 2017 Report Share Posted March 12, 2017 Ja pomislio neki update Link to post Share on other sites
BugerMan 0 Posted March 12, 2017 Report Share Posted March 12, 2017 5 hours ago, Bengvejac said: Ja pomislio neki update I ja se ponadao. Link to post Share on other sites
ronninseb 0 Posted March 12, 2017 Report Share Posted March 12, 2017 извињавам се Link to post Share on other sites
Sasquatch 0 Posted March 25, 2017 Author Report Share Posted March 25, 2017 Evo me, cenu sam poslao preko PP Pumpa za gorivo DONE!!! I onda krece frka Za ostale koji jos uvek prate. Imao sam neke probleme. Otisao mi regulator pritiska, uz to sam nikenuo iberlauf i stavio breather: Zbog toga sam morao da promenim ulje itd. Jer naravno poplavio je motor. Pa sam se cuo sa Milosem i nasao je on sledece (Hvala Milose) : Nakacio mp3 Naravno i zamenio Papucie jer sam u takve mogucnosti Sada na ono sto je trebalo da se desi I odmah problem Kuciste za hladjak ulja mora da se rotira. Downpipe Malo da se ukroji Jos samo WG da se namesti, ali naravno nema gde pa malo sec sec, pljuni pa zalepi Bice screamer.... nije bas idealno ali lakse. Mada i sam ugao nije idealan ali sta je tu je Pa malo obrada turbine: Zatvoren interni wg I onda pec pec i malo da se prihefta sve to. Done, ima EGT sto sam dvoumio gde staviti. Trebalo bi pre trubine ali mi receno da tu najpre izgori. Eto stavljeno malo posle. i Lambda sonda nekih skoro 1m od turbine Medjutim i ovo uzeh... nije potrebno ali eto. Stiglo windage i sump baffle, treba jos da se to namesti i odliv u karter. I lagano FMIC i charge cevi. Link to post Share on other sites
Sasquatch 0 Posted March 25, 2017 Author Report Share Posted March 25, 2017 Bice toga jos ali za sada imamo ovo (Luka) END OF THE ROAD Link to post Share on other sites
N.e30 0 Posted March 25, 2017 Report Share Posted March 25, 2017 Svaka cast ?? Link to post Share on other sites
Elvir 0 Posted March 25, 2017 Report Share Posted March 25, 2017 Bruka! Link to post Share on other sites
pomoravac 0 Posted March 25, 2017 Report Share Posted March 25, 2017 Lepo ? Link to post Share on other sites
mister_e30 0 Posted March 25, 2017 Report Share Posted March 25, 2017 ?? Link to post Share on other sites
BMW FUNF 0 Posted March 25, 2017 Report Share Posted March 25, 2017 svi komplimenti,stvarno jedan, ako ne i najlepsi i najkulturniji e30 karavan Link to post Share on other sites
Sasquatch 0 Posted March 25, 2017 Author Report Share Posted March 25, 2017 Hvala svima. Nisam sve sam. Ima dosta ljudi sto su pomagali. Ima tu jos da se radi. Kao sto se vidi na slikama, drugi auto je koriscen test itd. Link to post Share on other sites
TOKYO 0 Posted March 28, 2017 Report Share Posted March 28, 2017 felne su najlepse Link to post Share on other sites
Sasquatch 0 Posted March 28, 2017 Author Report Share Posted March 28, 2017 Odlicne su Link to post Share on other sites
Sasquatch 0 Posted April 24, 2017 Author Report Share Posted April 24, 2017 Danas je ovo stiglo. Za koj dan ce da vidim ako mora da se digne glava ili ne. MLS 2.03mm Link to post Share on other sites
Stefan L. 0 Posted April 25, 2017 Report Share Posted April 25, 2017 JERI MOZE TRISTA ? xaxaxa Link to post Share on other sites
Sasquatch 0 Posted April 26, 2017 Author Report Share Posted April 26, 2017 300 nego sta! Inace sve nesto sporo ide ali haj. Crko visko pa sam sa @terza namestao Turbina je mora da se obradi i klokira da legne kako treba Otovorili da vidimo sta pise itd pa da vidimo kako ce ici charge pipe I odluka je da moramo deo limarije da secemo. Eventualno veci intercooler ako moze da stane. I evo kako izgleda auspuh 90% Link to post Share on other sites
Bengvejac 0 Posted April 26, 2017 Report Share Posted April 26, 2017 boom, done, science! Ludilo! Link to post Share on other sites
Sasquatch 0 Posted April 26, 2017 Author Report Share Posted April 26, 2017 Najverovatnije tek sutra ce biti ono sto me najvise muci. Slikam. Javljam. Link to post Share on other sites
mister_e30 0 Posted April 26, 2017 Report Share Posted April 26, 2017 Stize jos malo 27..? Link to post Share on other sites
Sasquatch 0 Posted April 26, 2017 Author Report Share Posted April 26, 2017 Mislis danas? Link to post Share on other sites
pomoravac 0 Posted April 27, 2017 Report Share Posted April 27, 2017 Fino radi se ? Link to post Share on other sites
BMW_E30 0 Posted April 27, 2017 Report Share Posted April 27, 2017 Gde si uzeo regulator pritiska i koliko je para? Link to post Share on other sites
Indorile 0 Posted April 27, 2017 Report Share Posted April 27, 2017 Ebay ili BMW, 100e Link to post Share on other sites
Sasquatch 0 Posted April 28, 2017 Author Report Share Posted April 28, 2017 Regulator je sa ebaya ispao je €88 ali to je slucajno. Inace morali smo da skidamo glavu, vracena. ARPovi drze sve to na 95nm. Stavili MLS i tako sve kako treba. Link to post Share on other sites
mister_e30 0 Posted April 28, 2017 Report Share Posted April 28, 2017 Dokle ste stigli..? Link to post Share on other sites
