somi92 0 Posted December 9, 2020 Report Share Posted December 9, 2020 Nije, imao sam e46 coupe benzinca, za vodu jeSent from my EML-L29 using Tapatalk Link to post Share on other sites
NikNS 0 Posted December 9, 2020 Report Share Posted December 9, 2020 1 hour ago, kami said: E90 nije imao nikakve pokazivace temperature ulja ili vode. Za F sigurno pokazuje ulje, ali mislim da je to i za starije E serije. Sent from my SM-G975F using Tapatalk F je ulja sto se i vidi na tabli a E serije su pokazivale samo vodu tj antifriz. Link to post Share on other sites
dredger 0 Posted December 9, 2020 Report Share Posted December 9, 2020 Jedino kod M u E seriji je bila i temperatura ulja. Link to post Share on other sites
Indorile 0 Posted December 9, 2020 Report Share Posted December 9, 2020 I na 335i Link to post Share on other sites
chevu1990 0 Posted December 10, 2020 Report Share Posted December 10, 2020 (edited) Na F seriji se moze otkljucati skriveni meni gde se mogu pratiti razni parametri, izmedju ostalog i coolant temp. iliti temperatura rashladne tecnosti. Edited December 10, 2020 by chevu1990 Link to post Share on other sites
somi92 0 Posted December 10, 2020 Report Share Posted December 10, 2020 Da, tako ja pratim, zadrzis ono dugme za resetovanje km, otvori ti menu, odes na unlock, ukucas zbir zadnjih 5 brojeva sasije i otkljuca ti sve. Mana je sto svaki put moras iznova, ne moze ostati otkljucanSent from my EML-L29 using Tapatalk Link to post Share on other sites
NikNS 0 Posted December 10, 2020 Report Share Posted December 10, 2020 Ma da zato i kazem najlakse je uzeti Carly pa preko fona sve zacas pogledati a ne smeta ti sto je zaboden u obd Link to post Share on other sites
Sale-Sombor 0 Posted December 10, 2020 Report Share Posted December 10, 2020 10 minutes ago, NikNS said: Ma da zato i kazem najlakse je uzeti Carly pa preko fona sve zacas pogledati a ne smeta ti sto je zaboden u obd Da, samo sto moras svake godine da placas aplikaciju 60-70€ Link to post Share on other sites
NikNS 0 Posted December 10, 2020 Report Share Posted December 10, 2020 Pa znam al kolko u proseku kvarova imamo godisnje isplati se imati plus i zbog kodiranja 😁 Link to post Share on other sites
Sasa0906 0 Posted December 10, 2020 Report Share Posted December 10, 2020 Imam bimercode, puno je bolji od carlyEnvoyé de mon iPhone en utilisant Tapatalk Link to post Share on other sites
Sigtran 0 Posted December 11, 2020 Report Share Posted December 11, 2020 20 hours ago, Sasa0906 said: Imam bimercode, puno je bolji od carly To je diskutabilno, a definitivno Carly nudi više. Ali je Carly i skuplji, jer plaćaš applikaciju godišnje (ja svake godine čekam i obnovim na Black Friday, pa uvek košta 20% manje). Link to post Share on other sites
alenas 0 Posted December 11, 2020 Report Share Posted December 11, 2020 22 hours ago, Sale-Sombor said: Da, samo sto moras svake godine da placas aplikaciju 60-70€ odakle ti taj info da se placa svake godine ? ja sam platio 50e apk i obd kabal od njih 50e pre 5 godina i od tada nista vise cak mi je aktiviran expert mode. pitao sam pre nego sto sam platio koliko vazi licenca i rekose mi da je dozivotna samo je potrebno da se logujem s mailom preko kod sam kupio . Link to post Share on other sites
NikNS 0 Posted December 11, 2020 Report Share Posted December 11, 2020 24 minutes ago, alenas said: odakle ti taj info da se placa svake godine ? ja sam platio 50e apk i obd kabal od njih 50e pre 5 godina i od tada nista vise cak mi je aktiviran expert mode. pitao sam pre nego sto sam platio koliko vazi licenca i rekose mi da je dozivotna samo je potrebno da se logujem s mailom preko kod sam kupio . Cekaj kabl ili si uzeo adapter koji ide u obd pa preko fona sve resavas? Izgleda da ne pricamo o istom tipu Carlya Link to post Share on other sites
Sale-Sombor 0 Posted December 11, 2020 Report Share Posted December 11, 2020 37 minutes ago, alenas said: odakle ti taj info da se placa svake godine ? ja sam platio 50e apk i obd kabal od njih 50e pre 5 godina i od tada nista vise cak mi je aktiviran expert mode. pitao sam pre nego sto sam platio koliko vazi licenca i rekose mi da je dozivotna samo je potrebno da se logujem s mailom preko kod sam kupio . Od prosle godine se placa licenca za aplikaciju svake godine. A svi koji su pre tog perioda kupili, oni imaju za stalno. Znam iz razloga sto sam hteo sebi da uzmem, pa sam se dobro raspitao Link to post Share on other sites
Boban_m 0 Posted December 11, 2020 Report Share Posted December 11, 2020 Uz BimmerCode treba imati i BimmerLink. Prvi kodira drugi radi dijagnostiku. Za registrovanje akumulatora, u slucaju da stavljas obicni kiselinski npr, moras imati oba softvera. Sa BimmerCode mijenjas (kodiras) info o vrsti i kapacitetu akumulatora a u BimmerLink vrsis registraciju. Ako stavljas isti BMW akumulator kao sto je i bio (a ko to radi, jel), onda je BimmerLink dovoljan. Link to post Share on other sites
alenas 0 Posted December 12, 2020 Report Share Posted December 12, 2020 On 12/11/2020 at 10:06 AM, NikNS said: Cekaj kabl ili si uzeo adapter koji ide u obd pa preko fona sve resavas? Izgleda da ne pricamo o istom tipu Carlya obd kabal, a na drugom kraju usb pa preko otg-a ubodem u mobilni. mozda je bolja vartijanta bluetooth ali tada nije bilo. iscitavas sve, greske, reset servisa predjenu km iz svih modula, kodiranje ( aktivacija i deaktivacija funkcija koje fabrika nije aktivirala), dpf itd. meni se isplatio odavno jer neki servisi lupaju cene, a da ne pominjem kad umesto halogene stavljas led sijalice pa tinsole pamet da treba da lemim neke otpornike. Link to post Share on other sites
