dredger 0 Posted April 2, 2014 Report Share Posted April 2, 2014 Svaka ti cast druze. Jako, jako lep hobi. Auto pravi ubica. Mogu misliti kako deres napaljenike po putu. Ne razumem se u nitro bas nikako pa me interesuje kako se puni to cudo? Link to post Share on other sites
stevanmil 0 Posted April 2, 2014 Author Report Share Posted April 2, 2014 Hvala :) Ima servisa koji to rade u BG, meni jos nije trebalo jer imam jos pola boce, ali prethodni vlasnik nitra je punio po ceni od 35e boca od 5kg. Link to post Share on other sites
dredger 0 Posted April 2, 2014 Report Share Posted April 2, 2014 Na koliki pritisak se puni boca? Link to post Share on other sites
stevanmil 0 Posted April 2, 2014 Author Report Share Posted April 2, 2014 Oko 70 bari, da ne idem sad da gledam na bocu tacno. Link to post Share on other sites
StunterSM 0 Posted April 2, 2014 Report Share Posted April 2, 2014 Stevo kad cemo se druziti malo? Jel dolazis u Cacak? Imas li planove da zadjes u moj kraj? Link to post Share on other sites
stevanmil 0 Posted April 2, 2014 Author Report Share Posted April 2, 2014 Ne znam za tvoj kraj nisam siguran, ovako u Cacak na drift sigurno :) I jos neka manifestacija ako bude zanimljiva naravno tu sam :) Link to post Share on other sites
StunterSM 0 Posted April 2, 2014 Report Share Posted April 2, 2014 Za vikend pravim rostilj, mislim da je i to manifestacija :D Link to post Share on other sites
dredger 0 Posted April 2, 2014 Report Share Posted April 2, 2014 Oko 70 bari, da ne idem sad da gledam na bocu tacno. Jel to cist azot? U ronjenju se koristi i opcija ronjenja na nitrox, to je smesa bogatija azotom i puni se u boce preko specijalnog kompresora. Ja se pomalo bavim ronjenjem, pa kad budes hteo da punis javi se da probamo da nadjemo povoljniju varijantu. Link to post Share on other sites
stevanmil 0 Posted April 2, 2014 Author Report Share Posted April 2, 2014 N2O iliti gas smejavac se puni, ne azot :) Link to post Share on other sites
dredger 0 Posted April 2, 2014 Report Share Posted April 2, 2014 Ja bio ubedjen da je azot, ne znam ni sam zasto...Znaci helijum mu daje paprike Link to post Share on other sites
dredger 0 Posted April 2, 2014 Report Share Posted April 2, 2014 Matori, imao sam 2 iz hemije :lol: Sad sam se setio koji je to gas smejavac, pomesao sam ga sa helijumom. Link to post Share on other sites
terza 0 Posted April 3, 2014 Report Share Posted April 3, 2014 Vidim ja da ce Nemanja na kraju da ti se isprdi u bocu kako je krenuo :lol: Kad se vraca SC ? Ko je pomenuo rostilj za vikend kod Mikija :P Link to post Share on other sites
stevanmil 0 Posted April 4, 2014 Author Report Share Posted April 4, 2014 Ako budem hteo da pravim hemijsko oruzje zovem ga :D Za s/c ovih dana razmatram sta i kako cu, po svoj prilici mora da nabavim dizne od lancie kappe turbo Razmisljao da radim bregaste, da stavim kombinaciju m54b30 usis bregasta i m50b25nv usis na izduv stranu (sto je priblizno specifikacijama shrick i bregastih od americkog m3), ali proucavao malo sve to kako deluje na ugradnju superchargera i sa agresivnijim bregastim za atmosferac motor bi ustvari gubio kad ugradim s/c. Jer njemu ne odgovara veliko preklapanje iliti overlap usisne i izduvne bregaste (sto agresivne bregaste imaju jer tako postizu dobijanje snage na visokim obrtajima) jer tada duva mali deo vazduha pravo u auspuh. E taj mali deo zavisi koliki je overlap, sto veci overlap vise ode u auspuh pravo, neiskorisceno. A sa tim bregastim bi trenutno kao atmosferski motor trebao dobiti 15 ak hp. Ja nisam isao na dyno ali na bimmerforums sa atmosferskim setupom kao mojim + bregaste ove guraju po 240-245hp na radilici, tj 210 ak konja na tocku. Tako da ne znam kojim putem da idem, da li kao atmosferac ili supercharged.. Link to post Share on other sites
