mteden 0 Posted February 22, 2016 Report Share Posted February 22, 2016 Kao sto naslov kaze, imam ogroman problem potrosnje. Bez preterivanja, potrosnja je izmedju 20 i 30 litara i ne mogu da se naplacam goriva. U motoru sam zamenio sve sto sam mogao, tipa kablovi, svecice itd, cistio dizne dva puta. Da ne duzim pricu posto nije kratka, ima li neki senzon ili sta god koji regulise potrosnju goriva? U pitanju je kocka 86 godiste, 2.0 motor, 125ks. Radi se o potrosnji benzina, nema plin. Hvala unapred. Link to post Share on other sites
Nidza crveni 0 Posted February 22, 2016 Report Share Posted February 22, 2016 protokomer,ima i smrdljivi davac na glavi i kad on zvekne motor registruje da je stalno hladan i naliva ga gorivom,jel se oseca gorivo na audpuhu Link to post Share on other sites
Indorile 0 Posted February 22, 2016 Report Share Posted February 22, 2016 Davac mozes da ispitas unimerom http://www.e30zone.net/e30zonewiki/index.php/Blue_Plug#Testing Link to post Share on other sites
mteden 0 Posted February 22, 2016 Author Report Share Posted February 22, 2016 plavi davac sam zamenio novim, i kaze mi majstor gde sam bio da mozda davac nije za 2.0 motor pa i dalje daje lazne podatke motoru?!? protokomer sam menjao jer je stari zakucao od plina. ne znam sta sve nisam radio. Link to post Share on other sites
MladenR 0 Posted February 22, 2016 Report Share Posted February 22, 2016 A jel ide kako treba? Link to post Share on other sites
mteden 0 Posted February 22, 2016 Author Report Share Posted February 22, 2016 kada se ugreje ide dobro, dok je hladan raspada se xD ali u svakom trenutku, hladan ili vruc, trosi previse goriva. smrdi zivo gorivo. nekada ume da se desi da nece da upali jer presisa ali to je jednom u par meseci. i onda samo proradi :/ Link to post Share on other sites
Dzoni 0 Posted February 22, 2016 Report Share Posted February 22, 2016 Ja bih rekao da je protokomer u problemu... Ako imas nekoga ko ima isti auto a da mu je ispravan protokomer (mada tesko) samo ih prebaci da vidis ima li neke razlike... Link to post Share on other sites
Indorile 0 Posted February 22, 2016 Report Share Posted February 22, 2016 Imam ja 2.0 protokomer, cackan nesto malo by zoranm, dam ti ga za dzabe koj ce mi k***c. Ispravan je moze da posluzi. Link to post Share on other sites
Stefan L. 0 Posted February 22, 2016 Report Share Posted February 22, 2016 jel moguce da toliko poveca potrosnju kad rikne protokomer :) Link to post Share on other sites
mteden 0 Posted February 22, 2016 Author Report Share Posted February 22, 2016 Imam ja 2.0 protokomer, cackan nesto malo by zoranm, dam ti ga za dzabe koj ce mi k***c. Ispravan je moze da posluzi. druze bio bih ti zahvalan, barem da ga probam. ako nista drugo. imam ja "novi" koji je u autu i imam stari gde se klapna malo pokrivila od detonacije. majstor gde sam isao da teram auto kaze da mozda moze da od dva sastavi jedan da radi. Link to post Share on other sites
Bengvejac 0 Posted February 22, 2016 Report Share Posted February 22, 2016 I ja sam mislio da mi je protokomer, kad ono curi gorivo... Pogledaj kako ti dihtuje pumpa/plovak ispod sedista, pogledaj i na filteru goriva kako ti stoji crevo, i kod fuel rail (nznm kako je na srpskom), pogledaj regulator pritiska isto na "rail-u"... Nekad bude takva sitnica a ne primetis... Pa kad sve to radis proveri i dizne. Link to post Share on other sites
mteden 0 Posted February 22, 2016 Author Report Share Posted February 22, 2016 pumpa je spoljna, menjana je i to je okej, ne curi. dizne sam skoro cistio opet, lepo rade. promenio sam regulator pritiska goriva, stari je pustao gorivo, ovaj je dobar. gledam motor, suvo je svuda. samo mu nesto govori da naliva gorivo. Link to post Share on other sites
pomoravac 0 Posted February 22, 2016 Report Share Posted February 22, 2016 screen capture tool Proveri ovo sranje! Regulator pritiska goriva Link to post Share on other sites
miksa 0 Posted February 22, 2016 Report Share Posted February 22, 2016 Davac na motoru mislim da te zeza Zato se raspada dok je hladan ,kad se ugreje guta kolko god da nalije pa umiri rad ali trosi preterano Link to post Share on other sites
mteden 0 Posted February 22, 2016 Author Report Share Posted February 22, 2016 promenio sam i jedno i drugo. bas tako, umiri se kad se ugreje malo i radi okej ali trosi kao nevreme :D Link to post Share on other sites
Indorile 0 Posted February 23, 2016 Report Share Posted February 23, 2016 Javim ti se cim dodjem do auta da ti dam protokomer pa da vidimo ocel biti bolje sta :) Link to post Share on other sites
mteden 0 Posted February 23, 2016 Author Report Share Posted February 23, 2016 vazi, hvala. ako proradi, duznik sam ti :D Link to post Share on other sites
777.boban 0 Posted February 23, 2016 Report Share Posted February 23, 2016 Proveri da nije propisala sauh dizna tj ona na koju ide crevo sa povrata benzina stoji na usisu plave je boje,i isto tako proveri da li je povrat benzina ok,kad skines crevo sa te dizne stavi ga u neku flasu i upali auto da vidis kako ce da radi. Link to post Share on other sites
mteden 0 Posted February 23, 2016 Author Report Share Posted February 23, 2016 to vec ne znam da uradim. :/ radjen je neki bajpas zbog plina (to je stari vlasnik uradio) i sad nemam sauh kada palim auto. hteo sam da proverim taj povrat i sve to ali ne znam kako sve to izgleda. Link to post Share on other sites