StunterSM 0 Posted April 4, 2014 Report Share Posted April 4, 2014 Ako ode pogresnim putem Steva taj kompresor ide na pravi put, tj kod mene hahahah Link to post Share on other sites
Raso ///M 0 Posted April 8, 2014 Report Share Posted April 8, 2014 sto mislis koliko bi ima ks sa tim superchargerom? Link to post Share on other sites
stevanmil 0 Posted April 9, 2014 Author Report Share Posted April 9, 2014 Sa 0.4 bara pritiska treba oko 300 najmanje na radilici da ima, uz poprilican obrtni moment, najveci dobici su na momentu. Link to post Share on other sites
stevanmil 0 Posted June 9, 2014 Author Report Share Posted June 9, 2014 Supercharger postavljen, 0.2-0.25 bara pritisak od niskih obrtaja do max. Veliki dobici na obrtnom momentu, kako je pre najjace povlacio od 4000 obrtaja tako sad od 2000 i to jako do 6500 obrtaja. Sve radi na fabrickoj struji veoma dobro, na tom pritisku. Odnos remenica koji koristim 2.18. Interkuler ugradjen, bypass ventil homemade postavljen, radi kako treba, dok je pusten gas vakum povuce leptir i vazduh iz s/c ide u atmosferu, cim dam gas leptir se zatvori i vazduh ide u motor.. Spaner kaisa napravljen (pre ga nisam imao). Usis superchargera bolje odradjen, filter vazduha mi se nalazi u braniku. Supercharger portovan i ispoliran najfinijom smirglom koju sam mogao naci, 1000. Za 5 min sve vratim na fabricko kad hocu da mi potrosnja bude normalna, skinem kais i crevo i stavim fabricko kuciste filtera i to je to. Jedino kad trebam opet vratiti kais i crevo da ga vozim sa s/c moram resetovati mape. Ubrzanje do 100 se poboljsalo za vise od pola sekunde, tako da je sad 6sek do 100kmh. Generalno ja sam veoma zadovoljan, skupljaju se pare za det3 i povecanje pritiska na 0.45, dizne za tu snagu i pritisak sam vec kupio, od lancie kappe turbo, 380cc na 3.5 bar, remenicu takodje imam vec pripremljenu da ga brze okrece. Link to post Share on other sites
bokibmw 0 Posted June 9, 2014 Report Share Posted June 9, 2014 Stevo stavljaj cepice na poklopac motora odmah......... kompresor jezivo zvuci... Link to post Share on other sites
stevanmil 0 Posted June 9, 2014 Author Report Share Posted June 9, 2014 Cepici postavljeni :) Ne znam sta je sa videom pa nece kako treba da stoji u forumu, vec sam postavljao ranije ali sad zeza. ha, evo ga, imalo s za secure posle http Link to post Share on other sites
susice34 0 Posted June 9, 2014 Report Share Posted June 9, 2014 Auuu jbt al ima zvuk... Postavi neki klip da vidimo kako to ide. Link to post Share on other sites
stevanmil 0 Posted June 9, 2014 Author Report Share Posted June 9, 2014 Link to post Share on other sites
smg 0 Posted June 10, 2014 Report Share Posted June 10, 2014 Čuje se kao omanja formula :) Svaka čast! Link to post Share on other sites
Stefan L. 0 Posted June 10, 2014 Report Share Posted June 10, 2014 auuu... koliko konja ima trenutno ? vidim da ubrzava j kevu Link to post Share on other sites
susice34 0 Posted June 10, 2014 Report Share Posted June 10, 2014 Cuje se dobro ali meni iskreno i ne ide nesto mnooogo dobro, mada mozda gresim jer ipak se sa snimka ne moze uociti ubrzanje.. Link to post Share on other sites
